  • 阅读:2969
北电的考试题
spray915
积分 327
帖子 35
威望 1595 个
发表于 2007-03-14 09:55:01  只看楼主
英文笔试题
1. Tranlation (Mandatory)
CDMA venders have worked hard to give CDMA roaming capabilities via the development of RUIM-essentially, a SIM card for CDMA handsets currently being deployed in China for new CDMA operator China Unicom. Korean cellco KTF demonstrated earlier this year the ability to roam between GSM and CDMA using such cards.However,only the card containing the user’s service data can roam-not the CDMA handset or the user’s number (except via call forwarding).
2. Programming (Mandatory)
Linked list
a. Implement a linked list for integers,which supports the insertafter (insert a node after a specified node) and removeafter (remove the node after a specified node) methods;
b. Implement a method to sort the linked list to descending order.
3. Debugging (Mandatory)
a. For each of the following recursive methods,enter Y in the answer box if themethod terminaters (assume i=5), Otherwise enter N.
static int f(int i){
return f(i-1)*f(i-1);
Ansewr:
if(i==0){return 1;}
else {return f(i-1)*f(i-1);}
Ansewr:
if(i==0){return 1;}
else {return f(i-1)*f(i-2);}
Ansewr:
b. There are two errors in the following JAVA program:
static void g(int i){
if(i==1){return;}
if(i%2==0){g(i/2);return;}
else {g(3*i);return;}
please correct them to make sure we can get the printed-out result as below:
3105168421
    jackddf
    积分 2766
    帖子 225
    威望 1182 个
    注册 2007-5-14
    发表于 2007-05-25 13:27:40
    强啊!这么强啊!我还真没有想到还要考这么多啊!
    韦华山
    积分 15840
    帖子 1475
    威望 4781 个
    专家指数 11
    注册 2007-6-14
    来自 广西
    发表于 2008-03-25 14:33:25
    自己还得不定学习啊,可别落伍了.............
    当前时区 GMT+8, 现在时间是 2026-07-23 10:28:05
    Processed in 0.477800 second(s), 14 queries , Gzip enabled
