  • 阅读:8357
ZTE PTN6200
yanchangyi
积分 637
帖子 80
威望 8798 个
专家指数 -16
注册 2009-5-23
发表于 2011-11-30 11:58:26  只看楼主
username who password who privilege 1
username zte password ecc privilege 15
username ptn password ptn privilege 1
hostname gaog
show username
multi-user configure
snmp-server view AllView internet included
snmp-server community public view AllView ro
snmp-server community private view AllView rw
snmp-server host 193.29.255.109 trap version 2c public udp-port 162
snmp-server trap-source 193.29.74.254
snmp-server packetsize 8192
snmp-server enable trap SNMP
snmp-server enable trap VPN
snmp-server enable trap BGP
snmp-server enable trap OSPF
snmp-server enable trap RMON
snmp-server enable trap STALARM
logging on
logging trap-enable informational
clock timezone BEIJING 8
line telnet idle-timeout 30
line telnet absolute-timeout 0
interface lct_5/4
ip address 192.192.192.11 255.255.255.0
exit
interface loopback1
ip address 193.29.74.254 255.255.255.255
exit
tmpls lsr-id loopback1
interface gei_1/1
mcc-vlanid 3570
switchport mode trunk
switchport trunk vlan 1290
switchport trunk native vlan 1290
exit
interface vlan 1290
ip address 193.29.74.2 255.255.255.252
exit
router ospf 1
network 193.29.74.0 0.0.0.3 area 0
network 193.29.74.254 0.0.0.0 area 0
exit
    123321好的
    纪念勋章·六周年
    积分 1589
    帖子 334
    威望 13709 个
    专家指数 -81
    注册 2012-3-6
    发表于 2012-06-26 15:59:57
    呵呵中 ...这不是开PTN所用的....什么吗
    1screw1
    威望 46 个
    注册 2012-8-3
    发表于 2012-08-03 21:21:07
    这个还是老版本的,新的加了
    interface gei_1/1'对各个端口的默认VLAN进行隔离,这里是满配置,现场需根据实际情况进行选择配置‘
    switchport access vlan2
    exit
    interface gei_2/1'对所有端口进行未知组播,未知单播限速,限制带宽为500kbps,对承载的业务类型为广播或者组播业务,需要打开限速设置‘
    qos storm-control broadcast rate 500 burst-size 4
    qos storm-control unicast-dlf rate 500 burst-size 4
    qos storm-control unknown-multicast rate 500 burst-size 4
    exit
    当前时区 GMT+8, 现在时间是 2026-07-10 09:34:34
    Processed in 0.895602 second(s), 19 queries , Gzip enabled
