  • 阅读:3036
  • 回复:4
[下载] Mimo_Transmission_Schemes_for_LTE_and_HSPA_Networks
rochut
积分 130
帖子 26
威望 5070 个
注册 2007-6-14
发表于 2009-08-29 21:35:47  只看楼主
【资料名称】:Mimo_Transmission_Schemes_for_LTE_and_HS
【资料作者】:3g american
【资料日期】:June-2009
【资料语言】:英文
【资料格式】:PDF
Table of Contents
1 TERMINOLOGY .............................................................................................................................................. 4
2 Executive Summary ...................................................................................................................................... 5
3 PRINCIPLES .................................................................................................................................................... 6
3.1 Multi‐antenna‐transmission basics .........................................................................................................6
3.1.1 Improving SINR ................................................................................................................................ 6
3.1.2 Sharing SINR .................................................................................................................................... 6
3.1.3 Peak rate or coverage ...................................................................................................................... 8
3.1.4 Precoding......................................................................................................................................... 8
3.1.5 MIMO channel properties affecting the choice of transmission scheme ...................................... 11
3.1.6 What distinguishes beamforming relative precoding? .................................................................. 13
3.2 BS ANTENNA CONFIGURATIONS .......................................................................................................... 14
3.3 UE ANTENNA CONFIGURATIONS ......................................................................................................... 15
3.3.1 UE Considerations .......................................................................................................................... 15
3.3.2 Impact of Multiple Antennas on Size ............................................................................................. 17
3.3.3 Battery Consumption of Multiple Antennas .................................................................................. 17
3.3.4 Advanced‐Antenna Concepts for UE Application ........................................................................... 18
4 CURRENT MIMO TRANSMISSION SCHEMES ................................................................................................ 19
4.1 Introduction to LTE Rel‐8 MIMO Algorithms ....................................................................................... 19
4.2 DL SU‐MIMO AND Transmit Diversity (TxD) ........................................................................................ 20
4.2.1 Transmit diversity for two antenna ports ...................................................................................... 20
4.2.2 Transmit diversity for four antenna ports ...................................................................................... 21
4.2.3 Precoded spatial multiplexing for LTE ............................................................................................ 21
4.3 DL‐MIMO in HSPA ............................................................................................................................... 26
4.4 DL MULTIUSER MIMO .......................................................................................................................... 27
4.4.1 Single‐layer dedicated beamforming in LTE ................................................................................... 28
4.5 UL MULTIUSER MIMO .......................................................................................................................... 28
4.6 ALGORITHM ADAPTATION ................................................................................................................... 30
5 EMERGING MIMO TRANSMISSION SCHEMES ............................................................................................. 31
5.1 Downlink Dual‐Layer Beamforming ..................................................................................................... 31
5.2 Uplink Single‐User MIMO .................................................................................................................... 31
5.3 Extended Downlink Single‐User MIMO ............................................................................................... 32
5.4 MU‐MIMO ........................................................................................................................................... 32
5.5 CoMP ................................................................................................................................................... 34
5.5.1 PRINCIPLE ...................................................................................................................................... 34
5.5.2 CoMP Architecture ......................................................................................................................... 34
5.5.3 DL COMP ....................................................................................................................................... 36
5.5.4 UL COMP ....................................................................................................................................... 37
6 SYSTEM PERFORMANCE .............................................................................................................................. 37
6.1 MAPPING MIMO ALGORITHMS TO eNB and UE ANTENNA CONFIGURATIONS .................................. 37
6.1.1 Algorithm Mappings ....................................................................................................................... 38
6.2 DL SYSTEM PERFORMANCE ........................................................................................................... 39
6.2.1 The Baseline Case (1V) ................................................................................................................ 39
6.2.2. OL‐MIMO with DIV Antenna Configurations .............................................................................. 40
6.2.3. CL‐MIMO with DIV Antenna Configurations............................................................................... 43
6.2.4. MIMO with ULA‐4V ..................................................................................................................... 45
6.3 UL SYSTEM PERFORMANCE ........................................................................................................... 46
6.3.1 The Baseline Case with DIV‐1X ................................................................................................... 46
6.3.2 UL MU‐MIMO with DIV‐1X ......................................................................................................... 47
7 Concluding Remarks .................................................................................................................................. 49
8 REFERENCES ................................................................................................................................................ 50
9 ACKNOWLEDGEMENTS ............................................................................................................................... 50
2009-8-29 21:35:47  下载次数: 33
Mimo_Transmission_Schemes_for_LTE_and_HSPA_Networks_June-2009.pdf (950.4 KB)
    • onlyjim 威望 +5 个
      · 感谢分享 详细.. 发表与:2014-8-30 21:36:54
    fantastic_987
    积分 551
    帖子 110
    威望 3554 个
    注册 2009-9-12
    发表于 2009-09-15 22:36:27
    gooooooooood,定了学习学习
    hisenequeen
    积分 3029
    帖子 293
    威望 4268 个
    注册 2009-5-20
    发表于 2009-11-06 11:25:24
    谢谢楼主了 ~~~
    水冷云
    积分 105
    帖子 21
    威望 10 个
    注册 2009-10-16
    发表于 2010-04-12 16:47:49
    这么有难度啊
    zkzhd
    积分 394
    帖子 48
    威望 3978 个
    注册 2006-5-29
    来自 JLU
    发表于 2011-09-29 09:53:36
    非常感谢啊,资料非常好
    改变不能接受的,接受不能改变的!
    标题 [下载] Mimo_Transmission_Schemes_for_LTE_and_HSPA_Networks" tabindex="1">
    当前时区 GMT+8, 现在时间是 2026-08-18 21:47:43
    Processed in 0.834549 second(s), 21 queries , Gzip enabled
