WLAN技术区
» H3C S3100 series (8口)交换机不能手动开启poe功能
[讨论]
blackdog
积分 3020
帖子 598
威望 12915 个
专家指数 30
注册 2010-1-20
发表于 2012-09-26 23:45:28
各位大侠,偶最近配到一个难题,
H3C 3100
口交换在断电之后,所有端口
poe
均无法手动开启,很是无奈!之前请教过
H3C
厂家的工程师,他只给我一句话
升级!然后
现来此跪求大侠们指导一二,如果是要升级,麻烦教教小弟,该交换机的详细升级步骤当然还需要相应的升级程序;如果不是,大家一起看看,找找原因,共同提高,不胜感激!好了,废话不多说了,我把该交换机的前后配置数据放在下面,大家对比对比:
之前配置如下:
vlan 1
vlan 106
vlan 3535 to 3536
interface Vlan-interface106
ip address 172.27.10.16 255.255.255.0
interface Aux1/0/0
interface Ethernet1/0/1
port link-type trunk
undo port trunk permit vlan 1
port trunk permit vlan 106 3535
interface Ethernet1/0/2
poe enable
port access vlan 3535
port isolate
interface Ethernet1/0/3
poe enable
port isolate
interface Ethernet1/0/4
poe enable
port isolate
interface Ethernet1/0/5
poe enable
port isolate
interface Ethernet1/0/6
poe enable
port isolate
interface Ethernet1/0/7
poe enable
port isolate
interface Ethernet1/0/8
poe enable
port isolate
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
shutdown
interface NULL0
management-vlan 106
user-interface aux 0
user-interface vty 0 4
authentication-mode scheme
Return
现在显示在该交换机的配置:
vlan 1
vlan 106
vlan 3535 to 3536
interface Aux1/0/0
port isolate
port isolate
port isolate
port isolate
port isolate
port isolate
port isolate
shutdown
interface NULL0
management-vlan 106
return
以下是本人手动开启各个端口的
poe
,显示如下:
[hanchuan-fuxingkeji'1]int Ethernet 1/0/2
[hanchuan-fuxingkeji'1-Ethernet1/0/2]poe enable
PoE is not supported on the port!
[hanchuan-fuxingkeji'1-Ethernet1/0/3]poe enable
[hanchuan-fuxingkeji'1-Ethernet1/0/3]int Ethernet 1/0/4
[hanchuan-fuxingkeji'1-Ethernet1/0/4]poe enable
[hanchuan-fuxingkeji'1-Ethernet1/0/4]int Ethernet 1/0/5
[hanchuan-fuxingkeji'1-Ethernet1/0/5]poe enable
[hanchuan-fuxingkeji'1-Ethernet1/0/5]int Ethernet 1/0/6
[hanchuan-fuxingkeji'1-Ethernet1/0/6]poe enable
[hanchuan-fuxingkeji'1-Ethernet1/0/6]int Ethernet 1/0/7
[hanchuan-fuxingkeji'1-Ethernet1/0/7]poe enable
[hanchuan-fuxingkeji'1-Ethernet1/0/7]int Ethernet 1/0/8
[hanchuan-fuxingkeji'1-Ethernet1/0/8]poe enable
关于H3C 交换机经常自动关闭端口POE
2012-02-11
看看别个语文学的几好!
2010-05-17
(转)看你会说不会说
2010-05-10
兄弟姐妹们,大家想要世博年勋章不?
2010-03-31
【我想对你说】 通信流浪歌(哥)
2010-03-29
莫问前尘有愧,但求今生无悔!
blackdog
积分 3020
帖子 598
威望 12915 个
专家指数 30
注册 2010-1-20
发表于 2012-09-27 23:44:52
招聘的板块不行了是吗?
在线,45天前提问
招聘的板块不行了是吗?
在线,45天前提问
招聘的板块不行了是吗?
在线,45天前提问
因为系统原因导致的中断,系统能自动7赎回处理吗
在线,67天前提问
在线,76天前提问
在线,76天前提问
在线,175天前提问
在线,205天前提问
在线,370天前提问
在线,405天前提问
在线,469天前提问
在线,506天前提问
在线,555天前提问
在线,564天前提问
在线,593天前提问
在线,616天前提问
为毛还木有人回答啊高手在哪里 大虾在哪里啊
莫问前尘有愧,但求今生无悔!
httaojin
积分 145
帖子 29
威望 1343 个
注册 2012-8-28
发表于 2012-10-01 21:51:53
电源模块坏了,换新的
httaojin
积分 145
帖子 29
威望 1343 个
注册 2012-8-28
发表于 2012-10-01 21:52:34
或者删除配置,重启,重新配置
blackdog
积分 3020
帖子 598
威望 12915 个
专家指数 30
注册 2010-1-20
发表于 2012-10-02 19:08:00
楼上的兄弟你确定是电源模块坏了吗?如果是的话,为什么厂家的人说升级也可以解决问题 呢?
还有根本就没有新的给你换!!!
所以,我就想自己来试试能不能自己找办法解决;
如果你说的第二种方法可行的话,我休完假后可以试试!
莫问前尘有愧,但求今生无悔!
blackdog
积分 3020
帖子 598
威望 12915 个
专家指数 30
注册 2010-1-20
发表于 2012-10-10 21:43:19
难道木有人知道怎么搞 求解救啊
莫问前尘有愧,但求今生无悔!
rekerch
积分 289
帖子 37
威望 1352 个
注册 2008-11-18
发表于 2012-11-29 17:51:08
我也碰到了,求高手指点。据说(引用网友回复)
你打 poe enable
提示POE在次设备不支持的英文吗? 还是你连POE ENABLE命令都打不上?
如果是前者告诉你POE模块坏了,如果是后者 升级最新.BIN文件
再告诉你个方法:如果是前者,你可以手工灌入.S19文件,然后可能支持POE 功能,但这个方法一般交换机断电重启后失效,归根到底还是POE模块坏了。S3100 这种交换机POE模块坏的很多,也没什么大不了的,最好申请备件
blackdog
积分 3020
帖子 598
威望 12915 个
专家指数 30
注册 2010-1-20
发表于 2012-12-07 22:24:28
请问怎么手动灌入.S19文件
莫问前尘有愧,但求今生无悔!
[讨论] H3C S3100 series (8口)交换机不能手动开启poe功能" tabindex="1">
当前时区 GMT+8, 现在时间是 2026-08-27 09:03:48
Processed in 1.186601 second(s), 25 queries , Gzip enabled
