  • 阅读:2031
4G(LTE)网络中终端分配的资源(RB)计算
威望 1813255 个
发表于 2020-12-17 18:24:10  只看楼主
       4G(LTE)网络中终端分配到的资源(RB),通过对DCI中RIV(Resource Indication Value)的计算获得 ;其中包括:终端分配到的RB数量和起始RB;kangguoying20201217
1.DCI中的RIVkangguoying20201217
2.RIV计算方法
     根据TS36.213 - 7.1.6.3上图中两种DCI的RIV计算方法分别如下:kangguoying20201217
2.1 PDCCH DCI format 1A, 1B or 1D,  for EPDCCH DCI format 1A, 1B, or 1Dkangguoying20201217
2.2 PDCCH DCI format 1Ckangguoying20201217
3.计算RIV批处理kangguoying20201217
 % Following is from lte_dci_1a_unpack.m file in /octave folderkangguoying20201217
        for(n=1:N_rb_dl)kangguoying20201217
            for(m=0:(N_rb_dl-n))
                if((n-1) <= floor(N_rb_dl/2))
                    if(RIV == N_rb_dl*(n-1)+m)
                        L_crb    = n;
                        RB_start = m;
                    endif
                else  kangguoying20201217
                    if(RIV == N_rb_dl*(N_rb_dl-n+1)+(N_rb_dl-1-m))
                        L_crb    = n;kangguoying20201217
                        RB_start = m;
                    endif
                endif
            endfor
        endfor
原文来自:[url]www.sharetechnote.com[/url]
整理:kangguoying20201217
“伴我行”4G网络--盒子基站NIB"已在微信公众号"跟着老康学5G"中推出,敬请关注。
    当前时区 GMT+8, 现在时间是 2026-07-07 11:52:41
    Processed in 0.659992 second(s), 17 queries , Gzip enabled
