  • 阅读:1559
5G网络中终端测量层一和层三结果RSRP
Mr Kang
积分 105076
帖子 8582
威望 1796753 个
发表于 2021-09-02 17:42:28  只看楼主
        在5G网络中终端用于 L3 报告的 SS-RSRP 和 CSI-RSRP 的报告范围定义为 -156 dBm 至 -31 dBm,分辨率为 1 dB。  kangguoying20210902
  •         用于L1 报告的SS-RSRP 和CSI-RSRP的报告范围定义为-140 至 -44 dBm,分辨率为1 dB。
        测量量的映射定义见表10.1.6.1-1。 信令中的范围可能大于保证精度范围。 kangguoying20210902
                                                          Table 10.1.6.1-1: SS-RSRP and CSI-RSRP measurement report mapping
Reported value     kangguoying20210902
Measured   quantity value (L3 SS-RSRP) and CSI-RSRP
Measured   quantity value (L1 SS-RSRP and CSI-RSRP)
Unit
RSRP_0
SS-RSRP<-156
Not valid
dBm
RSRP_1
-156 SS-RSRP<-155
Not valid
dBm
RSRP_2
-155 SS-RSRP<-154
Not valid
dBm
RSRP_3
-154 SS-RSRP<-153
Not valid
dBm
RSRP_4
-153 SS-RSRP<-152
Not valid
dBm
RSRP_5
-152 SS-RSRP<-151
Not valid
dBm
RSRP_6
-151 SS-RSRP<-150
Not valid
dBm
RSRP_7
-150 SS-RSRP<-149
Not valid
dBm
RSRP_8
-149 SS-RSRP<-148
Not valid
dBm
RSRP_9
-148 SS-RSRP<-147
Not valid
dBm
RSRP_10
-147 SS-RSRP<-146
Not valid
dBm
RSRP_11
-146 SS-RSRP<-145
Not valid
dBm
RSRP_12
-145 SS-RSRP<-144
Not valid
dBm
RSRP_13
-144 SS-RSRP<-143
Not valid
dBm
RSRP_14
-143 SS-RSRP<-142
Not valid
dBm
RSRP_15
-142 SS-RSRP<-141
Not valid
dBm
RSRP_16
-141 SS-RSRP<-140
RSRP<-140
dBm
RSRP_17
-140 SS-RSRP<-139
-140RSRP<-139
dBm
RSRP_18
-139 SS-RSRP<-138
-139 RSRP<-138
dBm
kangguoying2021
kangguoying20210902
kangguoying20210
RSRP_111
-46 SS-RSRP<-45
-46 RSRP<-45
dBm
RSRP_112
-45 SS-RSRP<-44
-45 RSRP<-44
dBm
RSRP_113
-44 SS-RSRP<-43
-44 RSRP
dBm
RSRP_114
-43 SS-RSRP<-42
Not valid
dBm
RSRP_115
-42 SS-RSRP<-41
Not valid
dBm
RSRP_116
-41 SS-RSRP<-40
Not valid
dBm
RSRP_117
-40 SS-RSRP<-39
Not valid
dBm
RSRP_118
-39 SS-RSRP<-38
Not valid
dBm
RSRP_119
-38 SS-RSRP<-37
Not valid
dBm
RSRP_120
-37 SS-RSRP<-36
Not valid
dBm
RSRP_121
-36 SS-RSRP<-35
Not valid
dBm
RSRP_122
-35 SS-RSRP<-34
Not valid
dBm
RSRP_123
-34 SS-RSRP<-33
Not valid
dBm
RSRP_124
-33 SS-RSRP<-32
Not valid
dBm
RSRP_125
-32 SS-RSRP<-31
Not valid
dBm
RSRP_126
-31 SS-RSRP
Not valid
dBm
RSRP_127 (Note)
Infinitykangguoying20210
Infinity
dBm
kangguoying20210902
  •        用于L1报告和 L3 报告的差分 SS-RSRP 和 CSI-RSRP 的报告范围定义为 0 dB 到 -30 dB,分辨率为2 dB。
        测量量的映射定义见表10.1.6.1-2。 信令中的范围可能大于保证精度范围。
                 Table 10.1.6.1-2: Differential SS-RSRP and CSI-RSRP measurement (for L1 reporting and L3 reporting) report mapping
Reported   value
Measured   quantity value (difference in measured RSRP from strongest RSRP)
Unit
DIFFRSRP_0
0≥ΔRSRP>-2kangguoying2021090
dB
DIFFRSRP_1
-2≥ΔRSRP>-4
dB
DIFFRSRP_2
-4≥ΔRSRP>-6
dB
DIFFRSRP_3
-6≥ΔRSRP>-8
dB
DIFFRSRP_4
-8≥ΔRSRP>-10
dB
DIFFRSRP_5
-10≥ΔRSRP>-12
dB
DIFFRSRP_6
-12≥ΔRSRP>-14
dB
DIFFRSRP_7
-14≥ΔRSRP>-16
dB
DIFFRSRP_8
-16≥ΔRSRP>-18
dB
DIFFRSRP_9
-18≥ΔRSRP>-20
dB
DIFFRSRP_10
-20≥ΔRSRP>-22
dB
DIFFRSRP_11
-22≥ΔRSRP>-24
dB
DIFFRSRP_12
-24≥ΔRSRP>-26
dB
DIFFRSRP_13
-26≥ΔRSRP>-28
dB
DIFFRSRP_14
-28≥ΔRSRP>-30
dB
DIFFRSRP_15
-30≥ΔRSRPkangguoying20210902
dB
资料来源:TS38.133
整理:kangguoying20210902
    当前时区 GMT+8, 现在时间是 2025-12-19 23:44:34
    Processed in 0.304146 second(s), 14 queries , Gzip enabled
