DT测试分析·软件使用·工程模式
» RNOPOS 2.2软件 2008-10-21
fmstero
积分 3488
帖子 295
威望 34171 个
专家指数 102
注册 2006-10-29
发表于 2012-04-17 23:48:43
RNO Post Processing7Tool
Version: 2.2 (Build 2008-10)
Platform: Windows 95/98/ME/NT/2000/XP/2003.
RNO Post Processing Tool is a TRIAL Free SOFTWARE.
The author shall have no liability for any error or
damages of any kind resulting from the use of
this software.
-=User Guide=-
RNOPOS can parse Ericsson BSC R10/R12/07A RNO raw files(Binary
format),which is useful to radio engineers in network
optimization
There are 2 major functions of this tools:
1). Convert RNO raw files(MRRFIL,RIRFIL,BARFIL) to
Microsoft Access database(.mdb) format
2). Display the line chart as well as the bar chart
for the MRR or RIR measurement data
To use it,
First click on the corresponding option box in the main
interface of the tool. Then select the "Convert" menu
item to choose RNO raw file to convert.
Or select "open" button which is also in the main interface
of the tool. Then press the "Show Chart" button to display
the chart data
Also you can select the "SetData" menu item to do some
settings, note this option is only valid for BARFIL
parsing.
-=Limitation=-
1.Bugs may exist.
2.Features to be implmented
1).Chart display feature needs to be improved
2).PMR raw file decoding
3).stats. on the whole BSC
4)...
-=Note=-
None
-=History=-
2008-10-21RNOPOS 2.2
1). Bugs fixed:In NCS processing part, on close window"Cell DATA"
2008-5-16RNOPOS 2.1
1). Minor update:max 65535 number of lines in BAR raw file supported
2008-4-29RNOPOS 2.0
1). Minor update:TextBox(in main window) property is changed on scrollbar option
2012-4-17 23:48:43 下载次数: 65
RNOPOS_2.2.rar
(115.02 KB)
微软PowerMap的国内经纬度转换工具
2016-11-02
EXCQL-基于EXCEL的通信后台大数据分析和处理工具
2016-11-02
CSFB相关信令流程
2014-04-14
用RAMDISK为笔记本提速!!!
2013-11-06
华为RNC820辅助工具,有问题或者建议请直接联系:rnprno@139.com。
2013-11-05
GSM System Survey
2013-04-08
q2080069
积分 964
帖子 189
威望 3145 个
专家指数 19
注册 2010-11-24
发表于 2012-05-16 08:59:03
在线,9天前提问
在线,17天前提问
在线,17天前提问
在线,116天前提问
在线,147天前提问
在线,311天前提问
在线,346天前提问
在线,411天前提问
在线,447天前提问
在线,497天前提问
在线,506天前提问
在线,534天前提问
在线,558天前提问
在线,565天前提问
在线,583天前提问
在线,612天前提问
牛人啊.求拜师
wdj3002
积分 2737
帖子 523
威望 21721 个
专家指数 -334
注册 2008-5-24
发表于 2012-05-17 11:19:41
percentile value should be an integer in the rangeof 500 to 1000
老是提示这个,不给用啊。明明percentile 默认是900的。楼主好人,能帮我吗
RNOPOS_2.2.rar
当前时区 GMT+8, 现在时间是 2026-06-29 14:51:52
Processed in 0.323150 second(s), 19 queries , Gzip enabled
