  • 阅读:6786
  • 回复:9
网络分析仪基础
alvinway
积分 547
帖子 111
威望 7326 个
专家指数 -8
注册 2010-7-10
发表于 2010-07-11 00:29:40  只看楼主
【资料名称】:网络分析仪基础
【资料作者】:无
【资料日期】:无
网络分析仪基础1-1
Network Analyzer Basics Copyright
2000
Slide 1
Welcome to Network Analyzer Basics.
1-2
2000
Network Analysis is NOT.…
Router
Bridge
Repeater
Hub
Your IEEE 802.3 X.25 ISDN
switched-packet data stream
is running at 147 MBPS with
a BER of 1.523 X 10 . . . -9
Slide 2
This module is not about computer networks! When the name "network analyzer" was
coined many years ago, there were no such things as computer networks. Back then,
networks always referred to electrical networks. Today, when we refer to the things
that network analyzers measure, we speak mostly about devices and components.
1-3
2000
What Types of Devices are Tested?
Passive Device type Active
Low Integration High
Antennas
Switches
Multiplexers
Mixers
Samplers
Multipliers
Diodes
Duplexers
Diplexers
Filters
Couplers
Bridges
Splitters, dividers
Combiners
Isolators
Circulators
Attenuators
Adapters
Opens, shorts, loads
Delay lines
Cables
Transmission lines
Waveguide
Resonators
Dielectrics
R, L, C's
RFICs
MMICs
T/R modules
Transceivers
Receivers
Tuners
Converters
VCAs
Amplifiers
VCOs
VTFs
Oscillators
Modulators
VCAtten’s
Transistors
Slide 3
Here are some examples of the types of devices that you can
test with network analyzers. They include both passive and
active devices (and some that have attributes of both). Many
of these devices need to be characterized for both linear and
nonlinear behavior. It is not possible to completely
characterize all of these devices with just one piece of test
equipment.
The next slide shows a model covering the wide range of
measurements necessary for complete linear and nonlinear
characterization of devices. This model requires a variety of
stimulus and response tools. It takes a large range of test
equipment to accomplish all of the measurements shown on
this chart. Some instruments are optimized for one test only
(like bit-error rate), while others, like network analyzers, are
much more general-purpose in nature. Network analyzers
can measure both linear and nonlinear behavior of devices,
although the measurement techniques are different
(frequency versus power sweeps for example). This module
focuses on swept-frequency and swept-power measurements
made with network analyzers
1-4
2000
Device Test Measurement Model
NF
Simple Stimulus type Complex
Response Complex
tool
Simpl
e
DC CW Swept Swept Noise 2-tone Multi- Complex Pulsed- Protocol
freq power tone
modulation RF
Det/Scope
Param. An.
NF Mtr.
Imped. An.
Power Mtr.
SNA
VNA
SA
VSA
84000
TG/SA
Ded. Testers
I-V
Absol.
Power
Gain/Flatness
LCR/Z
Harm. Dist.
LO stability
Image Rej.
Gain/Flat.
Phase/GD
Isolation
Rtn Ls/VSWR
Impedance
S-parameters
Compr'n
AM-PM
RFIC test
Full call
sequence
Pulsed S-parm.
Pulse profiling
BER
EVM
ACP
Regrowth
Constell.
Eye
Intermodulation
NF Distortion
Measurement
plane
Slide 4
Here is a key to many of the abbreviations used above:
Response
84000 series high-volume RFIC tester
Ded. Testers Dedicated (usually one-box) testers
VSA Vector signal analyzer
SA Spectrum analyzer
VNA Vector network analyzer
TG/SA Tracking generator/spectrum analyzer
SNA Scalar network analyzer
NF Mtr. Noise-figure meter
Imped. An. Impedance analyzer (LCR meter)
Power Mtr. Power meter
Det./Scope Diode detector/oscilloscope
Measurement
ACP Adjacent channel power
AM-PM AM to PM conversion
BER Bit-error rate
Compr'n Gain compression
Constell. Constellation diagram
EVM Error-vector magnitude
Eye Eye diagram
GD Group delay
Harm. Dist. Harmonic distortion
NF Noise figure
Regrowth Spectral regrowth
Rtn Ls Return loss
VSWR Voltage standing wave ratio
1-5
2000
Lightwave Analogy to RF Energy
RF
Incident
Reflected
Transmitted
Lightwave
DUT
Slide 5
One of the most fundamental concepts of high-frequency network analysis involves
incident, reflected and transmitted waves traveling along transmission lines. It is
helpful to think of traveling waves along a transmission line in terms of a lightwave
analogy. We can imagine incident light striking some optical component like a clear
lens. Some of the light is reflected off the surface of the lens, but most of the light
continues on through the lens. If the lens were made of some lossy material, then a
portion of the light could be absorbed within the lens. If the lens had mirrored surfaces,
then most of the light would be reflected and little or none would be transmitted
through the lens. This concept is valid for RF signals as well, except the
electromagnetic energy is in the RF range instead of the optical range, and our
components and circuits are electrical devices and networks instead of lenses and
mirrors.
Network analysis is concerned with the accurate measurement of the ratios of the
reflected signal to the incident signal, and the transmitted signal to the incident signal.
1-6
2000
• Verify specifications of “building blocks” for more
complex RF systems
• Ensure distortionless transmission
of communications signals
– linear: constant amplitude, linear phase / constant group
delay
– nonlinear: harmonics, intermodulation, compression, AMto-
PM conversion
• Ensure good match when absorbing
power (e.g., an antenna)
Why Do We Need to Test Components?
KPWR FM 97
Slide 6
Components are tested for a variety of reasons. Many components are used as
"building blocks" in more complicated RF systems. For example, in most transceivers
there are amplifiers to boost LO power to mixers, and filters to remove signal
harmonics. Often, R&D engineers need to measure these components to verify their
simulation models and their actual hardware prototypes. For component production, a
manufacturer must measure the performance of their products so they can provide
accurate specifications. This is essential so prospective customers will know how a
particular component will behave in their application.
When used in communications systems to pass signals, designers want to ensure the
component or circuit is not causing excessive signal distortion. This can be in the form
of linear distortion where flat magnitude and linear phase shift versus frequency is not
maintained over the bandwidth of interest, or in the form of nonlinear effects like
intermodulation distortion.
Often it is most important to measure how reflective a component is, to ensure that it
absorbs energy efficiently. Measuring antenna match is a good example.
1-7
2000
The Need for Both Magnitude and Phase
4. Time-domain
characterization
Mag
Time
5. Vector-error correction
Error
Measured
Actual
2. Complex impedance
needed to design
matching circuits
3. Complex values
needed for device
modeling
1. Complete
characterization of
linear networks
High-frequency transistor model
Collector
Base
Emitter
S21
S12
S11 S22
Slide 7
In many situations, magnitude-only data is sufficient for out needs. For example, we
may only care about the gain of an amplifier or the stop-band rejection of a filter.
However, as we will explore throughout this paper, measuring phase is a critical
element of network analysis.
Complete characterization of devices and networks involves measurement of phase as
well as magnitude. This is necessary for developing circuit models for simulation and
to design matching circuits based on conjugate-matching techniques. Time-domain
characterization requires magnitude and phase information to perform the inverse-
Fourier transform. Finally, for best measurement accuracy, phase data is required to
perform vector error correction.
1-8
2000
Agenda
􀁺 What measurements do we make?
􀃎 Transmission-line basics
􀃎 Reflection and transmission
parameters
􀃎 S-parameter definition
􀁺 Network analyzer hardware
􀃎 Signal separation devices
􀃎 Detection types
􀃎 Dynamic range
􀃎 T/R versus S-parameter test sets
􀁺 Error models and calibration
􀃎 Types of measurement error
􀃎 One- and two-port models
􀃎 Error-correction choices
􀃎 Basic uncertainty calculations
􀁺 Example measurements
􀁺 Appendix
Slide 8
In this section we will review reflection and transmission measurements. We will see
that transmission lines are needed to convey RF and microwave energy from one
point to another with minimal loss, that transmission lines have a characteristic
impedance, and that a termination at the end of a transmission line must match the
characteristic impedance of the line to prevent loss of energy due to reflections. We
will see how the Smith chart simplifies the process of converting reflection data to the
complex impedance of the termination. For transmission measurements, we will
discuss not only simple gain and loss but distortion introduced by linear devices. We
will introduce S-parameters and explain why they are used instead of h-, y-, or zparameters
at RF and microwave frequencies.
