  • 阅读:13039
蓝牙(Bluetooth)通信交互消息实例
威望 1812690 个
发表于 2021-02-09 08:43:18  只看楼主
       与其他无线通信一样,蓝牙设备通信中也是通过消息交互进行信息交流;以下是Wiershark对设备发送和接收内容进行抓包过滤后的结果:Kangguoying2021
Step
Command
Sent HCI Command InquiryKangguoying2021
Rcvd HCI Event Command Status (Inquiry)
Rcvd HCI Event Inquiry Result
Rcvd HCI Event Inquiry Complete
Sent HCI Command Remote Name Request
Rcvd HCI Event Command Status (Remote Name Request)
Rcvd HCI Event Remote Name Req Complete
Rcvd HCI Event Connect RequestKangguoying2021
9
Sent HCI Command Accept Connection Request
10
Rcvd HCI Event Command Status (Accept Connection Request)
11
Rcvd HCI Event PIN Code RequestKangguoying2021
12
Sent HCI Command PIN Code Request Reply
13
Rcvd HCI Event Command Complete (PIN Code Request Reply)
14
Rcvd HCI Event Connect CompleteKangguoying2021
15
16
17
18
19
20
21
Rcvd HCI Event Link Key Notification
22
23
Sent HCI Command Write Link Policy Settings
24
Rcvd HCI Event Page Scan Repetition Mode Change
25
Rcvd HCI Event Command Complete (Write Link Policy Settings)
26
Sent HCI Command Change Connection Packet Type
27
Rcvd HCI Event Max Slots Change
28
Rcvd HCI Event Command Status (Change Connection Packet Type)
29
Sent HCI Command Remote Name RequestKangguoying2021
30
Rcvd HCI Event Connection Packet Type Changed
31
32
33
34
Rcvd HCI Event Remote Name Req CompleteKangguoying2021
35
Rcvd HCI Event Disconnect Complete
        这35步消息的详细内容(Bluetooth HCI H4)分别如下:Kangguoying2021
(1) Command Inquiry
        [Direction: Sent (0x00)]
        HCI Packet Type: HCI Command (0x01)
    Bluetooth HCI Command - InquiryKangguoying2021
        Command Opcode: Inquiry (0x0401)
            0000 01.. .... .... = ogf: Link Control Commands (0x0001)
            .... ..00 0000 0001 = ocf: 0x0001Kangguoying2021Kangguoying2021
        Parameter Total Length: 5
        LAP: 0x9e8b33Kangguoying2021
        Inquiry Length: 16
        Num Responses: 0
(2) Command Status (Inquiry)
        [Direction: Rcvd (0x01)]Kangguoying2021
        HCI Packet Type: HCI Event (0x04)
    Bluetooth HCI Event - Command Status
        Event Code: Command Status (0x0f)
        Parameter Total Length: 4Kangguoying2021
        Status: Pending (0x00)Kangguoying2021
        Number of Allowed Command Packets: 1
(3) Inquiry Result
    Bluetooth HCI H4
    Bluetooth HCI Event - Inquiry Result
        Event Code: Inquiry Result (0x02)
        Parameter Total Length: 15
        Number of responses: 1
        BD_ADDR:000e:6d:072efa (MurataMa_07:2e:fa)
        Page Scan Repetition Mode: R1 (0x01)Kangguoying2021Kangguoying2021
        Page Scan Period Mode: P0 (0x00)
        Page Scan Mode: Mandatory Page Scan Mode (0x00)
        Class of Device: 0x420204 (Phone - services: Telephony, Networking)
        .100 0010 1101 1101 = Clock Offset: 0x42dd
(4) Inquiry Complete
    Bluetooth HCI Event - Inquiry Complete
        Event Code: Inquiry Complete (0x01)
        Parameter Total Length: 1Kangguoying2021
        Status: Success (0x00)
(5) Remote Name Request
        [Direction: Sent (0x00)]Kangguoying2021
        HCI Packet Type: HCI Command (0x01)Kangguoying2021
    Bluetooth HCI Command - Remote Name Request
        Command Opcode: Remote Name Request (0x0419)
            .... ..00 0001 1001 = ocf: 0x0019
        Parameter Total Length: 10Kangguoying2021
        .000 0000 0000 0000 = Clock Offset: 0x0000 (0 ms)
        0... .... .... .... = Clock_Offset_Valid_Flag: false (0)
(6) Command Status (Remote Name Request)
(7) Remote Name Req Complete
