  • 阅读:6438
ACM 消息详细解释及应用情况
fusufusu
积分 55
威望 1080 个
注册 2010-8-6
发表于 2015-06-23 23:30:23  只看楼主
经过初步了解。ACM主要就分几个部分。1,后向指示语
2,可选后向指示语
3,原因值
......address-complete
........backward-call-indicators
..........backward-call-indicators-ITUT
32> 02------10............charge-indicator:charge (2)
----00--............called-partys-status-indicator:no-indication (0)
--00----............called-partys-category-indicator:no-indication (0)
00------............end-to-end-method-indicator:no-end-to-end-method-available (0)
33> 04-------0............interworking-indicator:no-interworking-encountered (0)
------0-............end-to-end-information-indicator:no-end-to-end-information-available (0)
-----1--............iSDN-user-part-indicator:isdn-user-part-used-all-the-way (1)
----0---............holding-indicator:holding-not-requested (0)
---0----............isdn-access-indicator:terminating-access-non-ISDN (0)
--0-----............echo-control-device-indicator:incoming-echo-control-device-not-included (0)
00------............sccp-method-indicator:no-indication (0)
........offset
34> 0100000001 *
........optional-part
35> 2900101001 T
36> 0100000001 L
..........optional-backward-call-indicators
............optional-backward-call-indicators-ITUT
37> 01-------1..............in-band-information-indicator:in-band-information-or-an-appropriate-pattern-is-now-available (1)
------0-..............call-diversion-may-occur-indicator:no-indication (0)
-----0--..............simple-segmentation-indicator:no-additional-information-will-be-sent (0)
----0---..............mlpp-user-indicator:no-indication (0)
---0----..............spare:0x0 (0)
--0-----..............ctm:no-indication (0)
00------..............reserved-for-national-use:0x0 (0)
38> 1200010010 T
39> 0200000010 L
..........cause-indicators
............cause
40> E21-------..............ext1:0x1 (1)
..............coding-standard
-11-----................coding-standard-ITUT:reserved-for-other-international-standards1 (3)
..............location
----0010................location-ITUT:public-network-serving-the-local-user (2)
41> 841-------..............ext2:0x1 (1)
..............cause-value
-0000100................cause-value-ITUT:send-special-information-tone (4)
42> 0000000000 T
..........end-of-optional-parameters:NULL
大致应该就这些吧。
1,后向指示语是必有的,里面包含用户状态,回声抑制等状态。
2,可选后向指示语,分情况有或没有。 里面包含语音指示等。
3,原因值也是分情况有或没有。包含失败原因值等。
各位专家,我就是不明白都是什么情况下,这些内容有或者没有呢。
例如,用户关机,那么回复的ACM里到底应该有什么呢。
(第37行的in-band-information-or-an-appropriate-pattern-is-now-available (1)是不是说给主叫放关机音呢)
(第41行的send-special-information-tone (4)是不是说让主叫局再次放音呢。)
他娘的,到底啥意思啊。找不到信令详解的资料啊想哭。。。
    显示异常
    积分 27129
    帖子 5414
    威望 225706 个
    礼品券 51 个
    专家指数 59
    注册 2015-3-30
    来自 山东淄博
    发表于 2015-06-24 08:25:42  QQ
    “大致就这些吧”,感觉楼主像是在估摸着解释呢
    活到老学到老
    当前时区 GMT+8, 现在时间是 2026-08-18 22:39:26
    Processed in 0.404790 second(s), 17 queries , Gzip enabled
