在4G(LTE)网络支持的Sidelink网络中物理信号有同步、共享和控制信号,这些信道中承载的内容分别如下:
而Sidelink中传输信道只有SL-BCH和SL-SCH两种,
第一部分,物理信号
1.Sidelink物理同步信号
Sidelink主同步信号 (ltePSSS):Primary sidelink synchronization signal;
Sidelink主同步资源指数 (ltePSSSIndices):PSSS resource element indices;
Sidelink辅同步信号(lteSSSS):Secondary sidelink synchronization signal;
Sdelink辅同步资源指数(lteSSSS):Indices:SSSS resource element indices;
2.Sidelink物理共享信号
主同步解调参考信号(ltePSSCHDRS):PSSCH demodulation reference signal;
主同步解调参考信号资源指数(ltePSSCHDRSIndices):PSSCH DM-RS resource element indices;
3.Sidelink物理控制信号
共享信道解调参考信号(ltePSCCHDRS):PSCCH demodulation reference signal;
共享信道解调参考信号资源指数( ltePSCCHDRSIndices):PSCCH DM-RS resource element indices;
第二部分 物理广播信道及承载内容
| ltePSBCH | Physical sidelink broadcast channel |
| ltePSBCHIndices | PSBCH resource element indices |
| ltePSBCHDRS | PSBCH demodulation reference signal |
| ltePSBCHDRSIndices | PSBCH DM-RS resource element indices |
| ltePSBCHPRBS | PSBCH pseudorandom binary scrambling sequence |
| ltePSBCHDecode | PSBCH decoding |
| lteSLChannelEstimatePSBCH | PSBCH sidelink channel estimation |
| lteSLFrameOffsetPSBCH | PSBCH DM-RS sidelink subframe timing estimate |
第三部分 物理共享信道及承载内容
| ltePSSCH | Physical sidelink shared channel |
| ltePSSCHIndices | PSSCH resource element indices |
| ltePSSCHDRS | PSSCH demodulation reference signal |
| ltePSSCHDRSIndices | PSSCH DM-RS resource element indices |
| ltePSSCHPRBS | PSSCH pseudorandom binary scrambling sequence |
| ltePSSCHDecode | PSSCH decoding |
| lteSLChannelEstimatePSSCH | PSSCH sidelink channel estimation |
| lteSLFrameOffsetPSSCH | PSSCH DM-RS sidelink subframe timing estimate |
第四部分 物理控制信道及承载内容
| ltePSCCH | Physical sidelink control channel |
| ltePSCCHIndices | PSCCH resource element indices |
| ltePSCCHDRS | PSCCH demodulation reference signal |
| ltePSCCHDRSIndices | PSCCH DM-RS resource element indices |
| ltePSCCHPRBS | PSCCH pseudorandom binary scrambling sequence |
| ltePSCCHDecode | PSCCH decoding |
| lteSLChannelEstimatePSCCH | PSCCH sidelink channel estimation |
| lteSLFrameOffsetPSCCH | PSCCH DM-RS sidelink subframe timing estimate |
第四部分传输信道(SL-BCH和SL-SCH):用于在特定的传输块中传输MAC数据
| lteSLMIB | Sidelink master information block encoding and decoding |
| lteSLBCH | Sidelink broadcast channel |
| lteSLBCHDecode | Sidelink broadcast channel decoding |
| lteSLSCH | Sidelink shared channel |
| lteSLSCHDecode | Sidelink shared channel decoding |
原文来自:mathworks
整理:kangguoying 20210131
5G(NR)网络PDCCH承载了些啥?在公众号k_guoying中已发布。。
7、回复“YDSL”免费领取《中国移动算力并网白皮书》
