  • 阅读:3107
  • 回复:5
[求助] 一段交换内配置忘高手指导一二
blackpearl
积分 1477
帖子 321
威望 1938 个
专家指数 -128
注册 2010-7-22
发表于 2012-09-29 16:41:33  只看楼主
贴一段交换内配置麻烦高手给解疑下:
全部配置:
[SDQDA-WLAN-SW-JSDS-1-S2300]display cur
!Software Version V100R005C01
sysname SDQDA-WLAN-SW-JSDS-1-S2300
vlan batch 1 7 1159 2555
l2protocol-tunnel user-defined-protocol dot1x protocol-mac 0180-c200-0003 group-mac 0100-0000-0000
cluster enable
ntdp enable
ntdp hop 16
ndp enable
bpdu enable
dhcp enable
undo http server enable
drop illegal-mac alarm
acl number 2000
rule 0 permit source 211.137.179.36 0
rule 1 permit source 211.137.179.40 0
rule 2 deny
acl number 3000
rule 0 permit ip source 172.16.0.0 0.0.255.255
rule 1 deny ip
aaa
authentication-scheme default
authorization-scheme default
accounting-scheme default
domain default
domain default_admin
local-user admin password simple admin
local-user admin service-type http
local-user sunqiang13963919107 password cipher PI6a`&-8+#-H;C/!R%=1I!!!
local-user sunqiang13963919107 privilege level 3
local-user sunqiang13963919107 ftp-directory flash:
local-user sunqiang13963919107 service-type telnet
interface Vlanif7 ap的管理vlan
interface Vlanif2555交换机的管理vlan
ip address 172.16.6.34 255.255.255.224
交换机的管理地址
interface Ethernet0/0/1
port hybrid pvid vlan 7设置缺省vlan7
undo port hybrid vlan 1
华为交换机Hybrid端口的缺省VLAN默认为VLAN 1;
port hybrid tagged vlan 2 to 6 8 to 4094
port hybrid untagged vlan 7
l2protocol-tunnel user-defined-protocol dot1x enable
ntdp enable
ndp enable
port-isolate enable group 1端口隔离
interface Ethernet0/0/2
ntdp enable
ndp enable
interface Ethernet0/0/3
ntdp enable
ndp enable
interface Ethernet0/0/4
ntdp enable
ndp enable
interface Ethernet0/0/5
ntdp enable
ndp enable
interface Ethernet0/0/6
ntdp enable
ndp enable
interface Ethernet0/0/7
ntdp enable
ndp enable
interface Ethernet0/0/8
ntdp enable
ndp enable
interface GigabitEthernet0/0/1
description to SDQDA-WLAN-XSX-SW3900
port link-type trunk
undo port trunk allow-pass vlan 1
port trunk allow-pass vlan 7 1159 2555
ntdp enable
ndp enable
interface NULL0
ip route-static 0.0.0.0 0.0.0.0 172.16.6.33
snmp-agent
snmp-agent local-engineid 7007302117
snmp-agent community readSDm0bile acl 2000
snmp-agent sys-info location SDQDA-WLAN-SW-LNDY-1
snmp-agent sys-info version all
snmp-agent target-host trapaddress udp-domain 211.137.179.36 params securityname QDYD
user-interface con 0
user-interface vty 0 4
acl 3000 inbound
authentication-mode aaa
idle-timeout 15 0
return
问题1
设置缺省vlan7
ntdp enable
ndp enable
端口隔离
为啥要将ap管理vlan设为pvid,而且还是untagged;假如ap的管理报文进入交换机端口,由于pvid在允许范围内,端口接受报文;转发时管理报文vlan idpvid,设置为untagged,剥离vlan id转发到各个端口?是这样么?有何意义?
ntdp enable
ndp enable
问题2
上联3900交换机端口G0/0/1pvid为缺省值=1?当接受报文时,比如ap管理报文,到G0/0/1口时已不带tagpvid=1,打上vlan id=1的标签进入端口,但是端口设置不允许vlan1的报文通过!!
    qshyj
    C友·贡献勋章   纪念勋章·九周年   纪念勋章·十周年
    积分 6329
    帖子 756
    威望 21400 个
    礼品券 999 个
    专家指数 2447
    注册 2009-7-3
    发表于 2012-09-30 09:29:17
    好长呀,眼睛看花了
    时刻准备着!!!
    xs3226325
    积分 931
    帖子 164
    威望 1506 个
    专家指数 111
    注册 2011-1-12
    来自 湖南
    发表于 2012-10-10 16:26:54
    需要高手来解答的问题
    callusman
    威望 40 个
    注册 2012-10-15
    发表于 2012-10-15 16:23:47
    问题1:技术能力一般的厂家,ap出来的报文不支持带tag。另外交换机收到untag的报文,是以pvlan来打标签的,只在vlan内广播。你最好画个图出来看看。
    问题2:G0/0/1只允许三个vlan呀。
    sxx0064
    威望 106 个
    注册 2011-6-28
    发表于 2012-10-18 18:40:46
    问题1:
    交换机使用的port type为 hybrid(不懂百度一下吧 ) 这类型的接口既能为终端打tag 也能给终端Untag。
    如楼主的配置,当端口接的是终端设备,终端收到的数据报文经过该端口时,当报文头为VLANid 7时,端口剥掉TAG头,终端就可以使用剥掉TAG头的数据包;当报文头不为VLANid 7时,终端会丢弃不为VLANid 7的报文。
    反向,终端通过该端口发送数据报文时,数据包经过端口时,端口会给该数据包打上VLANid 7的报文头,数据包就在VLAN7里面广播。
    当端口接的是交换设备,且对端交换设备配置类型与该端口类型差不多(trunk或者hybrid)时,tag的数据包(2to6 8to4094)可通过该端口转发到对端设备,而PVid 7的包经过该口的数据包,被剥离报文头,形成一个不带报文头的数据包,转发至对端设备。
    为什么配成 PVid呢,只是因为 hybrid 的配置方法就定了 配置成PVID。而不象
    port link-type access
    port default vlan 7
    这种配置方法。
    这种类型的端口,应该也常用于WLAN的本地转发模式下,用户的业务数据通过tag在业务VLAN中广播,而AP的管理数据通过untag直接与AC相关联。另,集中转发使用这类型的端口,也没啥问题。
    问题2:
    交换机一般 trunk 或者 tag时,默认会把 VLAN 1的加上。该上联口仅允许 7 1159 2555 三个VLANID的数据报文通过。
    undo port trunk allow-pass vlan 1 是把默认trunk VLAN 1删除…… 并没有说上联3900交换机端口G0/0/1,pvid为缺省值=1啊……
    a50691356
    积分 335
    帖子 67
    威望 5325 个
    注册 2009-12-26
    发表于 2012-11-02 14:46:58
    标题 [求助] 一段交换内配置忘高手指导一二" tabindex="1">
    当前时区 GMT+8, 现在时间是 2026-08-27 09:03:26
    Processed in 1.288469 second(s), 19 queries , Gzip enabled
