  • 阅读:14374
卡特G网中 Cause22: 太短距离切换 是什么意思呢?
wweinano
专家·高级勋章
积分 20030
帖子 856
威望 23846 个
礼品券 218 个
专家指数 412
注册 2009-3-19
发表于 2012-08-27 10:31:29  只看楼主
如题,Cause22: 太短距离切换为什么要触发这个原因的切换呢?
counter 解释为
Number of inter-cell internal or external handovers attempts, with cause 22: "too short MS-BTS distance" on a
TCH channel (in HR or FR usage). Only the outer zones of extended cells are concerned by this counter.
Trigger condition:
Whenever 44.018HANDOVER COMMAND is sent to the mobile via the BTS because of cause 22 on TCH.
This counter is incremented in the serving cell.
Note: This counter counts both inter-PLMN and intra-PLMN handover events.
意思是这个切换和 扩展小区有关?
求解释!
    <font size="10">我就喜欢-->MSCBSC
    wweinano
    专家·高级勋章
    积分 20030
    帖子 856
    威望 23846 个
    礼品券 218 个
    专家指数 412
    注册 2009-3-19
    发表于 2012-08-28 11:44:29  只看楼主
    没人
    当前时区 GMT+8, 现在时间是 2026-04-18 05:02:47
    Processed in 0.406015 second(s), 14 queries , Gzip enabled
