4G(LTE)网络中DCI format取决于终端的RNTI与传输模式,3GPP在36.213中定义了它们之间的关系;以RNTI为标识它们之间的关系如下:
1.DCI与SI-RNTI(38.213-v14.6.0 Table 7.1-1)
DCI format | Search Space | Transmission scheme of PDSCH corresponding to PDCCH | DCI format 1C | Common | If the number of PBCH antenna ports is one, Single-antenna port, port 0 is used , otherwise Transmit diversity . | DCI format 1A | Common | If the number of PBCH antenna ports is one, Single-antenna port, port 0 is used , otherwise Transmit diversity . |
2. DCI与P-RNTI(38.213-v14.6.0 Table 7.1-2)
DCI format | Search Space | Transmission scheme of PDSCH corresponding to PDCCH | | DCI format 1C | Common | If the number of PBCH antenna ports is one, Single-antenna port, port 0 is used, otherwise Transmit diversity | | DCI format 1A | Common | If the number of PBCH antenna ports is one, Single-antenna port, port 0 is used , otherwise Transmit diversity |
3. .DCI与RA-RNTI(38.213-v14.6.0 Table 7.1-3)
DCI format | Search Space | Transmission scheme of PDSCH corresponding to PDCCH | | DCI format 1C | Common | If the number of PBCH antenna ports is one, Single-antenna port, port 0 is used , otherwise Transmit diversity | | DCI format 1A | Common | If the number of PBCH antenna ports is one, Single-antenna port, port 0 is used , otherwise Transmit diversity |
4.DC1与 C-RNTI(38.213-v14.6.0)
Transmission mode | DCI format | Search Space | Transmission scheme of PDSCH corresponding to PDCCH | Mode 1 | DCI format 1A | Common and UE specific by C-RNTI | Single-antenna port, port 0 | DCI format 1 | UE specific by C-RNTI | Single-antenna port, port 0 | Mode 2 | DCI format 1A | Common and UE specific by C-RNTI | Transmit Diversity | DCI format 1 | UE specific by C-RNTI | Transmit Diversity | Mode 3 | DCI format 1A | Common and UE specific by C-RNTI | Transmit Diversity | DCI format 2A | UE specific by C-RNTI | Large delay CDD or Transmit Diversity | Mode 4 | DCI format 1A | Common and UE specific by C-RNTI | Transmit Diversity | DCI format 2 | UE specific by C-RNTI | Closed-loop multiplexing or Transmit Diversity | Mode 5 | DCI format 1A | Common and UE specific by C-RNTI | Transmit Diversity | DCI format 1D | UE specific by C-RNTI | Multi-user MIMO | Mode 6 | DCI format 1A | Common and UE specific by C-RNTI | Transmit Diversity | DCI format 1B | UE specific by C-RNTI | Closed-loop multiplexing using a single transmission layer | Mode 7 | DCI format 1A | Common and UE specific by C-RNTI | If the number of PBCH antenna ports is one, Single-antenna port, port 0 is used , otherwise Transmit diversity | DCI format 1 | UE specific by C-RNTI | Single-antenna port, port 5 | Mode 8 | DCI format 1A | Common and UE specific by C-RNTI | If the number of PBCH antenna ports is one, Single-antenna port, port 0 is used , otherwise Transmit diversity | DCI format 2B | UE specific by C-RNTI | Dual layer transmission, port 7 and 8 or single-antenna port, port 7 or 8 | Mode 9 | DCI format 1A | Common and UE specific by C-RNTI | Non-MBSFN subframe: If the number of PBCH antenna ports is one, Single-antenna port, port 0 is used, otherwise Transmit diversity MBSFN subframe: Single-antenna port, port 7 | DCI format 2C | UE specific by C-RNTI | Transmit diversity, port 7-8, or dual layer transmission port 7-8 , if UE is configured with higher layer parameter semiOpenLoop, up to 8 layer transmission, ports 7-14 otherwise; or single-antenna port, port 7, 8, 11, or 13 if UE is configured with higher layer parameter dmrs-tableAlt, single-antenna port, port 7 or 8 otherwise | Mode 10 | DCI format 1A | Common and UE specific by C-RNTI | Non-MBSFN subframe: If the number of PBCH antenna ports is one, Single-antenna port, port 0 is used, otherwise Transmit diversity MBSFN subframe: Single-antenna port, port 7 | DCI format 2D | UE specific by C-RNTI | Transmit diversity, port 7-8, or dual layer transmission port 7-8 , if UE is configured with higher layer parameter semiOpenLoop, up to 8 layer transmission, ports 7-14 otherwise; or single-antenna port, port 7, 8, 11, or 13 if UE is configured with higher layer parameter dmrs-tableAlt, single-antenna port, port 7 or 8 |
5.DCI与 Temporary C-RNTI(38.213-v14.6.0 Table 7.1-7)
DCI format | Search Space | Transmission scheme of PDSCH corresponding to PDCCH | | DCI format 1A | Common and UE specific by C-RNTI | If the number of PBCH antenna port is one, Single-antenna port, port 0 is used , otherwise Transmit diversity | | DCI format 1 | UE specific by C-RNTI | If the number of PBCH antenna port is one, Single-antenna port, port 0 is used , otherwise Transmit diversity |
*各种RNTI定义和用途可参考:[url]https://club.mscbsc.com/t706880p1.html[/url](终端在5G(NR)网络中的RNTI取值和用途)
原文来自:[url]www.sharetechnote.com[/url] 整理:kangguoying20201214 "“伴我行”4G网络--盒子基站NIB"已在微信公众号"跟着老康学5G"中推出,敬请关注。
7、回复“YDSL”免费领取《中国移动算力并网白皮书》