    Bluetooth HCI Event - Remote Name Req Complete
        Event Code: Remote Name Req Complete (0x07)
        Parameter Total Length: 255Kangguoying2021
        Status: Page Timeout (0x04)Kangguoying2021
        Remote Name:
(8) Connect Request
    Bluetooth HCI Event - Connect RequestKangguoying2021
        Event Code: Connect Request (0x04)
        Class of Device: 0x6a0204 (Phone - services: Telephony, Audio, Capturing, Networking)
        Link Type: ACL connection (Data Channels) (0x01)
(9) Accept Connection Request
    Bluetooth HCI Command - Accept Connection Request
        Command Opcode: Accept Connection Request (0x0409)
            .... ..00 0000 1001 = ocf: 0x0009
        Parameter Total Length: 7Kangguoying2021
        Role: Remain Slave (0x01)
(10) Command Status (Accept Connection Request)
(11) PIN Code Request
    Bluetooth HCI Event - PIN Code Request
        Event Code: PIN Code Request (0x16)Kangguoying2021
        Parameter Total Length: 6
(12) PIN Code Request Reply
    Bluetooth HCI Command - PIN Code Request Reply
        Command Opcode: PIN Code Request Reply (0x040d)
            .... ..00 0000 1101 = ocf: 0x000d
        Parameter Total Length: 23
        PIN Code Length: 4
        PIN Code: 1234
(13) Command Complete (PIN Code Request Reply)
    Bluetooth HCI Event - Command Complete
        Event Code: Command Complete (0x0e)
        Status: Success (0x00)Kangguoying2021
(14) Connect Complete
        HCI Packet Type: HCI Event (0x04)Kangguoying2021
    Bluetooth HCI Event - Connect Complete
        Event Code: Connect Complete (0x03)
        Parameter Total Length: 11Kangguoying2021
        Status: Authentication Failure (0x05)
        Connection Handle: 0x0029
        Encryption Mode: Encryption Disabled (0x00)
(15) Connect Request
(16) Accept Connection Request
            .... ..00 0000 1001 = ocf: 0x0009Kangguoying2021
(17) Command Status (Accept Connection Request)
(18) PIN Code Request
        Parameter Total Length: 6Kangguoying2021
(19) PIN Code Request Reply
        Parameter Total Length: 23Kangguoying2021
        PIN Code Length: 4
        PIN Code: 1234
(20) Command Complete (PIN Code Request Reply)
            .... ..00 0000 1101 = ocf: 0x000dKangguoying2021
(21) Link Key Notification
    Bluetooth HCI Event - Link Key NotificationKangguoying2021
        Event Code: Link Key Notification (0x18)
        Link Key: ec596f3306bba9e53d7b72de47c1404a
        Key Type: Combination Key (0x00)
(22) Connect Complete
        Connection Handle: 0x002aKangguoying2021
        Encryption Mode: Encryption only for point-to-point packets (0x01)
(23) Write Link Policy Settings
    Bluetooth HCI Command - Write Link Policy Settings
        Command Opcode: Write Link Policy Settings (0x080d)
            0000 10.. .... .... = ogf: Link Policy Commands (0x0002)
        .... .... .... ...1 = Enable Master Slave Switch: true (1)
        .... .... .... ..1. = Enable Hold Mode: true (1)
        .... .... .... .1.. = Enable Sniff Mode: true (1)
        .... .... .... 1... = Enable Park Mode: true (1)
(24) Page Scan Repetition Mode Change
    Bluetooth HCI Event - Page Scan Repetition Mode Change
        Event Code: Page Scan Repetition Mode Change (0x20)
(25) Command Complete (Write Link Policy Settings)
(26) Change Connection Packet Type
    Bluetooth HCI Command - Change Connection Packet Type
        Command Opcode: Change Connection Packet Type (0x040f)
            .... ..00 0000 1111 = ocf: 0x000f