1-9
2000
Transmission Line Basics
Low frequencies
􀁺 wavelengths >> wire length
􀁺 current (I) travels down wires easily for efficient
power transmission
􀁺 measured voltage and current not dependent on
position along wire
High frequencies
&#1048698; wavelength ≈ or << length of transmission
medium
&#1048698; need transmission lines for efficient power
transmission
&#1048698; matching to characteristic impedance (Zo) is
very important for low reflection and maximum
power transfer
measured envelope voltage dependent on
+ I -
Slide 9
The need for efficient transfer of RF power is one of the main reasons behind the use
of transmission lines. At low frequencies where the wavelength of the signals are
much larger than the length of the circuit conductors, a simple wire is very useful for
carrying power. Current travels down the wire easily, and voltage and current are the
same no matter where we measure along the wire.
At high frequencies however, the wavelength of signals of interest are comparable to
or much smaller than the length of conductors. In this case, power transmission can
best be thought of in terms of traveling waves.
Of critical importance is that a lossless transmission line takes on a characteristic
impedance (Zo). In fact, an infinitely long transmission line appears to be a resistive
load! When the transmission line is terminated in its characteristic impedance,
maximum power is transferred to the load. When the termination is not Zo, the portion
of the signal which is not absorbed by the load is reflected back toward the source.
This creates a condition where the envelope voltage along the transmission line varies
with position. We will examine the incident and reflected waves on transmission lines
with different load conditions in following slides
1-10
2000
Transmission line Zo
• Zo determines relationship between voltage and current
waves
• Zo is a function of physical dimensions and ε
r
• Zo is usually a real impedance (e.g. 50 or 75 ohms)
for coaxial airlines (ohms)
10 20 30 40 50 60 70 80 90100
1.0
0.8
0.7
0.6
0.5
0.9
1.5
1.4
1.3
1.2
1.1
normalized values
50 ohm standard
attenuation is
lowest at 77 ohms
power handling capacity
peaks at 30 ohms
Microstrip
h
w
Coplanar
w1
w2
εr
Waveguide
Twisted-pair
Coaxial
b
a
h
Slide 10
RF transmission lines can be made in a variety of transmission media. Common
examples are coaxial, waveguide, twisted pair, coplanar, stripline and microstrip. RF
circuit design on printed-circuit boards (PCB) often use coplanar or microstrip
transmission lines. The fundamental parameter of a transmission line is its
characteristic impedance Zo. Zo describes the relationship between the voltage and
current traveling waves, and is a function of the various dimensions of the
transmission line and the dielectric constant ( ε
r) of the non-conducting material in the
transmission line. For most RF systems, Zo is either 50 or 75 ohms.
For low-power situations (cable TV, for example) coaxial transmission lines are
optimized for low loss, which works out to about 75 ohms (for coaxial transmission
lines with air dielectric). For RF and microwave communication and radar applications,
where high power is often encountered, coaxial transmission lines are designed to
have a characteristic impedance of 50 ohms, a compromise between maximum power
handling (occurring at 30 ohms) and minimum loss.
1-11
2000
Power Transfer Efficiency
RS
RL For complex impedances, maximum
power transfer occurs when ZL = ZS*
(conjugate match)
Maximum power is transferred when RL = RS
RL / RS
0.4
0.6
0.8
0 1 2 3 4 5 6 7 8 9 10
Load Power
(normalized)
Rs
RL
+jX
-jX
Slide 11
Before we begin our discussion about transmission lines, let us look at the condition
for maximum power transfer into a load, given a source impedance of Rs. The graph
above shows that the matched condition (RL = RS) results in the maximum power
dissipated in the load resistor. This condition is true whether the stimulus is a DC
voltage source or an RF sinusoid.
For maximum transfer of energy into a transmission line from a source or from a
transmission line to a load (the next stage of an amplifier, an antenna, etc.), the
impedance of the source and load should match the characteristic impedance of the
transmission line. In general, then, Zo is the target for input and output impedances of
devices and networks.
When the source impedance is not purely resistive, the maximum power transfer
occurs when the load impedance is equal to the complex conjugate of the source
impedance. This condition is met by reversing the sign of the imaginary part of the
impedance. For example, if RS = 0.6 + j0.3, then the complex conjugate RS* = 0.6 -
j0.3.
Sometimes the source impedance is adjusted to be the complex conjugate of the load
impedance. For example, when matching to an antenna, the load impedance is
determined by the characteristics of the antenna. A designer has to optimize the output
match of the RF amplifier over the frequency range of the antenna so that maximum
RF power is transmitted through the antenna
1-12
2000
Transmission Line Terminated with Zo
For reflection, a transmission line
terminated in Zo behaves like an infinitely
Zs = Zo
Zo
Vrefl = 0! (all the incident power
is absorbed in the load)
Vinc
Zo = characteristic
impedance of
transmission line
Slide 12
Let's review what happens when transmission lines are terminated in various
impedances, starting with a Zo load. Since a transmission line terminated in its
characteristic impedance results in maximum transfer of power to the load, there is no
reflected signal. This result is the same as if the transmission line was infinitely long. If
we were to look at the envelope of the RF signal versus distance along the
transmission line, it would be constant (no standing-wave pattern). This is because
there is energy flowing in one direction only.
1-13
2000
Short, Open
Zs = Zo
Vrefl
Vinc
terminated in a short or open reflects
all power back to source
In-phase (0o) for open,
out-of-phase (180o) for short
Slide 13
Next, let's terminate our line in a short circuit. Since purely reactive elements cannot
dissipate any power, and there is nowhere else for the energy to go, a reflected wave
is launched back down the line toward the source. For Ohm's law to be satisfied (no
voltage across the short), this reflected wave must be equal in voltage magnitude to
the incident wave, and be 180o out of phase with it. This satisfies the condition that the
total voltage must equal zero at the plane of the short circuit. Our reflected and
incident voltage (and current) waves will be identical in magnitude but traveling in the
opposite direction.
Now let us leave our line open. This time, Ohm's law tells us that the open can support
no current. Therefore, our reflected current wave must be 180o out of phase with
respect to the incident wave (the voltage wave will be in phase with the incident wave).
This guarantees that current at the open will be zero. Again, our reflected and incident
current (and voltage) waves will be identical in magnitude, but traveling in the opposite
direction. For both the short and open cases, a standing-wave pattern will be set up on
the transmission line. The valleys will be at zero and the peaks at twice the incident
voltage level. The peaks and valleys of the short and open will be shifted in position
along the line with respect to each other, in order to satisfy Ohm's law as described
above.
1-14
2000
Transmission Line Terminated with 25 Ω
Vrefl
Standing wave pattern
does not go to zero as
with short or open
Zs = Zo
ZL = 25 Ω
Vinc
Slide 14
Finally, let's terminate our line with a 25 Ω resistor (an impedance between the full
reflection of an open or short circuit and the perfect termination of a 50 Ω load). Some
(but not all) of our incident energy will be absorbed in the load, and some will be
reflected back towards the source. We will find that our reflected voltage wave will
have an amplitude 1/3 that of the incident wave, and that the two waves will be 180o
out of phase at the load. The phase relationship between the incident and reflected
waves will change as a function of distance along the transmission line from the load.
The valleys of the standing-wave pattern will no longer be zero, and the peak will be
less than that of the short/open case.
