  • 阅读:5234
forlopp问题
youfeng
C友·登录达人   纪念勋章·九周年   纪念勋章·十周年
积分 35383
帖子 4449
威望 86779 个
礼品券 98 个
专家指数 528
注册 2006-9-20
发表于 2012-02-23 16:52:50  只看楼主
关于FLERROR一项ALEX的描述如下:
The FLERROR status for a specific block should only be changed to OFF in case a fault in the implementation of the Application Detected Error Reporting functionality has been found in the block. A maximum of 16 blocks are allowed to have the FLERROR status set to OFF simultaneously
这个开关(ON/OFF)还能指定BLOCK?还是我理解的有问题呢?
    丝竹轻唱
    积分 725
    帖子 120
    威望 6810 个
    礼品券 100 个
    专家指数 24
    注册 2009-7-6
    发表于 2012-05-18 11:28:53
    貌似可以,在TEST ONE 中有段话:
    When FLSTATUS is set to ACTIVE, FLSTATUS is changed for blocks
    that include forlopp handling and where the block permits change of its
    FLSTATUS by using a command.
    我理解就是有的block 的forlopp可以active,有的不行
    youfeng
    积分 35383
    帖子 4449
    威望 86779 个
    礼品券 98 个
    专家指数 528
    注册 2006-9-20
    发表于 2012-05-18 15:08:49  只看楼主
    哦,谢谢,但是如何设置呢?
    当前时区 GMT+8, 现在时间是 2026-08-18 22:40:10
    Processed in 0.363530 second(s), 18 queries , Gzip enabled
