资料为英文版,PDF格式,里面包含各种制式的导入工参格式,及使用说明,有需要的可以下载
Contents
1 GETTING STARTED WITH ACTIX ANALYZER .................................................. 5
1.1 ABOUT THIS GUIDE ................................................................................ 5
1.2 INTRODUCING ACTIX ANALYZER ................................................................. 5
1.3 LEARNING ABOUT ANALYZER ..................................................................... 6
1.4 USE THE ONLINE HELP ............................................................................. 7
1.5 CUSTOMER SUPPORT .............................................................................. 8
2 STARTING YOUR SOLUTION .................................................................. 10
3 CONFIGURING ANALYZER .................................................................... 12
3.1 CONFIGURING NETWORK INFORMATION ...................................................... 12
3.1.1 Obtain site data in tabular format ........................................................... 12
3.1.2 Import cell site data ............................................................................. 15
3.1.3 Specify a network information (cellrefs) file ............................................. 19
3.2 MODIFYING THRESHOLD VALUES FOR DETECTING EVENTS ................................. 20
3.3 CONFIGURING HOW DATA IS AGGREGATED ................................................... 20
3.3.1 Change the binning method ................................................................... 21
3.3.2 Specify the message filtering method used when loading data ................... 21
3.4 CONFIGURING MAPS ............................................................................. 22
3.4.1 Set up map backgrounds and layers ....................................................... 22
3.4.2 Change labels for a map layer ................................................................ 23
3.4.3 Change how a map layer is displayed ..................................................... 25
3.4.4 Show Lines to Cells on a map ................................................................ 25
3.4.5 Change the size of cell sectors ............................................................... 27
4 EXAMINING LOADED DATA ................................................................... 28
4.1 THE ANALYZER INTERFACE ...................................................................... 28
4.2 MANAGING DATA ................................................................................. 29
4.2.1 Load data files ..................................................................................... 29
4.2.2 Find and use data in the Attribute Explorer .............................................. 29
4.2.3 Close data files .................................................................................... 31
4.3 SELECTING ANALYSIS OPTIONS ................................................................ 32
4.4 VIEWING SUMMARY DATA FROM STREAMS .................................................... 33
4.4.1 Investigate streams .............................................................................. 33
4.4.2 View data using solution reports ............................................................. 33
4.4.3 View data using the Message Browser ..................................................... 35
4.4.4 View data using the Protocol Stack Browser ............................................. 36
4.5 VIEWING ATTRIBUTE DATA ...................................................................... 37
4.5.1 View data in a Map ............................................................................... 37
4.5.2 Replay the data .................................................................................... 39
4.5.3 View data in a Form .............................................................................. 40
4.5.4 View data in a Chart ............................................................................. 42
4.5.5 View data in a Table ............................................................................. 44
4.5.6 View data in a Workbook ....................................................................... 44
4.5.7 About synchronized data windows .......................................................... 45
4.6 INTEGRATING REVERSE/FORWARD LINK (UPLINK/DOWNLINK) DATA ..................... 46
4.7 CREATING AND USING QUERIES ................................................................ 47
www.actix.com
4.7.1 Create a filter ...................................................................................... 47
4.7.2 Filter the data ...................................................................................... 49
4.8 GENERATING NEW REPORTS .................................................................... 50
4.9 LOADING LARGE AMOUNTS OF DATA WITH REPOSITORY MANAGER ....................... 52
4.9.1 Create a new Repository ....................................................................... 53
4.9.2 Open a Repository ................................................................................ 54
4.9.3 Load data into a Repository ................................................................... 55
4.9.4 Display the list of files loaded in a Repository ........................................... 56
4.9.5 Close a Repository ................................................................................ 56
4.9.6 Delete a Repository .............................................................................. 57
4.9.7 Manage Repository templates ................................................................ 57
APPENDIX: CELL SITE PARAMETERS FOR IMPORT ............................................ 59
CDMA .................................................................................................. 59
GSM / GPRS / EDGE ............................................................................... 60
IDEN .................................................................................................... 61
LTE ...................................................................................................... 62
UMTS / HSPA+ ...................................................................................... 63
IMPORTING MULTIPLE TECHNOLOGIES .............................................................. 64
INDEX ............................................................................................ 65