The significance of standing waves should not go unnoticed. Ohm's law tells us the
complex relationship between the incident and reflected signals at the load. Assuming
a 50-ohm source, the voltage across a 25-ohm load resistor will be two thirds of the
voltage across a 50-ohm load. Hence, the voltage of the reflected signal is one third
the voltage of the incident signal and is 180o out of phase with it. However, as we
move away from the load toward the source, we find that the phase between the
incident and reflected signals changes! The vector sum of the two signals therefore
also changes along the line, producing the standing wave pattern. The apparent
impedance also changes along the line because the relative amplitude and phase of
the incident and reflected waves at any given point uniquely determine the measured
impedance. For example, if we made a measurement one quarter wavelength away
from the 25-ohm load, the results would indicate a 100-ohm load. The standing wave
pattern repeats every half wavelength, as does the apparent impedance.
1-15
2000
High-Frequency Device Characterization
Transmitted
Incident
TRANSMISSION
Gain / Loss
S-Parameters
S21, S12
Group
Delay
Transmission
Coefficient
Insertion
Phase
Reflected
Incident
REFLECTION
SWR
S-Parameters
S11, S22 Reflection
Coefficient
Impedance,
Admittance
R+jX,
G+jB
Return
Loss
Γ, ρ
Τ,τ
Incident
Reflected
R Transmitted B
A
A
R
B
R
Slide 15
Now that we fully understand the relationship of electromagnetic waves, we must also
recognize the terms used to describe them. Common network analyzer terminology
has the incident wave measured with the R (for reference) receiver. The reflected
wave is measured with the A receiver and the transmitted wave is measured with the
B receiver. With amplitude and phase information of these three waves, we can
quantify the reflection and transmission characteristics of our device under test (DUT).
Some of the common measured terms are scalar in nature (the phase part is ignored
or not measured), while others are vector (both magnitude and phase are measured).
For example, return loss is a scalar measurement of reflection, while impedance
results from a vector reflection measurement. Some, like group delay, are purely
phase-related measurements.
Ratioed reflection is often shown as A/R and ratioed transmission is often shown as
B/R, relating to the measurement receivers used in the network analyzer
1-16
2000
Reflection Parameters
∞ dB
No reflection
(ZL = Zo)
ρ
RL
VSWR
0 1
Full reflection
(ZL = open, short)
0 dB
1 ∞
ZL − ZO
ZL + ZO
Reflection
Coefficient =
Vreflected
Vincident
Γ = ρ Φ
Return loss = -20 log(ρ), ρ = Γ
Voltage Standing Wave
Ratio
VSWR = Emax
Emin
1 + ρ
1 - ρ
Emax
Emin
Slide 16
Let's now examine reflection measurements. The first term for reflected waves is
reflection coefficient gamma (Γ). Reflection coefficient is the ratio of the reflected
signal voltage to the incident signal voltage. It can be calculated as shown above by
knowing the impedances of the transmission line and the load. The magnitude portion
of gamma is called rho (ρ). A transmission line terminated in Zo will have all energy
transferred to the load; hence Vrefl = 0 and ρ = 0. When ZL is not equal to Zo , some
energy is reflected and ρ is greater than zero. When ZL is a short or open circuit, all
energy is reflected and ρ = 1. The range of possible values for ρ is therefore zero to
one.
Since it is often very convenient to show reflection on a logarithmic display, the second
way to convey reflection is return loss. Return loss is expressed in terms of dB, and is
a scalar quantity. The definition for return loss includes a negative sign so that the
return loss value is always a positive number (when measuring reflection on a network
analyzer with a log magnitude format, ignoring the minus sign gives the results in
terms of return loss). Return loss can be thought of as the number of dB that the
reflected signal is below the incident signal. Return loss varies between infinity for a Zo
impedance and 0 dB for an open or short circuit.
As we have already seen, two waves traveling in opposite directions on the same
transmission line cause a "standing wave". This condition can be measured in terms of
the voltage-standing-wave ratio (VSWR or SWR for short). VSWR is defined as the
maximum value of the RF envelope over the minimum value of the envelope. This
value can be computed as (1+ρ)/(1-ρ). VSWR can take
1-17
2000
Smith Chart Review
Smith Chart maps
rectilinear
impedance
plane onto polar
plane
0 +R
+jX
-jX
Rectilinear impedance
plane
-90o
0o 180o +-
.2
.4
.6
.8
1.0
90o
0 ∞
Polar plane
Z L = Zo
Γ = 0
Constant X
Constant R
Smith chart
Γ
L Z = 0
±18
0 O 1
(short) ZL =
= 0 O Γ 1
(open)
Slide 17
Our network analyzer gives us complex reflection coefficient. However, we often want to know the
impedance of the DUT. The previous slide shows the relationship between reflection coefficient and
impedance, and we could manually perform the complex math to find the impedance. Although
programmable calculators and computers take the drudgery out of doing the math, a single number
does not always give us the complete picture. In addition, impedance almost certainly changes with
frequency, so even if we did all the math, we would end up with a table of numbers that may be
difficult to interpret.
A simple, graphical method solves this problem. Let's first plot reflection coefficient using a polar
display. For positive resistance, the absolute magnitude of Γ varies from zero (perfect load) to unity
(full reflection) at some angle. So we have a unit circle, which marks the boundary of the polar plane
shown on the slide. An open would plot at 1 ∠0o; a short at 1 ∠180o; a perfect load at the center,
and so on. How do we get from the polar data to impedance graphically? Since there is a one-to-one
correspondence between complex reflection coefficient and impedance, we can map one plane onto
the other. If we try to map the polar plane onto the rectilinear impedance plane, we find that we have
problems. First of all, the rectilinear plane does not have values to infinity. Second, circles of
constant reflection coefficient are concentric on the polar plane but not on the rectilinear plane,
making it difficult to make judgments regarding two different impedances. Finally, phase angles plot
as radii on the polar plane but plot as arcs on the rectilinear plane, making it difficult to pinpoint.
The proper solution was first used in the 1930's, when Phillip H. Smith mapped the impedance plane
onto the polar plane, creating the chart that bears his name (the venerable Smith chart). Since unity
at zero degrees on the polar plane represents infinite impedance, both plus and minus infinite
reactances, as well as infinite resistance can be plotted. On the Smith chart, the vertical lines on the
rectilinear plane that indicate values of constant resistance map to circles, and the horizontal lines
that indicate values of constant reactance map to arcs. Zo maps to the exact center of the chart.
In general, Smith charts are normalized to Zo; that is, the impedance values are divided by Zo. The
chart is then independent of the characteristic impedance of the system in question. Actual
impedance values are derived by multiplying the indicated value by Zo. For example, in a 50-ohm
system, a normalized value of 0.3 - j0.15 becomes 15 - j7.5 ohms; in a 75-ohm system, 22.5 - j11.25
ohms.
Fortunately, we no longer have to go through the exercise ourselves. Out network analyzer can
1-18
2000
Transmission Parameters
VTransmitted VIncident
Transmission Coefficient = Τ =
VTransmitted
VIncident
= τ∠φ
DUT
Gain (dB) = 20 Log
V Trans
V Inc
= 20 log τ
Insertion Loss (dB) = - 20 Log
V Trans
V Inc
= - 20 log τ
Slide 18
Transmission coefficient Τ is defined as the transmitted voltage divided by the incident
voltage. If |Vtrans| > |Vinc|, the DUT has gain, and if |Vtrans| < |Vinc|, the DUT exhibits
attenuation or insertion loss. When insertion loss is expressed in dB, a negative sign is
added in the definition so that the loss value is expressed as a positive number. The
phase portion of the transmission coefficient is called insertion phase.
There is more to transmission than simple gain or loss. In communications systems,
signals are time varying -- they occupy a given bandwidth and are made up of multiple
frequency components. It is important then to know to what extent the DUT alters the
makeup of the signal, thereby causing signal distortion. While we often think of
distortion as only the result of nonlinear networks, we will see shortly that linear
networks can also cause signal distortion.
