  • 阅读:4365
4G(LTE)网络中有关Sidelink信息广播
威望 1813255 个
发表于 2020-12-05 11:09:10  只看楼主
        自3GPP R12版本开始,4G(LTE)网络就开启了Sidelink([url]https://club.mscbsc.com/t707661p1.html[/url])功能;为支持该功能4G网络通过系统消息Sib18和Sib19进行传递,其具体内容如下:
1.Sib18(Sidelink Information)--网络侧
        SystemInformationBlockType18-r12 ::= SEQUENCE {
            commConfig-r12 SEQUENCE {
                commRxPool-r12                                         SL-CommRxPoolList-r12,
                commTxPoolNormalCommon-r12                     SL-CommTxPoolList-r12 OPTIONAL, -- Need OR
                commTxPoolExceptional-r12                          SL-CommTxPoolList-r12 OPTIONAL, -- Need OR
                commSyncConfig-r12                                   SL-SyncConfigList-r12 OPTIONAL -- Need OR
            } OPTIONAL, -- Need OR
            lateNonCriticalExtension                                   OCTET STRING OPTIONAL,            ...,
            [[ commTxPoolNormalCommonExt-r13                  SL-CommTxPoolListExt-r13 OPTIONAL, -- Need OR
                commTxResourceUC-ReqAllowed-r13               ENUMERATED {true} OPTIONAL, -- Need OR
                commTxAllowRelayCommon-r13                      ENUMERATED {true} OPTIONAL -- Need OR
2.SIB 19sidelink UE information procedure and may contain sidelink discovery related resource configuration information--终端侧
           SystemInformationBlockType19-r12 ::= SEQUENCE {
           discConfig-r12 SEQUENCE {
           discRxPool-r12                                      SL-DiscRxPoolList-r12,
           discTxPoolCommon-r12                           SL-DiscTxPoolList-r12 OPTIONAL, -- Need OR
           discTxPowerInfo-r12                              SL-DiscTxPowerInfoList-r12 OPTIONAL, -- Cond Tx
           discSyncConfig-r12                                SL-SyncConfigList-r12 OPTIONAL -- Need OR
           discInterFreqList-r12                                     SL-CarrierFreqInfoList-r12 OPTIONAL, -- Need OR
           lateNonCriticalExtension                                 OCTET STRING OPTIONAL,...,
           [[ discConfig-v1310 SEQUENCE {
           discInterFreqList-v1310                  SL-CarrierFreqInfoList-v1310 OPTIONAL, -- Need OR
           gapRequestsAllowedCommon            ENUMERATED {true} OPTIONAL -- Need OR
           discConfigRelay-r13 SEQUENCE {
           relayUE-Config-r13                         SL-DiscConfigRelayUE-r13,
           remoteUE-Config-r13                      SL-DiscConfigRemoteUE-r13
           discConfigPS-13 SEQUENCE {
           discRxPoolPS-r13                           SL-DiscRxPoolList-r12,
           discTxPoolPS-Common-r13              SL-DiscTxPoolList-r12 OPTIONAL -- Need OR     } OPTIONAL -- Need OR]] }
           SL-CarrierFreqInfoList-r12                          ::= SEQUENCE (SIZE (1..maxFreq)) OF SL-CarrierFreqInfo-r12
           SL-CarrierFreqInfoList-v1310                      ::= SEQUENCE (SIZE (1..maxFreq)) OF SL-CarrierFreqInfo-v1310
           SL-CarrierFreqInfo-r12::= SEQUENCE {
           carrierFreq-r12                                             ARFCN-ValueEUTRA-r9,
           plmn-IdentityList-r12                                     PLMN-IdentityList4-r12 OPTIONAL -- Need OP}
           SL-DiscConfigRelayUE-r13 ::= SEQUENCE {
           threshHigh-r13                                             RSRP-RangeSL4-r13 OPTIONAL, -- Need OR
           threshLow-r13                                             RSRP-RangeSL4-r13 OPTIONAL, -- Need OR
           hystMax-r13                                                ENUMERATED {dB0, dB3, dB6, dB9, dB12, dBinf}
           hystMin-r13                                                 ENUMERATED {dB0, dB3, dB6, dB9, dB12}}
           SL-DiscConfigRemoteUE-r13 ::= SEQUENCE {
           hystMax-r13                                                ENUMERATED {dB0, dB3, dB6, dB9, dB12} OPTIONAL,
           reselectionInfoIC-r13                                     ReselectionInfoRelay-r13}
           ReselectionInfoRelay-r13 ::= SEQUENCE {
           q-RxLevMin-r13                                            Q-RxLevMin,
           filterCoefficient-r13                                       FilterCoefficient,
           minHyst-r13                                                 ENUMERATED {dB0, dB3, dB6, dB9, dB12, dBinf}}
           SL-CarrierFreqInfo-v1310::= SEQUENCE {
           discResourcesNonPS-r13                                SL-ResourcesInterFreq-r13 OPTIONAL,
           discResourcesPS-r13                                     SL-ResourcesInterFreq-r13 OPTIONAL,
           discConfigOther-r13                                      SL-DiscConfigOtherInterFreq-r13 OPTIONAL,...}
           PLMN-IdentityList4-r12                     ::= SEQUENCE (SIZE (1..maxPLMN-r11)) OF PLMN-IdentityInfo2-r12
           PLMN-IdentityInfo2-r12 ::= CHOICE {
           plmn-Index-r12                                            INTEGER (1..maxPLMN-r11),
           plmnIdentity-r12                                          PLMN-Identity}
           SL-DiscTxResourcesInterFreq-r13 ::= CHOICE {
           acquireSI-FromCarrier-r13                             NULL,
           discTxPoolCommon-r13                                 SL-DiscTxPoolList-r12,
           requestDedicated-r13                                   NULL,
           noTxOnCarrier-r13                                       NULL           }
           SL-DiscConfigOtherInterFreq-r13::= SEQUENCE {
           txPowerInfo-r13                                          SL-DiscTxPowerInfoList-r12 OPTIONAL, -- Cond Tx
           refCarrierCommon-r13                                   ENUMERATED {pCell} OPTIONAL, -- Need OR
           discSyncConfig-r13                                      SL-SyncConfigListNFreq-r13 OPTIONAL, -- Need OR
           discCellSelectionInfo-r13                               CellSelectionInfoNFreq-r13 OPTIONAL -- Need OR}
           SL-ResourcesInterFreq-r13 ::= SEQUENCE {
           discRxResourcesInterFreq-r13                       SL-DiscRxPoolList-r12 OPTIONAL, -- Need OR
           discTxResourcesInterFreq-r13                       SL-DiscTxResourcesInterFreq-r13 OPTIONAL -- Need OR}
原文来自:[url]www.sharetechnote.com[/url]
整理:kangguoying20201205
"自动驾驶为什么更可靠--5G网络时延缩短的秘密!"已在微信公众号"跟着老康学5G"中推出,敬请关注!
    当前时区 GMT+8, 现在时间是 2026-07-07 14:36:15
    Processed in 0.568320 second(s), 14 queries , Gzip enabled
