核心网技术专区
» IP Address Change for Windows Server 2003
祭祀残念
积分 4107
帖子 199
威望 11659 个
注册 2008-6-14
发表于 2011-11-30 09:57:57
IP Address Change of Windows Server 2003
Contents
1 Introduction.....................................................................................2
2 Preliminary......................................................................................2
2.1 Prerequisites...................................................................................2
3 Procedure.......................................................................................2
3.1 Overview.........................................................................................2
3.2 Change the Passive node IP address............................................3
3.3 Change the Cluster IP address.......................................................4
3.4 Change the Active Node IP address...............................................5
3.5 Check the new Cluster IP address.................................................5
3.6 Check the second node’s IP address.............................................6
3.7 Shutdown the passive node............................................................6
3.8 Reboot active node.........................................................................6
3.9 Check cluster resource online, and then reset the other node.......6
3.10 Check all cluster resource online....................................................6
3.11 Backup the APG40.........................................................................6
4 References.....................................................................................6
2011-11-30 09:57:57 下载次数: 17
IP Address Change for Windows Server 2003.pdf
(169.47 KB)
Evo Controller 8100_BSC Hardware
2012-05-04
User guide for APM, APG40
2012-02-02
xcj9811
积分 43291
帖子 5393
威望 114090 个
注册 2007-6-21
来自 shandong
发表于 2011-11-30 10:55:34
招聘的板块不行了是吗?
在线,37天前提问
招聘的板块不行了是吗?
在线,37天前提问
招聘的板块不行了是吗?
在线,37天前提问
在线,59天前提问
在线,67天前提问
在线,67天前提问
在线,167天前提问
在线,197天前提问
在线,362天前提问
在线,397天前提问
在线,461天前提问
在线,498天前提问
在线,547天前提问
在线,556天前提问
在线,585天前提问
在线,608天前提问
computer question!!!! out !!
qing07
积分 1384
帖子 95
威望 776 个
注册 2007-3-8
发表于 2011-12-27 00:18:08
谢谢楼主的分享....
有个性,我喜欢~~~
当前时区 GMT+8, 现在时间是 2026-08-18 22:40:40
Processed in 0.867305 second(s), 17 queries , Gzip enabled