1-19
2000
Linear Versus Nonlinear Behavior
Linear behavior:
&#1048698; input and output frequencies are
the same (no additional
frequencies created)
&#1048698; output frequency only undergoes
magnitude and phase change
f1 Frequency
Time
    alvinway
    积分 547
    帖子 111
    威望 7326 个
    专家指数 -8
    注册 2010-7-10
    发表于 2010-07-11 00:31:54  只看楼主
    Sin 360o * f * t
    Frequency
    A
    phase shift =
    to * 360o * f
    f
    DUT
    Time
    A
    to
    A * Sin 360o * f (t - to)
    Input Output
    Time
    Nonlinear behavior:
    &#1048698; output frequency may
    undergo frequency shift
    (e.g. with mixers)
    &#1048698; additional frequencies
    created (harmonics,
    f1 Frequency intermodulation)
    Slide 19
    Before we explore linear signal distortion, lets review the differences between linear
    and nonlinear behavior. Devices that behave linearly only impose magnitude and
    phase changes on input signals. Any sinusoid appearing at the input will also appear
    at the output at the same frequency. No new signals are created. When a single
    sinusoid is passed through a linear network, we don't consider amplitude and phase
    changes as distortion. However, when a complex, time-varying signal is passed
    through a linear network, the amplitude and phase shifts can dramatically distort the
    time-domain waveform.
    Non-linear devices can shift input signals in frequency (a mixer for example) and/or
    create new signals in the form of harmonics or intermodulation products. Many
    components that behave linearly under most signal conditions can exhibit nonlinear
    behavior if driven with a large enough input signal. This is true for both passive
    devices like filters and even connectors, and active devices like amplifiers
    1-20
    2000
    Criteria for Distortionless Transmission
    Linear Networks
    Constant amplitude over
    Magnitude
    Phase
    Frequency
    Frequency
    Linear phase over
    bandwidth of
    interest
    Slide 20
    Now lets examine how linear networks can cause signal distortion. There are three
    criteria that must be satisfied for linear distortionless transmission. First, the amplitude
    (magnitude) response of the device or system must be flat over the bandwidth of
    interest. This means all frequencies within the bandwidth will be attenuated identically.
    Second, the phase response must be linear over the bandwidth of interest. And last,
    the device must exhibit a "minimum-phase response", which means that at 0 Hz (DC),
    there is 0o phase shift (0o ± n*180o is okay if we don't mind an inverted
    signal).
    How can magnitude and phase distortion occur? The following two examples will
    illustrate how both magnitude and phase responses can introduce linear signal
    distortion.
    1-21
    2000
    Magnitude Variation with Frequency
    F(t) = sin wt + 1/3 sin 3wt + 1/5 sin 5wt
    Time
    Linear
    Network
    Frequency Frequency Frequency
    Magnitude
    Time
    Slide 21
    Here is an example of a square wave (consisting of three sinusoids) applied to a
    bandpass filter. The filter imposes a non-uniform amplitude change to each frequency
    component. Even though no phase changes are introduced, the frequency
    components no longer sum to a square wave at the output. The square wave is now
    severely distorted, having become more sinusoidal in nature.
    1-22
    2000
    Phase Variation with Frequency
    Frequency
    Magnitude
    Linear Network
    Frequency
    Frequency
    Time
    -360
    Time
    F(t) = sin wt + 1 /3 sin 3wt + 1 /5 sin 5wt
    Slide 22
    Let's apply the same square wave to another filter. Here, the third harmonic undergoes
    a 180o phase shift, but the other components are not phase shifted. All the amplitudes
    of the three spectral components remain the same (filters which only affect the phase
    of signals are called allpass filters). The output is again distorted, appearing very
    impulsive this time.
    1-23
    2000
    Deviation from Linear Phase
    Use electrical delay to
    remove linear portion of
    phase response
    Linear electrical length
    added
    + yields
    Frequency
    (Electrical delay function)
    Frequency
    RF filter response Deviation from linear
    phase
    Phase 1 /Div o
    Phase 45 /Div o
    Frequency
    Low resolution High resolution
    Slide 23
    Now that we know insertion phase versus frequency is a very important characteristic
    of a component, let's see how we would measure it. Looking at insertion phase directly
    is usually not very useful. This is because the phase has a negative slope with respect
    to frequency due to the electrical length of the device (the longer the device, the
    greater the slope). Since it is only the deviation from linear phase which causes
    distortion, it is desirable to remove the linear portion of the phase response. This can
    be accomplished by using the electrical delay feature of the network analyzer to cancel
    the electrical length of the DUT. This results in a high-resolution display of phase
    distortion (deviation from linear phase).
    1-24
    2000
    Group Delay
    in radians
    in radians/sec
    in degrees
    f in Hertz (ω = 2 π f)
    φωφ
    Group Delay (tg ) =
    −d φ
    d ω = −1
    360 o
    d φ
    * d f
    Frequency
    Group delay ripple
    Average delay
    t o
    t g
    Phaseφ
    Δφ
    Frequency
    Δω
    ω
    &#1048698; group-delay ripple indicates phase distortion
    &#1048698; average delay indicates electrical length of DUT
    &#1048698; aperture of measurement is very important
    Slide 24
    Another useful measure of phase distortion is group delay. Group delay is a measure
    of the transit time of a signal through the device under test, versus frequency. Group
    delay is calculated by differentiating the insertion-phase response of the DUT versus
    frequency. Another way to say this is that group delay is a measure of the slope of the
    transmission phase response. The linear portion of the phase response is converted to
    a constant value (representing the average signal-transit time) and deviations from
    linear phase are transformed into deviations from constant group delay. The variations
    in group delay cause signal distortion, just as deviations from linear phase cause
    distortion. Group delay is just another way to look at linear phase distortion.
    When specifying or measuring group delay, it is important to quantify the aperture in
    which the measurement is made. The aperture is defined as the frequency delta used
    in the differentiation process (the denominator in the group-delay formula). As we
    widen the aperture, trace noise is reduced but less group-delay resolution is available
    (we are essentially averaging the phase response over a wider window). As we make
    the aperture more narrow, trace noise increases but we have more measurement
    resolution.
    1-25
    2000
    Why Measure Group Delay?
    Same p-p phase ripple can result in different
    group delay
    Phase
    Phase
    Group
    Delay
    Group
    Delay
    −d φ
    d ω
    −d φ
    d ω
    f
    f
    f
    f
    Slide 25
    Why are both deviation from linear phase and group delay commonly measured?
    Depending on the device, both may be important. Specifying a maximum peak-to-peak
    value of phase ripple is not sufficient to completely characterize a device since the
    slope of the phase ripple is dependent on the number of ripples which occur over a
    frequency range of interest. Group delay takes this into account since it is the
    differentiated phase response. Group delay is often a more easily interpreted
    indication of phase distortion.
    The plot above shows that the same value of peak-to-peak phase ripple can result in
    substantially different group delay responses. The response on the right with the larger
    group-delay variation would cause more signal distortion.
    1-26
    2000
    Characterizing Unknown Devices
    Using parameters (H, Y, Z, S) to characterize
    devices:
    &#1048698; gives linear behavioral model of our device
    &#1048698; measure parameters (e.g. voltage and current) versus
    frequency under various source and load conditions
    (e.g. short and open circuits)
    &#1048698; compute device parameters from measured data
    &#1048698; predict circuit performance under any source and load
    conditions
    H-parameters
    V1 = h11I1 + h12V2
    I2 = h21I1 + h22V2
    Y-parameters
    I1 = y11V1 + y12V2
    I2 = y21V1 + y22V2
    Z-parameters
    V1 = z11I1 + z12I2
    V2 = z21I1 + z22I2
    h11 = V1
    I1 V2=0
    h12 = V1
    V2 I1=0
    (requires short circuit)
    (requires open circuit)
    Slide 26
    In order to completely characterize an unknown linear two-port device, we must make
    measurements under various conditions and compute a set of parameters. These
    parameters can be used to completely describe the electrical behavior of our device
    (or network), even under source and load conditions other than when we made our
    measurements. For low-frequency characterization of devices, the three most
    commonly measured parameters are the H, Y and Z-parameters. All of these
    parameters require measuring the total voltage or current as a function of frequency at
    the input or output nodes (ports) of the device. Furthermore, we have to apply either
    open or short circuits as part of the measurement. Extending measurements of these
    parameters to high frequencies is not very practical.
