| Bit(比特) | Definition(功能定义) | Note(应用) | DD/TDD |
| 1 | . Intra-subframe frequency hopping for PUSCH scheduled by UL grantkangguoying20201227 |
| Yes |
| . DCI format 3a (TPC commands for PUCCH and PUSCH with single bit power adjustments)kangguoying20201227 |
| . Aperiodic CQI/PMI/RI reporting on PUSCH: Mode 2-0 - UE selected subband CQI without PMIkangguoying20201227 |
| . Aperiodic CQI/PMI/RI reporting on PUSCH: Mode 2-2 - UE selected subband CQI with multiple PMIkangguoying20201227 |
| 2 | . Simultaneous CQI and ACK/NACK on PUCCH, i.e. PUCCH format 2a and 2bkangguoying20201227 |
| Yes |
| . Absolute TPC command for PUSCHkangguoying20201227 |
| . Resource allocation type 1 for PDSCHkangguoying20201227 |
| Periodic CQI/PMI/RI reporting on PUCCH : |
| . Mode 2-0 = UE selected subband CQI without PMI |
| . Mode 2-1 = UE selected subband CQI with single PMI |
| 3 | . 5 bit RLC UM SNkangguoying20201227 | VoLTE | No |
| . 7 bit PDCP SNkangguoying20201227 | Bit 7 = 1 |
| 4 | Short DRX cyclekangguoying20201227 | Bit 5 = 1 | Yes |
| 5 | Long DRX cycle, DRX command MAC control element |
| No |
| 6 | Prioritised bit ratekangguoying20201227 |
| No |
| 7 | RLC UMkangguoying20201227 | VoLTE | No |
| 8 | . EUTRA RRC_CONNECTED to UTRA FDD or UTRA TDD CELL_DCH PS handover, if the UE supports either only UTRAN FDD or only UTRAN TDD | Bit 22 = 1 | Yes |
| . EUTRA RRC_CONNECTED to UTRA FDD CELL_DCH PS handover, if the UE supports both UTRAN FDD and UTRAN TDD |
| 9 | EUTRA RRC_CONNECTED to GERAN GSM_Dedicated handover | SRVCC | Yes |
| kangguoying20201227 | Bit 23 = 1 |
| 10 | EUTRA RRC_CONNECTED to GERAN (Packet_) Idle by Cell Change Order (CCO), |
| Yes |
| without or with NACC (Network Assisted Cell Change) |
| 11 | EUTRA RRC_CONNECTED to CDMA2000 1xRTT CS Active handover | SRVCC | Yes |
| Bit 24 = 1 |
| 12 | EUTRA RRC_CONNECTED to CDMA2000 HRPD Active handover | Bit 26 = 1 | Yes |
| 13 | Inter-frequency handover within FDD or TDD | Bit 25 = 1 | No |
| 14 | Event measurement reporting A4 and A5kangguoying20201227 |
| No |
| 15 | Inter RAT Event B1 :kangguoying20201227 | UE has set at least one of the bit number 22, 23, 24, 26 or 39 to 1 | Yes |
| . UTRAN FDD or UTRAN TDD, if the UE supports either only UTRAN FDD or only UTRAN TDD and has set bit number 22 to 1 |
| . UTRAN FDD or UTRAN TDD, if the UE supports both UTRAN FDD and UTRAN TDD and has set bit number 22 or 39 to 1, respectivelykangguoying20201227 |
| . GERAN, 1xRTT or HRPD, if the UE has set bit number 23, 24 or 26 to 1, respectivelykangguoying20201227 |
| 16 | Periodical measurement, reportStrongestCells : |
| No |
| . Intra-frequencykangguoying20201227 |
| . Inter-frequency, if Bit 25=1kangguoying20201227 |
| . Inter-RAT UTRAN FDD or UTRAN TDD, if the UE supports either only UTRAN FDD or only UTRAN TDD and has set bit number 22 to 1kangguoying20201227 |
| . Inter-RAT UTRAN FDD or UTRAN TDD, if the UE supports both UTRAN FDD and UTRAN TDD and has set bit number 22 or 39 to 1, respectivelykangguoying20201227 |
