  • 阅读:1824
5G无线网中的搜索空间相关参数配置
Mr Kang
积分 105076
帖子 8582
威望 1796753 个
发表于 2021-08-31 15:54:27  只看楼主
        5G无线网中IE SearchSpace 定义了终端(UE)如何/在何处搜索 PDCCH 候选。 每个搜索空间都与一个 Control ResourceSet(控制资源集)相关联。 对于跨载波调度情况下的调度小区,除nrofCandidates外,所有可选字段均不存在(无论其存在条件如何)。kangguoying20210831
搜索空闲参数配置
-- ASN1STARTkangguoying20210831
-- TAG-SEARCHSPACE-START
SearchSpace ::=   kangguoying20210831 SEQUENCE {
    searchSpaceId                           SearchSpaceId,
    controlResourceSetId                    ControlResourceSetId   kangguoying20210831    OPTIONAL,   -- Cond SetupOnly
    monitoringSlotPeriodicityAndOffset      CHOICE {
        sl1                                     NULL,
        sl2                                     INTEGER (0..1),
        sl4                                     INTEGER (0..3),
        sl5                                     INTEGER (0..4),
        sl8  kangguoying20210831  INTEGER (0..7),
        sl10kangguoying20210831  INTEGER (0..9),
        sl16                                    INTEGER (0..15),
        sl20  kangguoying20210831 INTEGER (0..19),
        sl40                                    INTEGER (0..39),
        sl80                                    INTEGER (0..79),
        sl160   kangguoying20210831       INTEGER (0..159),
        sl320                                   INTEGER (0..319),
        sl640                                   INTEGER (0..639),
        sl1280                                  INTEGER (0..1279),
        sl2560                                  INTEGER (0..2559)
    }                 kangguoying20210831                                       OPTIONAL,   -- Cond Setup
    duration                                INTEGER (2..2559)                                           OPTIONAL,   -- Need R
    monitoringSymbolsWithinSlot             BIT STRING (SIZE (14))                                      OPTIONAL,   -- Cond Setup
    nrofCandidates                          SEQUENCE {kangguoying20210831
        aggregationLevel1                       ENUMERATED {n0, n1, n2, n3, n4, n5, n6, n8},
        aggregationLevel2                       ENUMERATED {n0, n1, n2, n3, n4, n5, n6, n8},
        aggregationLevel4                       ENUMERATED {n0, n1, n2, n3, n4, n5, n6, n8},
        aggregationLevel8                       ENUMERATED {n0, n1, n2, n3, n4, n5, n6, n8},
        aggregationLevel16                      ENUMERATED {n0, n1, n2, n3, n4, n5, n6, n8}    }          OPTIONAL,   -- Cond Setup
    searchSpaceType                         CHOICE {kangguoying20210831
        common                                  SEQUENCE {
            dci-Format0-0-AndFormat1-0              SEQUENCE {                ...            }          OPTIONAL,   -- Need R
            dci-Format2-0                           SEQUENCE {kangguoying20210831
                nrofCandidates-SFI                      SEQUENCE {kangguoying20210831
                    aggregationLevel1                       ENUMERATED {n1, n2}                         OPTIONAL,   -- Need R
                    aggregationLevel2                       ENUMERATED {n1, n2}                         OPTIONAL,   -- Need R
                    aggregationLevel4                       ENUMERATED {n1, n2}                         OPTIONAL,   -- Need R
                    aggregationLevel8                       ENUMERATED {n1, n2}                         OPTIONAL,   -- Need R
                    aggregationLevel16                      ENUMERATED {n1, n2}                         OPTIONAL    -- Need R     },     ...     }    OPTIONAL,   -- Need R
            dci-Format2-1                           SEQUENCE {                ...            }                                                 OPTIONAL,   -- Need R