    1-27
    2000
    Why Use S-Parameters?
    &#1048698; relatively easy to obtain at high frequencies
    &#1048708; measure voltage traveling waves with a vector network analyzer
    &#1048708; don't need shorts/opens which can cause active devices to oscillate
    or self-destruct
    &#1048698; relate to familiar measurements (gain, loss, reflection coefficient ...)
    &#1048698; can cascade S-parameters of multiple devices to predict system
    performance
    &#1048698; can compute H, Y, or Z parameters from S-parameters if desired
    &#1048698; can easily import and use S-parameter files in our electronicsimulation
    tools Incident S21 Transmitted
    S11
    Reflected S22
    Reflected
    Transmitted Incident
    b1
    a1 b2
    a2
    S12
    DUT
    b1= S11a1 + S12 a2
    b2 = S21 a1 + S22 a2
    Port 1 Port 2
    Slide 27
    At high frequencies, it is very hard to measure total voltage and current at the device
    ports. One cannot simply connect a voltmeter or current probe and get accurate
    measurements due to the impedance of the probes themselves and the difficulty of
    placing the probes at the desired positions. In addition, active devices may oscillate or
    self-destruct with the connection of shorts and opens.
    Clearly, some other way of characterizing high-frequency networks is needed that
    doesn't have these drawbacks. That is why scattering or S-parameters were
    developed. S-parameters have many advantages over the previously mentioned H, Y
    or Z-parameters. They relate to familiar measurements such as gain, loss, and
    reflection coefficient. They are defined in terms of voltage traveling waves, which are
    relatively easy to measure. S-parameters don't require connection of undesirable loads
    to the device under test. The measured S-parameters of multiple devices can be
    cascaded to predict overall system performance. If desired, H, Y, or Z-parameters can
    be derived from S-parameters. And very important for RF design, S-parameters are
    easily imported and used for circuit simulations in electronic-design automation (EDA)
    tools like Agilent's Advanced Design System (ADS). S-parameters are the shared
    language between simulation and measurement.
    An N-port device has N2 S-parameters. So, a two-port device has four S-parameters.
    The numbering convention for S-parameters is that the first number following the "S" is
    the port where the signal emerges, and the second number is the port where the signal
    is applied. So, S21 is a measure of the signal coming out port 2 relative to the RF
    stimulus entering port 1. When the numbers are the same (e.g., S11), it indicates a
    reflection measurement, as the input and output ports are the same. The incident
    terms (a1, a2) and output terms (b1, b2) represent voltage traveling waves.
    1-28
    2000
    Measuring S-Parameters
    S 11 = Reflected
    Incident
    b1
    a 1 a2 = 0
    S 21 =
    Transmitted
    Incident
    b
    a 1 a2 = 0
    S 22 = Reflected
    Incident
    b2
    a 2 a1 = 0
    S 12 = Transmitted
    Incident
    b1
    a 2 a1 = 0
    Incident S 21 Transmitted
    S 11
    Reflected
    b 1
    a 1
    b 2
    Z0
    Load
    a2 = 0
    Forward DUT
    Transmitted S 12 Incident
    S22
    Reflected
    b2
    a2
    b
    a1 = 0
    Z0 DUT
    Load Reverse
    Slide 28
    S11 and S21 are determined by measuring the magnitude and phase of the incident,
    reflected and transmitted voltage signals when the output is terminated in a perfect Zo
    (a load that equals the characteristic impedance of the test system). This condition
    guarantees that a2 is zero, since there is no reflection from an ideal load. S11 is
    equivalent to the input complex reflection coefficient or impedance of the DUT, and
    S21 is the forward complex transmission coefficient. Likewise, by placing the source at
    port 2 and terminating port 1 in a perfect load (making a1 zero), S22 and S12
    measurements can be made. S22 is equivalent to the output complex reflection
    coefficient or output impedance of the DUT, and S12 is the reverse complex
    The accuracy of S-parameter measurements depends greatly on how good a
    termination we apply to the load port (the port not being stimulated). Anything other
    than a perfect load will result in a1 or a2 not being zero (which violates the definition for
    S-parameters). When the DUT is connected to the test ports of a network analyzer and
    we don't account for imperfect test-port match, we have not done a very good job
    satisfying the condition of a perfect termination. For this reason, two-port error
    correction, which corrects for source and load match, is very important for accurate Sparameter
    measurements (two-port correction is covered in the calibration section).
    1-29
    2000
    Equating S-Parameters with Common
    Measurement Terms
    S11 = forward reflection coefficient (input match)
    S22 = reverse reflection coefficient (output match)
    S21 = forward transmission coefficient (gain or loss)
    S12 = reverse transmission coefficient (isolation)
    Remember, S-parameters are
    inherently complex, linear
    quantities -- however, we often
    express them in a log-magnitude
    format
    Slide 29
    S-parameters are essentially the same parameters as some of the terms we have
    mentioned before, such as input match and insertion loss. It is important to separate
    the fundamental definition of S-parameters and the format in which they are often
    displayed. S-parameters are inherently complex, linear quantities. They are expressed
    as real-and-imaginary or magnitude-and-phase pairs. However, it isn't always very
    useful to view them as linear pairs. Often we want to look only at the magnitude of the
    S-parameter (for example, when looking at insertion loss or input match), and often, a
    logarithmic display is most useful. A log-magnitude format lets us see far more
    dynamic range than a linear format.
    1-30
    2000
    Frequency Frequency
    Time Time
    Nonlinear Networks
    • Saturation, crossover, intermodulation,
    and other nonlinear effects can cause
    signal distortion
    • Effect on system depends on amount
    and type of distortion and system
    architecture
    Slide 30
    We have just seen how linear networks can cause distortion. Devices which behave
    nonlinearly also introduce distortion. The example above shows an amplifier that is
    overdriven, causing the signal at the output to "clip" due to saturation in the amplifier.
    Because the output signal is no longer a pure sinusoid, harmonics are present at
    integer multiples of the input frequency.
    Passive devices can also exhibit nonlinear behavior at high power levels. A common
    example is an L-C filter that uses inductors made with magnetic cores. Magnetic
    materials often display hysteresis effects, which are highly nonlinear. Another example
    are the connectors used in the antenna path of a cellular-phone base station. The
    metal-to-metal contacts (especially if water and corrosion salts are present) combined
    with the high-power transmitted signals can cause a diode effect to occur, producing
    very low-level intermodulation products. Although the level of the intermodulation
    products is usually quite small, they can be significant compared to the low signal
    strength of the received signals, causing interference problems.
    1-31
    2000
    Measuring Nonlinear Behavior
    Most common measurements:
    &#1048698; using a network analyzer and
    power sweeps
    &#1048782; gain compression
    &#1048782; AM to PM conversion
    &#1048698; using a spectrum analyzer +
    source(s)
    &#1048782; harmonics, particularly second
    and third
    &#1048782; intermodulation products resulting
    from two or more RF
    carriers
    RL 0 dBm ATTEN 10 dB 10 dB / DIV
    CENTER 20.00000 MHz SPAN 10.00 kHz
    RB 30 Hz VB 30 Hz ST 20 sec
    LPF
    8563A SPECTRUM ANALYZER 9 kHz - 26.5 GHz
    LPF DUT
    Slide 31
    So far, we've focused most of our attention on linear swept-frequency characterization,
    which is needed for both passive and active devices. We already know that nonlinear
    behavior is important to quantify, as it can cause severe signal distortion. The most
    common nonlinear measurements are gain compression and AM-to-PM conversion
    (usually measured with network analyzers and power sweeps), and harmonic and
    intermodulation distortion (usually measured with spectrum analyzers and signal
    sources). We will cover swept-power measurements using a network analyzer in more
    detail in the typical-measurements section of this presentation. The slide shows how
    intermodulation distortion is typically measured using two signal sources and a
    spectrum analyzer as a receiver.
    1-32
    2000
    What is the Difference
    Between Network and
    Spectrum Analyzers?