| . Inter-RAT GERAN, 1xRTT or HRPD, if the UE has set bit number 23, 24 or 26 to 1, respectively |
| 17 | Intra-frequency ANR featureskangguoying20201227 | Bit 5 = 1 | No |
| periodical measurement, reportStrongestCells and reportCGI |
| 18 | Inter-frequency ANR featureskangguoying20201227 | Bit 13 = 1 | No |
| 19 | Inter-RAT ANR features, periodical measurement : | Bit 5 | Yes |
| . reportStrongestCells for GERAN, if bit 23=1kangguoying20201227 | At least one of the bit number 22, 23, 24 or 26 to 1 |
| . reportStrongestCellsForSON for UTRAN FDD or UTRAN TDD, if the UE supports either only UTRAN FDD or only UTRAN TDD and has set bit number 22 to 1kangguoying20201227 |
| . reportStrongestCellsForSON for UTRAN FDD or UTRAN TDD, if the UE supports both UTRAN FDD and UTRAN TDD and has set bit number 22 or 39 to 1, respectivelykangguoying20201227 |
| . reportStrongestCellsForSON for 1xRTT or HRPD, if the UE has set bit number 24 or 26 to 1, respectively |
| . reportCGI for UTRAN FDD or UTRAN TDD, if the UE supports either only UTRAN FDD or only UTRANTDD and has set bit number 22 to 1kangguoying20201227 |
| . reportCGI for UTRAN FDD or UTRAN TDD, if the UE supports both UTRAN FDD and UTRAN TDD and has set bit number 22 or 39 to 1, respectivelykangguoying20201227 |
| . reportCGI for GERAN, 1xRTT or HRPD, if the UE has set bit number 23, 24 or 26 to 1, respectively |
| 20 | SRB1 and SRB2 for DCCH +kangguoying20201227 |
| No |
| . if Bit 7 == 0 : 8x AM DRBkangguoying20201227 |
| . if Bit 7 == 1 : 8x AM DRB, (5x AM DRB + 3x UM DRB) |
| 21 | . Predefined intra- and inter-subframe frequency hopping for PUSCH with N_sb > 1kangguoying20201227 |
| No |
| . Predefined inter-subframe frequency hopping for PUSCH with N_sb > 1kangguoying20201227 |
| 22 | . UTRAN FDD or UTRAN TDD measurements, reporting and measurement reporting event B2 in E-UTRA connected mode, if the UE supports either only UTRAN FDD or only UTRAN TDD |
| Yes |
| . UTRAN FDD measurements, reporting and measurement reporting event B2 in E-UTRA connected mode, if the UE supports both UTRAN FDD and UTRAN TDD |
| 23 | GERAN measurements, event B2kangguoying20201227 |
| Yes |
| 24 | 1xRTT measurements, event B2kangguoying20201227 |
| Yes |
| 25 | Inter-frequency measurements and reporting in E-UTRA connected mode |
| No |
| 26 | HRPD measurements, reporting and measurement reporting event B2 in E-UTRA connected mode |
| Yes |
| 27 | . EUTRA RRC_CONNECTED to UTRA FDD or UTRA TDD CELL_DCH CS handover, if the UE supports either only UTRAN FDD or only UTRAN TDD | SRVCC | Yes |
| . EUTRA RRC_CONNECTED to UTRA FDD CELL_DCH CS handover, if the UE supports both UTRAN FDD and UTRAN TDD | Bit 13 = 1 |
| 28 | TTI bundlingkangguoying20201227 |
| Yes |
| 29 | Semi-Persistent Scheduling (SPS)kangguoying20201227 |
| Yes |
| 30 | Handover between FDD and TDDkangguoying20201227 | Bit 13 = 1 | No |
| 31 | UE supports cells kangguoying20201227 broadcasting Multi Frequency Band Information (MFBI) |
| No |
| 32 |
