  • 阅读:2548
  • 回复:5
[下载] 【安捷伦】MIMO in LTE Operation and Measurement-Excerpts on LTE Test
smartcat
财富勋章·大富豪   C友·活跃勋章   财富勋章·富甲一方
积分 5474
帖子 982
威望 208298 个
礼品券 1500 个
专家指数 364
注册 2009-10-19
发表于 2009-12-13 13:24:43  只看楼主
【资料名称】:MIMO in LTE Operation and Measurement-Ex
【资料作者】:安捷伦
【资料日期】:2009
This application note is written for people who need an understanding of
Multiple Input Multiple Output (MIMO) radio operation as it applies to Long
Term Evolution (LTE). MIMO (otherwise known as spatial multiplexing) is one
of several multiple antenna techniques that are being implemented in LTE;
however, this application note will primarily focus on MIMO implementations.
Increasing use of high-bandwidth applications (such as streaming video) drives
a continued desire for higher throughput or better coverage from wireless
systems. To some extent, the use of more complex modulation formats such as
Orthogonal Frequency Division Multiplexing (OFDM) and 64 QAM has satisfied
this need. Other optimizations have been made through multiple antenna
techniques, including the use of more than one antenna, receiver chains that
combine multipath signals and multiple base station antennas correlated in
phase to shape coverage area.
Further advances are continually being made. Changing the use of the spectrum
available is being pursued through several approaches, including MIMO.
Release 8 of the 3GPP specifications, which specifies the Long Term Evolution
towards 4th generation (4G) systems (LTE), includes new requirements for
operation, where a base station and handset communicate using two or more
transmit and receive chains and takes advantage of the differences in radio
transmission paths between them.The goal is to increase both overall capacity
of a cell and the data rate that a single user can expect from the system.
MIMO radios get more from the RF bandwidth they occupy than their single-
channel equivalents by exploiting differences in the paths between the
transmitter and the receiver inputs. If a conventional single-channel radio
system creates one data “pipe” between the transmitter and the receiver, the
object of a MIMO radio system is to create multiple such pipes. It does this
by creating a mathematical model of the paths from transmitters to receivers
and solving the resulting equations, and has to do so as fast as the channel is
changing. If the data pipes can be completely separated, the channel capacity
increases linearly as more transmitter-receiver pairs are added.
The radio environment does not give up increases in capacity easily. MIMO
radio operation relies on the ability to separate the “pipes”. Like a solution to
a mathematical puzzle, there have to be enough equations compared to the
number of unknowns. This is added to the usual requirements to deal with
matters of interference, noise, interoperability, hardware costs and current
consumption.
Testing will play an important role in helping to make sure the radios operate
correctly, both individually and between the many different vendors’ designs
that will be deployed.
2009-12-13 13:24:43  下载次数: 25
MIMO in LTE Operation and Measurement-Excerpts on LTE Test_Agilent.pdf (1.13 MB)
    ashuang
    积分 3922
    帖子 784
    威望 16027 个
    注册 2009-7-12
    发表于 2010-01-05 22:53:45
    谢谢楼主分享好东西
    dingding
    kunsino
    C友·铁杆勋章   C友·贡献勋章   精华发帖   专家·高级勋章
    积分 108572
    帖子 4145
    威望 900503 个
    专家指数 1199
    注册 2007-3-28
    发表于 2010-01-30 07:40:08
    谢谢楼主的分享,
    人生总有失意的时候,逃避不是最好的办法,我相信我有勇气和能力去挑战;年轻时多受点挫折无所谓!
    newwinker
    积分 5381
    帖子 1052
    威望 61573 个
    专家指数 31
    注册 2007-6-6
    发表于 2010-02-03 19:00:37
    貌似不错的资料哦 收了收了
    panda_aiai
    积分 2552
    帖子 510
    威望 1086 个
    注册 2010-5-4
    发表于 2010-05-12 09:00:30
    感谢楼主啊..........
    hhyaya
    积分 7918
    帖子 840
    威望 16692 个
    专家指数 106
    注册 2006-7-7
    发表于 2010-06-24 07:58:07
    十分感谢,学习一下
    标题 [下载] 【安捷伦】MIMO in LTE Operation and Measurement-Excerpts on LTE Test" tabindex="1">
    当前时区 GMT+8, 现在时间是 2026-08-18 21:55:02
    Processed in 0.587701 second(s), 25 queries , Gzip enabled