    Amplitude Ratio
    Frequency
    Amplitude
    Frequency
    GHz
    Measures
    known
    signal
    Measures
    unknown
    signals
    Network analyzers:
    &#1048698; measure components,
    devices,
    circuits, sub-assemblies
    &#1048698; contain source and receiver
    &#1048698; display ratioed amplitude and
    phase
    (frequency or power sweeps)
    &#1048698; offer advanced error
    correction
    Spectrum analyzers:
    &#1048698; measure signal amplitude
    characteristics
    carrier level, sidebands,
    harmonics...)
    &#1048698; can demodulate (& measure)
    complex signals
    &#1048698; are receivers only (single channel)
    &#1048698; can be used for scalar component
    test (no
    phase) with tracking gen. or ext.
    source(s)
    Slide 32
    Now that we have seen some of the measurements that are commonly done with
    network and spectrum analyzers, it might be helpful to review the main differences
    between these instruments. Although they often both contain tuned receivers operating
    over similar frequency ranges, they are optimized for very different measurement
    applications.
    Network analyzers are used to measure components, devices, circuits, and subassemblies.
    They contain both a source and multiple receivers, and generally display
    ratioed amplitude and phase information (frequency or power sweeps). A network
    analyzer is always looking at a known signal (in terms of frequency), since it is a
    stimulus-response system. With network analyzers, it is harder to get an (accurate)
    trace on the display, but very easy to interpret the results. With vector-error correction,
    network analyzers provide much higher measurement accuracy than spectrum
    analyzers.
    Spectrum analyzers are most often used to measure signal characteristics such as
    carrier level, sidebands, harmonics, phase noise, etc., on unknown signals. They are
    most commonly configured as a single-channel receiver, without a source. Because of
    the flexibility needed to analyze signals, spectrum analyzers generally have a much
    wider range of IF bandwidths available than most network analyzers. Spectrum
    analyzers are often used with external sources for nonlinear stimulus/response testing.
    When combined with a tracking generator, spectrum analyzers can be used for scalar
    component testing (magnitude versus frequency, but no phase measurements). With
    spectrum analyzers, it is easy to get a trace on the display, but interpreting the results
    can be much more difficult than with a network analyzer.
    1-33
    2000
    Agenda
    &#1048698; What measurements do we make?
    &#1048698; Network analyzer hardware
    &#1048698; Error models and calibration
    &#1048698; Example measurements
    &#1048698; Appendix
    Slide 33
    In this next section, we will look at the main parts of a network analyzer.
    1-34
    2000
    Generalized Network Analyzer
    Block Diagram
    RECEIVER / DETECTOR
    PROCESSOR / DISPLAY
    REFLECTED
    (A)
    TRANSMITTED
    (B)
    INCIDENT
    (R)
    SIGNAL
    SEPARATION
    SOURCE
    Incident
    Reflected
    Transmitted
    DUT
    Slide 34
    Here is a generalized block diagram of a network analyzer, showing the major signalprocessing
    sections. In order to measure the incident, reflected and transmitted signal,
    four sections are required:
    • Source for stimulus
    • Signal-separation devices
    • Receivers that downconvert and detect the signals
    • Processor/display for calculating and reviewing the results
    We will briefly examine each of these sections. More detailed information about the
    signal separation devices and receiver section are in the appendix.
    1-35
    2000
    Source
    &#1048698; Supplies stimulus for system
    &#1048698; Swept frequency or power
    &#1048698; Traditionally NAs used separate
    source
    &#1048698; Most Agilent analyzers sold
    today have integrated,
    synthesized sources
    Slide 35
    The signal source supplies the stimulus for our stimulus-response test system. We can
    either sweep the frequency of the source or sweep its power level. Traditionally,
    network analyzers used a separate source. These sources were either based on openloop
    voltage-controlled oscillators (VCOs) which were cheaper, or more expensive
    synthesized sweepers which provided higher performance, especially for measuring
    narrowband devices. Excessive phase noise on open-loop VCOs degrades
    measurement accuracy considerably when measuring narrowband components over
    small frequency spans. Most network analyzers that Agilent sells today have
    integrated, synthesized sources, providing excellent frequency resolution and stability.
    1-36
    2000
    Signal Separation
    Test Port
    directional Detector
    coupler
    splitter
    bridge
    • measure incident signal for reference
    • separate incident and reflected signals
    RECEIVER / DETECTOR
    PROCESSOR / DISPLAY
    REFLECTED
    (A)
    TRANSMITTED
    INCIDENT (R) (B)
    SIGNAL
    SEPARATION
    SOURCE
    Incident
    Reflected
    Transmitted
    DUT
    Slide 36
    The next major area we will cover is the signal separation block. The hardware used
    for this function is generally called the "test set". The test set can be a separate box or
    integrated within the network analyzer. There are two functions that our signalseparation
    hardware must provide. The first is to measure a portion of the incident
    signal to provide a reference for ratioing. This can be done with splitters or directional
    couplers. Splitters are usually resistive. They are non-directional devices (more on
    directionality later) and can be very broadband. The trade-off is that they usually have
    6 dB or more of loss in each arm. Directional couplers have very low insertion loss
    (through the main arm) and good isolation and directivity. They are generally used in
    microwave network analyzers, but their inherent high-pass response makes them
    unusable below 40 MHz or so.
    The second function of the signal-splitting hardware is to separate the incident
    (forward) and reflected (reverse) traveling waves at the input of our DUT. Again,
    couplers are ideal in that they are directional, have low loss, and high reverse isolation.
    However, due to the difficulty of making truly broadband couplers, bridges are often
    used instead. Bridges work down to DC, but have more loss, resulting in less signal
    power delivered to the DUT. See the appendix for a more complete description of how
    a directional bridge works.
    1-37
    2000
    Directivity
    Directivity is a measure of how well a
    coupler can separate signals moving
    Test port
    (undesired leakage
    signal)
    alvinway
    积分 547
    帖子 111
    威望 7326 个
    专家指数 -8
    注册 2010-7-10
    发表于 2010-07-11 00:32:54  只看楼主
    (desired reflected
    signal)
    Directional Coupler
    Slide 37
    Unfortunately, real signal-separation devices are never perfect. For example, let's take
    a closer look at the actual performance of a 3-port directional coupler.
    Ideally, a signal traveling in the coupler's reverse direction will not appear at all at the
    coupled port. In reality, however, some energy does leak through to the coupled arm,
    as a result of finite isolation.
    One of the most important parameter for couplers is their directivity. Directivity is a
    measure of a coupler's ability to separate signals flowing in opposite directions within
    the coupler. It can be thought of as the dynamic range available for reflection
    measurements. Directivity can be defined as:
    Directivity (dB) = Isolation (dB) - Forward Coupling Factor (dB) - Loss (through-arm)
    (dB)
    The appendix contains a slide showing how adding attenuation to the ports of a
    coupler can affect the effective directivity of a system (such as a network analyzer)
    that uses a directional coupler.
    As we will see in the next slide, finite directivity adds error to our measured results.
    1-38
    2000
    Interaction of Directivity with the
    DUT (Without Error Correction)
    Data Max
    Add in-phase
    Device
    Directivity
    Return Loss
    Frequency
    60
    DUT RL = 40 dB
    Add out-of-phase
    (cancellation)
    Device
    Directivity
    Data = Vector Sum
    Directivity
    Device
    Data Min
    Slide 38
    Directivity error is the main reason we see a large ripple pattern in many
    measurements of return loss. At the peaks of the ripple, directivity is adding in phase
    with the reflection from the DUT. In some cases, directivity will cancel the DUT's
    reflection, resulting in a sharp dip in the response.
    1-39
    2000
    Detector Types
    Tuned Receiver
    Scalar broadband
    (no phase
    information)
    Vector
    (magnitude and
    phase)
    Diode
    DC
    AC
    RF
    IF Filter
    RF IF = F L O ±F RF
    LO
    ADC / DSP
    RECEIVER / DETECTOR
    PROCESSOR / DISPLAY
    REFLECTED
    (A)
    TRANSMITTED
    INCIDENT (R) (B)
    SIGNAL
    SEPARATION
    SOURCE
    Incident
    Reflected
    Transmitted
    DUT
    Slide 39
    The next portion of the network analyzer we'll look at is the signal-detection block.
