  • 阅读:15165
  • 回复:12
阿朗C网get_cell脚本如何使用
yzhnod1
积分 10043
帖子 58
威望 18902 个
注册 2008-2-28
发表于 2009-06-28 16:58:18  只看楼主
我想用它提取所有基站的经纬度。有筒子知道用法吗?执行后提示信息如下:
Please supply ap root login and/or password
USAGE: ./get_cell [options]
OPTIONS:
Login Parameters:
-l [login]Specify the AP login (required)
-p [Password]Specify the AP password (required)
-t [Target AP] Specify the Target AP. i.e. ap202 (optional)
-c [Central AP]Specify the Central AP. i.e. ap08 (optional)
-flx_login [login]Specify the FLX login (optional)
-flx_psswd [Psswd]Specify the FLX password (optional)
Filters:
-a Run the script on all the cells
-cell [bts1,bts2] Specify Cell/s. Comma separated List (optional)
-cdm [CDM number] Query a specific CDM (optional)
-k Keepgoing. Continues interrupted executions
-mod_onlyPerform task only on Mod1.0-3.0 cells
-1bts_onlyPerform task only on Mod4.0 cells
-crc_onlyPerform task only on CRC controllers
-urc_onlyPerform task only on URC controllers
-urc2_onlyPerform task only on URC-II controllers
-1x_only Perform task only on 3G1x cells
-do_only Perform task only on EVDO cells
-dp [CDM number]DO Parent - CDM# (optional switch)
-use_flx Uses the given flx to access the DO controllers
Actions:
-cdm_infoPrint info obtained from the DB
-umc_cmd [string] Execute the string on the UMC controller
-chk_nfd Check the NFD backplane record
-fix_nfd Fix the NFD backplane record
-gpsGet the GPS info from the timing unit
-ctu_dbg Get the CTU debug data
-gpar Get CSU Parameters
-macDisplay the MAC adrs of the controller
-evm_cmd "string" Type a command on the EVM
-put_file "string"Transfers the given file to the controller
-start_script "string"Set the startup script flag on controller
-get_pmapsRetrieve the pormap files from a controller
-upd_bootrom [UMC number]Update the Boot generic of the controller
NOTE: use 4 to update the spare on a Mod4 Frame
On Legacy frames use 2,4,6for the spares
[ 本帖最后由 yzhnod1 于 2009-6-28 17:02 编辑 ]
    • spatial 威望 +6 个
      · 鼓励技术交流! 详细.. 发表与:2010-9-8 21:58:25
    boinn
    积分 45435
    帖子 4484
    威望 7655 个
    专家指数 97
    注册 2007-8-23
    发表于 2009-06-28 17:33:55  QQ
    可以把get_cell脚本传上来,进一步分析一下。
    积分 3927
    帖子 440
    威望 6875 个
    注册 2007-5-25
    发表于 2009-06-28 19:38:25
    我有相关的资料和脚本,但是我却不去提取,万一AP出问题怎么办?
    积分 3927
    帖子 440
    威望 6875 个
    注册 2007-5-25
    发表于 2009-06-28 19:40:12
    你的权限不够,登陆AP要用root名户名和密码登陆
    yzhnod1
    积分 10043
    帖子 58
    威望 18902 个
    注册 2008-2-28
    发表于 2009-06-28 19:50:00  只看楼主
    附件只能传图片格式?
    我有AP的root帐号,只是它给出的参数提示太简单,不是很明白
    yzhnod1
    积分 10043
    帖子 58
    威望 18902 个
    注册 2008-2-28
    发表于 2009-06-28 19:54:44  只看楼主
    新建站的经纬度很多不准确,网优的时候判断容易出错,烦~
    tianyu348
    积分 14687
    帖子 1370
    威望 28015 个
    专家指数 51
    注册 2009-3-9
    发表于 2009-06-28 20:25:30
    了解~~~了解~~~
    tianyu348
    积分 14687
    帖子 1370
    威望 28015 个
    专家指数 51
    注册 2009-3-9
    发表于 2009-06-28 20:29:06
    了解,还好吧
    yong9603
    积分 1558
    帖子 301
    威望 1812 个
    注册 2008-5-26
    发表于 2009-12-19 15:27:37
    路过.............................
    godwin65326
    积分 -508
    帖子 27
    威望 8769 个
    专家指数 -643
    注册 2007-3-24
    发表于 2010-03-25 00:48:51
    ./get_cell -gps -cell xx -cdm 1 -t apxx -l root -p "password"
    试过提取GPS是没问题的,不会影响业务
    chuangye006
    积分 50
    威望 106 个
    注册 2010-5-5
    发表于 2010-05-09 23:26:32
    ./get_cell -gps -cell xx -cdm 1 -t apxx -l root -p "password"${(]1C0d+d7y9
    foxsfire
    积分 60
    威望 504 个
    注册 2011-2-19
    发表于 2013-10-11 11:44:07
    貌似不能一次性全部提取吧,我看过的文档好像讲的是单站提取GPS的,但是目前很多基站都是BBU-RRU的方式,比如9234、9926,
    sparcaaa
    积分 286
    帖子 57
    威望 132 个
    注册 2014-9-24
    发表于 2014-11-26 21:15:52
    推荐一个不错的在线通信技术学习网站www.51xuetongxin.com。或者百度"51学通信"第一个就是。
    主要是一些通信专业从业人录制的技术视频,包括IP技术、网络技术、2G/3G/4G_LTE_EPC_IMS等方面的技术。
    入门者也不用担心,上面还有专门针对未入门的菜鸟准备的通信技术入门视频,从物理介质、网线网卡光纤的分类、网络的构成讲起,循序渐进。非常推荐。而且还是免费的哦,在线视频教学哦。
    当前时区 GMT+8, 现在时间是 2026-08-23 22:54:02
    Processed in 0.524267 second(s), 30 queries , Gzip enabled