            dci-Format2-2                           SEQUENCE {                ...            }                                                  OPTIONAL,   -- Need R
            dci-Format2-3                           SEQUENCE {kangguoying20210831
                dummy1                                  ENUMERATED {sl1, sl2, sl4, sl5, sl8, sl10, sl16, sl20}  OPTIONAL,   -- Cond Setup
                dummy2                                  ENUMERATED {n1, n2},                ...            }               OPTIONAL    -- Need R        },
        ue-Specific                                 SEQUENCE {kangguoying20210831
            dci-Formats                                 ENUMERATED {formats0-0-And-1-0, formats0-1-And-1-1},            ...,
            [[ dci-Formats-MT-r16                   ENUMERATED {formats2-5}                                OPTIONAL,    -- Need R
            dci-FormatsSL-r16                    ENUMERATED {formats0-0-And-1-0, formats0-1-And-1-1, formats3-0, formats3-1,
                                                             formats3-0-And-3-1}                        OPTIONAL,    -- Need R
            dci-FormatsExt-r16                   ENUMERATED {formats0-2-And-1-2, formats0-1-And-1-1And-0-2-And-1-2}
                                                              OPTIONAL     -- Need R            ]]        }   }     kangguoying20210831
SearchSpaceExt-r16 ::=                   SEQUENCE {kangguoying20210831
    controlResourceSetId-r16                ControlResourceSetId-r16                                    OPTIONAL,   -- Cond SetupOnly2
    searchSpaceType-r16                     SEQUENCE {
        common-r16                              SEQUENCE {kangguoying20210831
            dci-Format2-4-r16                       SEQUENCE {kangguoying20210831
                nrofCandidates-CI-r16                   SEQUENCE {
                    aggregationLevel1-r16                   ENUMERATED {n1, n2}                         OPTIONAL,   -- Need R
                    aggregationLevel2-r16                   ENUMERATED {n1, n2}                         OPTIONAL,   -- Need Rkangguoying20210831
                    aggregationLevel4-r16                   ENUMERATED {n1, n2}                         OPTIONAL,   -- Need R
                    aggregationLevel8-r16                   ENUMERATED {n1, n2}                         OPTIONAL,   -- Need R
                    aggregationLevel16-r16                  ENUMERATED {n1, n2}                         OPTIONAL    -- Need R         },      ...   optIONAL,   -- Need R
            dci-Format2-5-r16                      SEQUENCE {kangguoying20210831
                nrofCandidates-IAB-r16                  SEQUENCE {
                    aggregationLevel16-r16                  ENUMERATED {n1, n2}                         OPTIONAL    -- Need R                },                ...            }        OPTIONAL,   -- Need Rkangguoying20210831
            dci-Format2-6-r16                SEQUENCE {            ...            }     OPTIONAL,   -- Need R          ...        }    }      OPTIONAL,    -- Cond Setup3
    searchSpaceGroupIdList-r16                      SEQUENCE (SIZE (1.. 2)) OF INTEGER (0..1)           OPTIONAL,    -- Need R
    freqMonitorLocations-r16                        BIT STRING (SIZE (5))                               OPTIONAL     -- Need Rkangguoying20210831
-- TAG-SEARCHSPACE-STOPkangguoying20210831
-- ASN1STOP
字段注释:
common:将此搜索空间配置为要监视的通用搜索空间 (CSS) 和 DCI 格式。kangguoying20210831