    There are two basic ways of providing signal detection in network analyzers. Diode
    detectors convert the RF signal level to a proportional DC level. If the stimulus signal is
    amplitude modulated, the diode strips the RF carrier from the modulation (this is called
    AC detection). Diode detection is inherently scalar, as phase information of the RF
    carrier is lost.
    The tuned receiver uses a local oscillator (LO) to mix the RF down to a lower
    "intermediate" frequency (IF). The LO is either locked to the RF or the IF signal so that
    the receivers in the network analyzer are always tuned to the RF signal present at the
    input. The IF signal is bandpass filtered, which narrows the receiver bandwidth and
    greatly improves sensitivity and dynamic range. Modern analyzers use an analog-todigital
    converter (ADC) and digital-signal processing (DSP) to extract magnitude and
    phase information from the IF signal. The tuned-receiver approach is used in vector
    network analyzers and spectrum analyzers.
    1-40
    2000
    Broadband Diode Detection
    &#1048698; Easy to make broadband
    &#1048698; Inexpensive compared to tuned receiver
    &#1048698; Good for measuring frequency-translating devices
    &#1048698; Improve dynamic range by increasing power
    &#1048698; Medium sensitivity / dynamic range
    10 MHz 26.5 GHz
    Slide 40
    The two main advantages of diode detectors are that they provide broadband
    frequency coverage ( < 10 MHz on the low end to > 26.5 GHz at the high end) and
    they are inexpensive compared to a tuned receiver. Diode detectors provide medium
    sensitivity and dynamic range: they can measure signals to -60 dBm or so and have a
    dynamic range around 60 to 75 dB, depending on the detector type. Their broadband
    nature limits their sensitivity and makes them sensitive to source harmonics and other
    spurious signals. Dynamic range is improved in measurements by increasing input
    power.
    AC detection eliminates the DC drift of the diode as an error source, resulting in more
    accurate measurements. This scheme also reduces noise and other unwanted signals.
    The major benefit of DC detection is that there is no modulation of the RF signal,
    which can have adverse effects on the measurement of some devices. Examples
    include amplifiers with AGC or large DC gain, and narrowband filters.
    One application where broadband diode detectors are very useful is measuring
    frequency-translating devices, particularly those with internal LOs.
    1-41
    2000
    Narrowband Detection - Tuned Receiver
    &#1048698; Best sensitivity / dynamic range
    &#1048698; Provides harmonic / spurious signal
    rejection
    power, decreasing IF bandwidth, or
    averaging
    &#1048698; Trade off noise floor and
    measurement speed
    10 MHz 26.5 GHz
    ADC / DSP
    Slide 41
    Tuned receivers provide the best sensitivity and dynamic range, and also provide
    harmonic and spurious-signal rejection. The narrow IF filter produces a considerably
    lower noise floor, resulting in a significant sensitivity improvement. For example, a
    microwave vector network analyzer (using a tuned receiver) might have a 3 kHz IF
    bandwidth, where a scalar analyzer's diode detector noise bandwidth might be 26.5
    GHz. Measurement dynamic range is improved with tuned receivers by increasing
    input power, by decreasing IF bandwidth, or by averaging. The latter two techniques
    provide a trade off between noise floor and measurement speed. Averaging reduces
    the noise floor of the network analyzer (as opposed to just reducing the noise
    excursions as happens when averaging spectrum analyzer data) because we are
    averaging complex data. Without phase information, averaging does not improve
    analyzer sensitivity.
    The same narrowband nature of tuned receivers that produces increased dynamic
    range also eliminates harmonic and spurious responses. As was mentioned earlier,
    the RF signal is downconverted and filtered before it is measured. The harmonics
    associated with the source are also downconverted, but they appear at frequencies
    outside the IF bandwidth and are therefore removed by filtering.
    1-42
    2000
    Comparison of Receiver Techniques
    < -100 dBm Sensitivity
    0 dB
    -50 dB
    -100 dB
    0 dB
    -50 dB
    -100 dB
    -60 dBm Sensitivity
    Broadband
    (diode)
    detection
    Narrowband
    (tuned-receiver)
    detection
    &#1048698; higher noise floor
    &#1048698; false responses
    &#1048698; high dynamic range
    &#1048698; harmonic immunity
    Dynamic range = maximum receiver power -
    receiver noise floor
    Slide 42
    Dynamic range is generally defined as the maximum power the receiver can
    accurately measure minus the receiver noise floor. There are many applications
    requiring large dynamic range. One of the most common is measuring filter stopband
    performance. As you can see here, at least 80 dB dynamic range is needed to properly
    characterize the rejection characteristics of this filter. The plots show a typical
    narrowband filter measured on an 8757 scalar network analyzer and on an 8510
    vector network analyzer. Notice that the filter exhibits 90 dB of rejection but the scalar
    analyzer is unable to measure it because of its higher noise floor.
    In the case where the scalar network analyzer was used with broadband diode
    detection, a harmonic from the source created a "false" response. For example, at
    some point on a broadband sweep, the second harmonic of the source might fall within
    the passband of the filter. If this occurs, the detector will register a response, even
    though the stopband of the filter is severely attenuating the frequency of the
    fundamental. This response from the second harmonic would show on the display at
    the frequency of the fundamental. On the tuned receiver, a false signal such as this
    would be filtered away and would not appear on the display. Note that source
    subharmonics and spurious outputs can also cause false display responses.
    1-43
    2000
    Dynamic Range and Accuracy
    Dynamic range
    is very important
    for measurement
    accuracy!
    Error Due to Interfering Signal
    0.001
    0.01
    0.1
    100
    0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 -55 -60 -65 -70
    Interfering signal (dB)
    Error (dB, deg)
    phase error
    magn error
    Slide 43
    This plot shows the effect that interfering signals (sinusoids or noise) have on
    measurement accuracy. The magnitude error is calculated as 20*log [1 ± interferingsignal]
    and the phase error is calculated as arc-tangent [interfering-signal], where the
    interfering signal is expressed in linear terms. Note that a 0 dB interfering signal
    results in (plus) 6 dB error when it adds in phase with the desired signal, and (negative)
    infinite error when it cancels the desired signal.
    To get low measurement uncertainty, more dynamic range is needed than the device
    exhibits. For example, to get less than 0.1 dB magnitude error and less than 0.6
    degree phase error, our noise floor needs to be more than 39 dB below our measured
    power levels (note that there are other sources of error besides noise that may limit
    measurement accuracy). To achieve that level of accuracy while measuring 80 dB of
    rejection would require 119 dB of dynamic range. One way to achieve this level is to
    average test data using a tuned-receiver based network analyzer.
    1-44
    2000
    T/R Versus S-Parameter Test Sets
    &#1048698; RF always comes out port
    &#1048698; port 2 is always receiver
    &#1048698; response, one-port cal
    available
    &#1048698; RF comes out port 1 or port
    &#1048698; forward and reverse
    measurements
    &#1048698; two-port calibration
    possible
    Transmission/Reflection Test Set
    Port 1 Port 2
    Source
    B
    R
    A
    Fwd DUT
    Port 1 Port 2
    Transfer switch
    Source
    B
    R
    A
    Fwd DUT Rev
    Slide 44
    There are two basic types of test sets that are used with network analyzers. For transmission/reflection
    (T/R) test sets, the RF power always comes out of test port one and test port two is always connected to a
    receiver in the analyzer. To measure reverse transmission or output reflection of the DUT, we must
    disconnect it, turn it around, and re-connect it to the analyzer. T/R-based network analyzers offer only
    response and one-port calibrations, so measurement accuracy is not as good as that which can be
    achieved with S-parameter test sets. However, T/R-based analyzers are more economical. For the 8712,
    8753 and 8720 families, Agilent uses the ET suffix to denote a T/R analyzer, and the ES suffix to denote
    an S-parameter analyzer.
