  • 阅读:4312
  • 回复:5
Actix Analyzer Getting Started Guide June 2010
hzxy0732
公益·慈善勋章   纪念勋章·八周年
积分 1684
帖子 358
威望 10092 个
礼品券 375 个
专家指数 -106
注册 2009-11-26
来自 汉中
发表于 2011-10-17 02:45:42  只看楼主  QQ
资料为Actix原版的英文PDF资料,包括各种制式技术的工参格式,有需要的可以下载。
Contents
1 GETTING STARTED WITH ACTIX ANALYZER .................................................. 5
1.1 ABOUT THIS GUIDE ................................................................................ 5
1.2 INTRODUCING ACTIX ANALYZER ................................................................. 5
1.3 LEARNING ABOUT ANALYZER ..................................................................... 6
1.4 USE THE ONLINE HELP ............................................................................. 7
1.5 CUSTOMER SUPPORT .............................................................................. 8
2 STARTING YOUR SOLUTION .................................................................. 10
3 CONFIGURING ANALYZER .................................................................... 12
3.1 CONFIGURING NETWORK INFORMATION ...................................................... 12
3.1.1 Obtain site data in tabular format ........................................................... 12
3.1.2 Import cell site data ............................................................................. 15
3.1.3 Specify a network information (cellrefs) file ............................................. 19
3.2 MODIFYING THRESHOLD VALUES FOR DETECTING EVENTS ................................. 20
3.3 CONFIGURING HOW DATA IS AGGREGATED ................................................... 20
3.3.1 Change the binning method ................................................................... 21
3.3.2 Specify the message filtering method used when loading data ................... 21
3.4 CONFIGURING MAPS ............................................................................. 22
3.4.1 Set up map backgrounds and layers ....................................................... 22
3.4.2 Change labels for a map layer ................................................................ 23
3.4.3 Change how a map layer is displayed ..................................................... 25
3.4.4 Show Lines to Cells on a map ................................................................ 25
3.4.5 Change the size of cell sectors ............................................................... 27
4 EXAMINING LOADED DATA ................................................................... 28
4.1 THE ANALYZER INTERFACE ...................................................................... 28
4.2 MANAGING DATA ................................................................................. 29
4.2.1 Load data files ..................................................................................... 29
4.2.2 Find and use data in the Attribute Explorer .............................................. 29
4.2.3 Close data files .................................................................................... 31
4.3 SELECTING ANALYSIS OPTIONS ................................................................ 32
4.4 VIEWING SUMMARY DATA FROM STREAMS .................................................... 33
4.4.1 Investigate streams .............................................................................. 33
4.4.2 View data using solution reports ............................................................. 33
4.4.3 View data using the Message Browser ..................................................... 35
4.4.4 View data using the Protocol Stack Browser ............................................. 36
4.5 VIEWING ATTRIBUTE DATA ...................................................................... 37
4.5.1 View data in a Map ............................................................................... 37
4.5.2 Replay the data .................................................................................... 39
4.5.3 View data in a Form .............................................................................. 40
4.5.4 View data in a Chart ............................................................................. 42
4.5.5 View data in a Table ............................................................................. 44
4.5.6 View data in a Workbook ....................................................................... 44
4.5.7 About synchronized data windows .......................................................... 45
4.6 INTEGRATING REVERSE/FORWARD LINK (UPLINK/DOWNLINK) DATA ..................... 46
4.7 CREATING AND USING QUERIES ................................................................ 47
www.actix.com
4.7.1 Create a filter ...................................................................................... 47
4.7.2 Filter the data ...................................................................................... 49
4.8 GENERATING NEW REPORTS .................................................................... 50
4.9 LOADING LARGE AMOUNTS OF DATA WITH REPOSITORY MANAGER ....................... 52
4.9.1 Create a new Repository ....................................................................... 53
4.9.2 Open a Repository ................................................................................ 54
4.9.3 Load data into a Repository ................................................................... 55
4.9.4 Display the list of files loaded in a Repository ........................................... 56
4.9.5 Close a Repository ................................................................................ 56
4.9.6 Delete a Repository .............................................................................. 57
4.9.7 Manage Repository templates ................................................................ 57
APPENDIX: CELL SITE PARAMETERS FOR IMPORT ............................................ 59
CDMA .................................................................................................. 59
GSM / GPRS / EDGE ............................................................................... 60
IDEN .................................................................................................... 61
LTE ...................................................................................................... 62
UMTS / HSPA+ ...................................................................................... 63
IMPORTING MULTIPLE TECHNOLOGIES .............................................................. 64
INDEX ............................................................................................ 65
2011-10-17 02:45:42  下载次数: 87
Actix Analyzer Getting Started Guide June 2010.pdf (2.44 MB)
    Love Communication!
    kaiter
    C友·登录达人   纪念勋章·六周年   纪念勋章·九周年   纪念勋章·十周年
    积分 15680
    帖子 1905
    威望 1194578 个
    礼品券 103 个
    专家指数 329
    注册 2006-7-5
    发表于 2011-11-04 08:34:14
    67页的资料,没有中文,就当学习英文的资料了.
    wkfzxt
    积分 180
    帖子 36
    威望 378 个
    注册 2011-11-4
    发表于 2011-11-04 20:44:35
    这是什么东东啊 ?
    张建立
    积分 327
    帖子 92
    威望 1551 个
    专家指数 -133
    注册 2010-10-12
    发表于 2011-11-10 16:59:28  QQ
    看的多拉就懂拉,路是人走出来的呵呵
    ysoanne
    积分 1062
    帖子 202
    威望 49334 个
    注册 2008-2-1
    来自 台灣
    发表于 2012-02-18 17:03:19  QQ
    thank for your sharing
    zhongshunqi
    积分 4491
    帖子 529
    威望 6663 个
    专家指数 -27
    注册 2007-2-5
    来自 广州
    发表于 2013-05-08 20:56:46  QQ
    说明资料很全,非常感谢LZ的分享!
    你快乐我也快乐中,沟通从心开始!
    当前时区 GMT+8, 现在时间是 2026-05-04 00:32:33
    Processed in 0.613322 second(s), 26 queries , Gzip enabled