controlResourceSetId:适用于此 SearchSpace 的 CORESET。 值 0 标识在 MIB 和 ServingCellConfigCommon 中配置的公共 CORESET#0。 值 1..maxNrofControlResourceSets-1 标识在系统信息中或通过专用信令配置的 CORESET。 具有非零 controlResourceSetId 的 CORESET 配置在与此 SearchSpace 相同的 BWP 中。 如果存在 controlResourceSetId-r16 字段,UE 应忽略 controlResourceSetId(无后缀)。kangguoying20210831
dummy1, dummy2:该字段未在规范中使用。 如果收到,UE 将忽略它。kangguoying20210831
dci-Format0-0-AndFormat1-0:如果已配置,则 UE 根据 TS 38.213 [13] 条款 10.1 监视 DCI 格式 0_0 和 1_0。
dci-FormatsSL:指示 UE 是否在此 USS 中监视 DCI 格式 0-0 和 1-0 或格式 0-1 和 1-1 或格式 3-0 动态授权或格式 3-1 或格式 3-0动态授予和 3-1。kangguoying20210831
duration:SearchSpace 在每个场合持续的连续时隙的数量,即,在周期和偏移中给出的每个周期。如果该字段不存在,则 UE 应用值 1 时隙,但 DCI 格式 2_0 除外。对于 DCI 格式 2_0,UE 忽略此字段。最大有效持续时间是周期-1(在 monitoringSlotPeriodicityAndOffset 中给出的周期)。kangguoying20210831
对于 IAB-MT,持续时间表示搜索空间在每个场合持续的连续时隙的数量,即,在周期和偏移中给定的每个周期。如果该字段不存在,则 IAB-MT 应用值 1 时隙,但 DCI 格式 2_0 和 DCI 格式 2_5 除外。对于 DCI 格式 2_0 和 DCI 格式 2_5,IAB-MT 忽略此字段。最大有效持续时间是周期-1(在 monitoringSlotPeriodicityAndOffset 中给出的周期)。kangguoying20210831
freqMonitorLocations:定义搜索空间与频域中多个监测位置的关联,并指示相关 CORESET 中配置的模式是否复制到特定 RB 集,参见 TS 38.213,第 10.1 节。位图中的每一位对应一个 RB 集,最右边(最低有效)位对应 BWP 中的 RB 集 0。设置为 1 的位表示从关联 CORESET 中配置的模式复制的频域资源分配映射到 RB 集。kangguoying20210831
monitoringSlotPeriodicityAndOffset:用于 PDCCH 监控的时隙配置为周期性和偏移。如果 UE 配置为监视 DCI 格式 2_1,则仅值“sl1”、“sl2”或“sl4”适用。如果 UE 被配置为监视 DCI 格式 2_0,则只有值 'sl1'、'sl2'、'sl4'、'sl5'、'sl8'、'sl10'、'sl16' 和 'sl20' 是适用的(见TS 38.213 [13],第 10 条)。如果 UE 配置为监视 DCI 格式 2_4,则仅值“sl1”、“sl2”、“sl4”、“sl5”、“sl8”和“sl10”适用。kangguoying20210831
对于 IAB-MT,如果 IAB-MT 配置为监视 DCI 格式 2_1,则只有值“sl1”、“sl2”或“sl4”适用。如果 IAB-MT 配置为监视 DCI 格式 2_0 或 DCI 格式 2_5,则仅值 'sl1'、'sl2'、'sl4'、'sl5'、'sl8'、'sl10'、'sl16' 和 ' sl20' 适用(见 TS 38.213,条款 10)。
monitoringSymbolsWithinSlot:为 PDCCH 监控配置的时隙中用于 PDCCH 监控的第一个符号(参见 monitoringSlotPeriodicityAndOffset 和持续时间)。最高有效(左)位代表时隙中的第一个 OFDM,第二个最高有效(左)位代表时隙中的第二个 OFDM 符号,依此类推。设置为1的比特标识时隙内控制资源集的第一个OFDM符号。如果 BWP 的循环前缀设置为扩展 CP,则比特串中的最后两个比特将被 UE 或 IAB-MT 忽略。kangguoying20210831
对于 DCI 格式 2_0,如果 controlResourceSetId 标识的 CORESET(在 IE ControlResourceSet 中)的持续时间为 3 个符号,则适用第一个符号,如果 controlResourceSetId 标识的 CORESET 的持续时间为 2 个符号,则适用前两个符号,并且前三个符号适用如果 controlResourceSetId 标识的 CORESET 的持续时间指示 1 个符号,则适用。kangguoying20210831
参见 TS 38.213 [13],第 10 条。kangguoying20210831
对于 IAB-MT:对于 DCI 格式 2_0 或 DCI 格式 2_5,如果 controlResourceSetId 标识的 CORESET(在 IE ControlResourceSet 中)的持续时间指示 3 个符号,则应用第一个符号,如果 controlResourceSetId 标识的 CORESET 的持续时间,则应用前两个符号表示2个符号,如果controlResourceSetId标识的CORESET的持续时间表示1个符号,则应用前三个符号。
nrofCandidates-CI:专用于已配置聚合级别的格式 2-4 的 PDCCH 候选数。如果不存在聚合级别,则 UE 不会搜索具有该聚合级别的任何候选。网络仅配置一个aggregationLevel 和相应数量的候选者(参见TS 38.213 [13],第10.1 节)。
nrofCandidates-SFI:专用于已配置聚合级别的格式 2-0 的 PDCCH 候选数量。如果不存在聚合级别,则 UE 不会搜索具有该聚合级别的任何候选。网络只配置一个aggregationLevel 和相应数量的候选者(见TS 38.213 [13],第11.1.1 节)。对于使用 freqMonitorLocations-r16 配置的搜索空间,只有值 'n1' 有效。kangguoying20210831
nrofCandidates:每个聚合级别的 PDCCH 候选数量。此处配置的候选数量和聚合级别适用于所有格式,除非指定了特定值或提供了特定于格式的值(请参阅内部 searchSpaceType)。如果在跨载波调度小区的 SearchSpace 中配置,则该字段确定编号kangguoying20210831
searchSpaceGroupIdList:与搜索空间关联的搜索空间组 ID 的列表。网络为每个 BWP 配置最多2个搜索空间组,其中组 ID为0或 1。
searchSpaceId:搜索空间的标识。 SearchSpaceId = 0 标识通过 PBCH (MIB) 或 ServingCellConfigCommon 配置的 searchSpaceZero,因此可能不会在 SearchSpace IE 中使用。 searchSpaceId 在服务小区的 BWP 中是唯一的。在跨载波调度的情况下,被调度小区和调度小区中具有相同searchSpaceId的搜索空间相互链接。仅当在调度小区和被调度小区中配置了链接搜索空间的 DL BWP 都处于活动状态时,UE 才为被调度小区应用搜索空间。kangguoying20210831
对于 IAB-MT,搜索空间定义了如何/在何处搜索 IAB-MT 的 PDCCH 候选。每个搜索空间都与一个 ControlResearchSet 相关联。对于跨载波调度情况下的调度小区,除nrofCandidates外,所有可选字段均不存在。kangguoying20210831
searchSpaceType:指示这是公共搜索空间(存在)还是 UE 特定搜索空间以及要监视的 DCI 格式。
ue-Specific:将此搜索空间配置为 UE 特定搜索空间 (USS)。 UE 通过 C-RNTI、CS-RNTI(如果配置)和 SP-CSI-RNTI(如果配置)加扰的 CRC 来监控 DCI 格式kangguoying20210831
资料来源:TS38.331
整理:kangguoying20210831
    当前时区 GMT+8, 现在时间是 2025-12-19 23:45:27
    Processed in 0.382021 second(s), 14 queries , Gzip enabled