        .... .... .... ..0. = Packet Type 2-DH1: false (0)
        .... .... .... .0.. = Packet Type 3-DH1: false (0)
        .... .... .... 1... = Packet Type DM1: true (1)Kangguoying2021
        .... .... ...1 .... = Packet Type DH1: true (1)
        .... ...0 .... .... = Packet Type 2-DH3: false (0)
        .... ..0. .... .... = Packet Type 3-DH3: false (0)
        .... .1.. .... .... = Packet Type DM3: true (1)
        .... 1... .... .... = Packet Type DH3: true (1)
        ...0 .... .... .... = Packet Type 2-DH5: false (0)
        ..0. .... .... .... = Packet Type 3-DH5: false (0)
        .1.. .... .... .... = Packet Type DM5: true (1)
        1... .... .... .... = Packet Type DH5: true (1)
(27) Max Slots Change
    Bluetooth HCI Event - Max Slots Change
        Event Code: Max Slots Change (0x1b)
        Parameter Total Length: 3Kangguoying2021
        Maximum Number of Slots: 5
(28) Command Status (Change Connection Packet Type)
(29) Remote Name Request
        Page Scan Repetition Mode: R1 (0x01)Kangguoying20210209
(30) Connection Packet Type Changed
        [Direction: Rcvd (0x01)]Kangguoying20210209
    Bluetooth HCI Event - Connection Packet Type Changed
        Event Code: Connection Packet Type Changed (0x1d)
        Status: Success (0x00)Kangguoying20210209
        Usable packet types: DM1 HV1 2-DH1Kangguoying20210209
            .... .... .... ..0. = ACL Link Type 2-DH1: False (0)
            .... .... .... .0.. = ACL Link Type 3-DH1: False (0)
            .... .... .... 1... = ACL Link Type DM1: True (1)
            .... .... ...1 .... = ACL Link Type DH1: True (1)
            .... ...0 .... .... = ACL Link Type 2-DH3: False (0)
            .... ..0. .... .... = ACL Link Type 3-DH3: False (0)
            .... .1.. .... .... = ACL Link Type DM3: True (1)
            .... 1... .... .... = ACL Link Type DH3: True (1)Kangguoying20210209
            ...0 .... .... .... = ACL Link Type 2-DH5: False (0)
            ..0. .... .... .... = ACL Link Type 3-DH5: False (0)
            .1.. .... .... .... = ACL Link Type DM5: True (1)
            1... .... .... .... = ACL Link Type DH5: True (1)
            .... .... ..0. .... = SCO Link Type HV1: False (0)
            .... .... .0.. .... = SCO Link Type HV2: False (0)
            .... .... 0... .... = SCO Link Type HV3: False (0)
(31) Command Status (Remote Name Request)
        HCI Packet Type: HCI Event (0x04)Kangguoying20210209
        Parameter Total Length: 4Kangguoying20210209
        Status: Pending (0x00)Kangguoying20210209
(32) Remote Name Request
        [Direction: Sent (0x00)]Kangguoying20210209
        HCI Packet Type: HCI Command (0x01)Kangguoying20210209
            .... ..00 0001 1001 = ocf: 0x0019Kangguoying20210209
        .000 0000 0000 0000 = Clock Offset: 0x0000 (0 ms)Kangguoying20210209
(33) Command Status (Remote Name Request)
        Number of Allowed Command Packets: 0Kangguoying20210209Kangguoying20210209
(34) Remote Name Req Complete
        Parameter Total Length: 255Kangguoying20210209
        Status: Other End Terminated Connection: User Ended Connection (0x13)
        Remote Name:
(35) Disconnect Complete
    Bluetooth HCI Event - Disconnect Complete
        Event Code: Disconnect Complete (0x05)
        Connection Handle: 0x002aKangguoying20210209
        Reason: Other End Terminated Connection: User Ended Connection (0x13)
原文来自:sharetechnote
整理:Kangguoying20210209
    当前时区 GMT+8, 现在时间是 2026-06-27 05:31:52
    Processed in 0.862595 second(s), 14 queries , Gzip enabled
