  • 阅读:2956
4G网络中5G邻区广播消息SIB24
威望 1813255 个
发表于 2021-03-01 09:39:01  只看楼主
      为于便于终端在4G网络中重选到5G(NR)网络,3GPP在36.331的R15版本中增加了SIB24消息;空闲态下的终端接收到该消息后,根据其内容对5G(NR)小区进行测量,当满足其条件时重选到5G(NR)网络;SIB24的内容如下:
SIB 24: InterRAT/NR Neighbouring cells for cell reselection.-----SIB24:频间/NR邻区重选
       SystemInformationBlockType24-r15 ::=SEQUENCE {-----系统消息Type24-r15
       carrierFreqListNR-r15         CarrierFreqListNR-r15OPTIONAL, -- Need-----载波频率列表NR-R15:
       t-ReselectionNR-r15            T-Reselection,-----t-NR重选R15(时间):
       t-ReselectionNR-SF-r15        SpeedStateScaleFactorsOPTIONAL, -- Need OR-----t-NR重选-速率因子R15(时间):
       lateNonCriticalExtension       OCTETSTRING OPTIONAL,...}
       CarrierFreqListNR-r15       ::=SEQUENCE (SIZE (1..maxFreq)) OF CarrierFreqNR-r15-----NR-R1载频列表
       CarrierFreqNR-r15 ::= SEQUENCE { carrierFreq-r15            ARFCN-ValueNR-r15,-----载波频点
       multiBandInfoList-r15         MultiFrequencyBandListNR-r15OPTIONAL, -- Need OR-----多频段指示
       multiBandInfoListSUL-r15    MultiFrequencyBandListNR-r15OPTIONAL, -- Need OR-----多频段SUL指示
       measTimingConfig-r15        MTC-SSB-NR-r15OPTIONAL, -- Need OR-----测量时间配置(NR MTC-SSB
       subcarrierSpacingSSB-r15    ENUMERATED{kHz15, kHz30, kHz120, kHz240},-----子载波间隔
       ss-RSSI-Measurement-r15    SS-RSSI-Measurement-r15OPTIONAL, -- Cond RSRQ2-----子载波RSSI测量
       cellReselectionPriority-r15      CellReselectionPriorityOPTIONAL, -- Need OP-----小区重选优先级
       cellReselectionSubPriority-r15     CellReselectionSubPriority-r13OPTIONAL, -- Need OR-----小区重选次优先级
       threshX-High-r15                      ReselectionThreshold,-----重选高门限(X-High
       threshX-Low-r15                       ReselectionThreshold,-----重选低门限(X-Low
       threshX-Q-r15 SEQUENCE {    threshX-HighQ-r15     ReselectionThresholdQ-r9,------重选质量高门限(X-High
       threshX-LowQ-r15          ReselectionThresholdQ-r9} OPTIONAL, -- Cond RSRQ------重选质量低门限(X-Low
       q-RxLevMin-r15               INTEGER(-70..-22),-------重选最小接入门限
       q-RxLevMinSUL-r15          INTEGER(-70..-22) OPTIONAL, -- Need OR-----SUL重选最小接入门限
       p-MaxNR-r15                    P-MaxNR-r15,-----NR最大发射功率
       ns-PmaxListNR-r15          NS-PmaxListNR-r15OPTIONAL, -- Need OR-----NS- NR最大发射功率
       q-QualMin-r15                     INTEGER(-43..-12) OPTIONAL, -- Need OP-----最小接入(质量)
       deriveSSB-IndexFromCell-r15         BOOLEAN,-----SSB指示
       maxRS-IndexCellQual-r15            MaxRS-IndexCellQualNR-r15OPTIONAL, -- Need OR-----小区质量RS指示
       threshRS-Index-r15                   ThresholdListNR-r15OPTIONAL, -- Need OR...,-----RS门限指示
       [[multiBandNsPmaxListNR-v1550       MultiBandNsPmaxListNR-1-v1550OPTIONAL, -- Need OR multiBandNsPmaxListNR-SUL-v1550        MultiBandNsPmaxListNR-v1550OPTIONAL, -- Need OR ssb-ToMeasure-r15        SSB-ToMeasure-r15OPTIONAL -- Need OR]]}-----多频段指示,SSB测量配置
       MultiBandNsPmaxListNR-1-v1550  ::= SEQUENCE (SIZE (1.. maxMultiBandsNR-1-r15)) OFNS-PmaxListNR-r15
       MultiBandNsPmaxListNR-v1550     ::= SEQUENCE (SIZE (1.. maxMultiBandsNR-r15))OF NS-PmaxListNR-r15------多频段发射功率指示
整理:Kangguoying20210228
5G(NR)网络中竞争和非竞争接入”在我V信k_guoying中,欢迎关注
    不服如画
    积分 55
    威望 649 个
    注册 2018-8-18
    发表于 2021-03-03 11:09:55
    原帖由 litom2004 于 2021-3-1 01:39:01 发表
    为于便于终端在4G网络中重选到5G(NR)网络,3GPP在36.331的R15版本中增加了SIB24消息;空闲态下的终端接收到该消息后,根据其内容对5G(NR)小区进行测量,当满足其条件时重选到5G(NR)网络; ...
    学习了,谢谢分享
    当前时区 GMT+8, 现在时间是 2026-07-07 12:01:54
    Processed in 0.705073 second(s), 20 queries , Gzip enabled