    S-parameter test sets allow both forward and reverse measurements on the DUT, which are needed to
    characterize all four S-parameters. RF power can come out of either test port one or two, and either test
    port can be connected to a receiver. S-parameter test sets also allow full two-port (12-term) error correction,
    which is the most accurate form available. S-parameter network analyzers provide more performance than
    T/R-based analyzers, but cost more due to extra RF components in the test set.
    There are two different types of transfer switches that can be used in an S-parameter test set: solid-state
    and mechanical. Solid-state switches have the advantage of infinite lifetimes (assuming they are not
    damaged by too much power from the DUT). However, they are more lossy so they reduce the maximum
    output power of the network analyzer. Mechanical switches have very low loss and therefore allow higher
    output powers. Their main disadvantage is that eventually they wear out (after 5 million cycles or so). When
    using a network analyzer with mechanical switches, measurements are generally done in single-sweep
    mode, so the transfer switch is not continuously switching.
    S-parameter test sets can have either a 3-receiver (shown on slide) or 4-receiver architecture. The 8753
    series and standard 8720 series analyzers have a 3-receiver architecture. Option 400 adds a fourth
    receiver to 8720 series analyzers, to allow true TRL calibration. The 8510C family uses a 4-receiver
    architecture. More detailed information of the two architecture is available in the appendix.
    1-45
    Network Analyzer Basics Copyright
    2000
    RECEIVER / DETECTOR
    PROCESSOR / DISPLAY
    REFLECTED
    (A)
    TRANSMITTED
    (B)
    INCIDENT
    (R)
    SIGNAL
    SEPARATION
    SOURCE
    Incident
    Reflected
    Transmitted
    DUT
    Processor / Display
    CH1 S21 log MAG 10 dB/ REF 0 dB
    CH1 START 775.000 000 MHz STOP 925.000 000 MHz
    Cor
    Hld
    PRm
    CH2 S12 log MAG 10 dB/ REF 0 dB
    CH2 START 775.000 000 MHz STOP 925.000 000 MHz
    Duplexer Test - Tx-Ant and Ant-Rx
    Cor
    Hld
    PRm
    1_ -1.9248 dB
    839.470 000 MHz
    PASS
    1_ -1.2468 dB
    880.435 000 MHz
    PASS
    &#1048698; markers
    &#1048698; limit lines
    &#1048698; pass/fail indicators
    &#1048698; linear/log formats
    &#1048698; grid/polar/Smith
    charts
    ACTIVE
    CHANNEL
    RESPONSE
    STIMULUS
    ENTRY
    INSTRUMENT
    STATE
    R CHANNEL
    T R L S
    HP-IB STATUS
    NETWORK ANYZER
    50 MH-20GHz
    PORT 1 PORT 2
    Cor
    Hld
    PRm
    Cor
    Hld
    PRm
    1_ -1.9248 dB
    839.470 0 00 MHz
    PASS
    1_ -1.2468 dB
    880.435 0 00 MHz
    PASS
    Slide 45
    The last major block of hardware in the network analyzer is the display/processor
    section. This is where the reflection and transmission data is formatted in ways that
    make it easy to interpret the measurement results. Most network analyzers have
    similar features such as linear and logarithmic sweeps, linear and log formats, polar
    plots, Smith charts, etc. Other common features are trace markers, limit lines, and
    pass/fail testing. Many of Agilent's network analyzers have specialized measurement
    features tailored to a particular market or application. One example is the E5100A/B,
    which has features specific to crystal-resonator manufacturers.
    1-46
    2000
    Internal Measurement Automation
    Simple: recall states
    More powerful:
    &#1048698; Test sequencing
    &#1048708; available on 8753/ 8720
    families
    &#1048708; keystroke recording
    &#1048708; some advanced functions
    &#1048698; IBASIC
    &#1048708; available on 8712 family
    &#1048708; sophisticated programs
    &#1048708; custom user interfaces
    ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789 + - / * = < > ( ) & "" " , . / ? ; : ' [ ]
    1 ASSIGN @Hp8714 TO 800
    2 OUTPUT @Hp8714;"SYSTRES; *WAI"
    3 OUTPUT @Hp8714;"ABOR;:INIT1:CONT OFF;*WAI"
    4 OUTPUT @Hp8714;"DISP:ANN:FREQ1:MODE SSTOP"
    5 OUTPUT @Hp8714;"DISP:ANN:FREQ1:MODE CSPAN"
    6 OUTPUT @Hp8714;"SENS1:FREQ:CENT 175000000 HZ;*WAI"
    7 OUTPUT @Hp8714;"ABOR;:INIT1:CONT OFF;:INIT1;*WAI"
    8 OUTPUT @Hp8714;"DISP:WIND1:TRAC:Y:AUTO ONCE"
    9 OUTPUT @Hp8714;"CALC1:MARK1 ON"
    10 OUTPUT @Hp8714;"CALC1:MARK:FUNC BWID"
    11 OUTPUT @Hp8714;"SENS2:STAT ON; *WAI"
    12 OUTPUT @Hp8714;"SENS2:FUNC 'XFROW:RAT 1,0';DET NBAN; *WAI"
    13 OUTPUT @Hp8714;"ABOR;:INIT1:CONT OFF;:INIT1;*WAI"
    14 OUTPUT @Hp8714;"DISP:WIND2:TRAC:Y:AUTO ONCE"
    15 OUTPUT @Hp8714;"ABOR;:INIT1:CONT ON;*WAI"
    16 END
    Slide 46
    All of Agilent's network analyzers offer some form of internal measurement automation.
    The most simple form is recall states. This is an easy way to set up the analyzer to a
    pre-configured measurement state, with all of the necessary instrument parameters.
    More powerful automation can be achieved with test sequencing or Instrument BASIC
    (IBASIC). Test sequencing is available on the 8753/8720 families and provides
    keystroke recording and some advanced functions. IBASIC is available on the
    8712ET/ES series and provides the user with sophisticated programs and custom user
    interfaces and measurement personalities.
    1-47
    2000
    Agilent’s Series of HF Vector Analyzers
    Microwave
    RF
    8510C series
    &#1048698; 110 GHz in
    coax
    &#1048698; highest
    accuracy
    &#1048698; modular,
    flexible
    &#1048698; pulse systems
    &#1048698; Tx/Rx module
    test
    8720ET/ES series
    &#1048698; 13.5, 20, 40 GHz
    &#1048698; economical
    &#1048698; fast, small, integrated
    &#1048698; test mixers, high-power
    东涛浪子
    积分 3014
    帖子 609
    威望 9674 个
    专家指数 -31
    注册 2010-5-18
    来自 南京
    发表于 2010-07-11 04:34:54  QQ
    这是什么呢 楼主
    unicom_fj
    专家·高级勋章
    积分 158975
    帖子 19406
    威望 3812528 个
    礼品券 54 个
    专家指数 433
    注册 2006-10-27
    发表于 2010-07-12 11:57:02
    学习,学习。。。
    pop456
    积分 1174
    帖子 210
    威望 426357 个
    专家指数 23
    注册 2008-6-12
    发表于 2011-04-26 11:00:55
    E文不好,纯属顶贴。
    fanhuaxing
    积分 130
    帖子 26
    威望 2 个
    注册 2011-3-4
    发表于 2011-04-27 10:16:00
    晕死,全英文,。。。。。
    xfeng128
    积分 280
    帖子 56
    威望 555 个
    注册 2010-12-23
    发表于 2011-05-05 10:07:41
    看的我满眼星星·····
    mainstar
    积分 13408
    帖子 2557
    威望 227962 个
    礼品券 7 个
    专家指数 113
    注册 2006-10-7
    发表于 2011-05-07 08:18:39  QQ
    全部贴进来了阿,有才
    amwyygy11
    积分 800
    帖子 160
    威望 5788 个
    注册 2010-4-11
    发表于 2011-05-07 10:38:17
    顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶
    当前时区 GMT+8, 现在时间是 2026-06-20 16:42:49
    Processed in 0.943589 second(s), 29 queries , Gzip enabled
