  • 阅读:11266
4G(LTE)网络支持的4->5G重选信息(SIB24)
威望 1813255 个
发表于 2020-12-06 10:40:07  只看楼主
        在5G(NR)网络提出后,3GPP针对终端在空闲态下4G->5G的重选制定了特定的系统消息SIB24;其在4G(LTE)网络中进行广播,以供终端从4G重选到5G,而SIB24消息中的主要内容如下:
SIB 24( InterRAT/NR Neighbouring cells for cell reselection).
SystemInformationBlockType24-r15 ::= SEQUENCE {
carrierFreqListNR-r15                              CarrierFreqListNR-r15 OPTIONAL, -- Need----NR载频列表
t-ReselectionNR-r15                               T-Reselection,                                         ----NR重选指示
t-ReselectionNR-SF-r15                          SpeedStateScaleFactors OPTIONAL, -- Need OR ----NR重选速度因子
lateNonCriticalExtension                          OCTET STRING OPTIONAL,...}
CarrierFreqListNR-r15                                     ::= SEQUENCE (SIZE (1..maxFreq)) OF CarrierFreqNR-r15
CarrierFreqNR-r15 ::= SEQUENCE {
carrierFreq-r15                                     ARFCN-ValueNR-r15,                           ----NR载频点列表
multiBandInfoList-r15                             MultiFrequencyBandListNR-r15 OPTIONAL, -- Need OR
multiBandInfoListSUL-r15                        MultiFrequencyBandListNR-r15 OPTIONAL, -- Need OR
measTimingConfig-r15                            MTC-SSB-NR-r15 OPTIONAL, -- Need OR ----NR小区(SSB MTC) subcarrierSpacingSSB-r15                      ENUMERATED {kHz15, kHz30, kHz120, kHz240},----NR子载波间隔
ss-RSSI-Measurement-r15                     SS-RSSI-Measurement-r15 OPTIONAL, -- Cond RSRQ2---NR RSSI测量
cellReselectionPriority-r15                      CellReselectionPriority OPTIONAL, -- Need OP
cellReselectionSubPriority-r15                 CellReselectionSubPriority-r13 OPTIONAL, -- Need OR
threshX-High-r15                                  ReselectionThreshold,       ---NR  重选的X-High
threshX-Low-r15                                  ReselectionThreshold,         ---NR 重选的X-LOW
threshX-Q-r15 SEQUENCE {
threshX-HighQ-r15                       ReselectionThresholdQ-r9,
threshX-LowQ-r15                       ReselectionThresholdQ-r9
} OPTIONAL, -- Cond RSRQ
q-RxLevMin-r15                                   INTEGER (-70..-22),               ---NR 重选主小区最小接入电平
q-RxLevMinSUL-r15                              INTEGER (-70..-22) OPTIONAL, -- Need OR  ---NR 重选SUL小区最小接入电平
p-MaxNR-r15                                       P-MaxNR-r15,                             ---NR小最大发射功率
ns-PmaxListNR-r15                               NS-PmaxListNR-r15 OPTIONAL, -- Need OR
q-QualMin-r15                                     INTEGER (-43..-12) OPTIONAL, -- Need OP
deriveSSB-IndexFromCell-r15                 BOOLEAN,
maxRS-IndexCellQual-r15                      MaxRS-IndexCellQualNR-r15 OPTIONAL, -- Need OR
threshRS-Index-r15                             ThresholdListNR-r15 OPTIONAL, -- Need OR
[[ multiBandNsPmaxListNR-v1550            MultiBandNsPmaxListNR-1-v1550 OPTIONAL, -- Need OR
multiBandNsPmaxListNR-SUL-v1550         MultiBandNsPmaxListNR-v1550 OPTIONAL, -- Need OR
ssb-ToMeasure-r15                              SSB-ToMeasure-r15 OPTIONAL -- Need OR
MultiBandNsPmaxListNR-1-v1550    ::= SEQUENCE (SIZE (1.. maxMultiBandsNR-1-r15)) OF NS-PmaxListNR-r15
MultiBandNsPmaxListNR-v1550       ::= SEQUENCE (SIZE (1.. maxMultiBandsNR-r15)) OF NS-PmaxListNR-r15
原文来自:www.sharetechnote.com
整理:kangguoying20201206
"4G(LTE)小区能支持多少VOLTE用户?"将在微信公众号"跟着老康学5G"中推出,敬请关注。
    wx_10187474
    积分 165
    帖子 33
    威望 1278 个
    注册 2018-1-3
    发表于 2020-12-06 13:56:40
    原帖由 litom2004 于 2020-12-6 02:40:07 发表
    在5G(NR)网络提出后,3GPP针对终端在空闲态下4G->5G的重选制定了特定的系统消息SIB24;其在4G(LTE)网络中进行广播,以供终端从4G重选到5G,而SIB24消息中的主要内容如下:SIB 24(& ...
    多谢分享,学无止境。
    chjy
    威望 135 个
    注册 2017-9-16
    来自 深圳
    发表于 2020-12-12 18:33:42
    感谢分享,那5G向4G重新选择有相应的系统信息吗?
    当前时区 GMT+8, 现在时间是 2026-07-07 13:14:15
    Processed in 1.412006 second(s), 20 queries , Gzip enabled
