  • 阅读:2475
5G网络FR1频段对L1-RSRP测量精度要求
Mr Kang
积分 105076
帖子 8582
威望 1796753 个
发表于 2021-09-03 10:50:24  只看楼主
          5G网络中FR1频段对L1-RSRP测量精度要求基于SSB 的L1-RSRP要求分为绝对精度相对精度两种,分别为:
绝对精度
        基于 SSB 的 L1-RSRP 绝对精度的要求适用于为 L1-RSRP 测量配置的服务小区的所有 SSB。
        表10.1.19.1.1-1 中的精度要求在以下条件下有效:kangguoying20210903
         - 满足 TS 38.101-1 [18] 第 7.3 节中定义的参考灵敏度条件。
         - L1-RSRP 测量的条件根据附件 B.2.4.1 满足每个相关 SSB 的相应频段。kangguoying20210903
                      Table 10.1.19.1.1-1: SSB based L1-RSRP absolute accuracy in FR1
Accuracy
Conditionskangguoying20210903
Normal condition
Extreme condition
SSB ês/Iot
Io Note 1 rangekangguoying20210903
NR operating band groups Note 2
Minimum Io
Maximum Io
dB
dB
dB
dBm / SCSSSB
dBm/BWChannel
dBm/BWChannel
kangguoying20210903
SCSSSB = 15 kHz
SCSSSB = 30 kHz
kangguoying20210903
NR_FDD_FR1_A, NR_TDD_FR1_A, NR_SDL_FR1_A
-121
-118
N/A
-70
NR_FDD_FR1_B
-120.5
-117.5
N/A
-70
NR_TDD_FR1_C
-120
-117
N/A
-70
±5.0
±9.5
3-3
NR_FDD_FR1_D,   NR_TDD_FR1_D
-119.5
-116.5
N/A
-70
NR_FDD_FR1_E,   NR_TDD_FR1_E
-119
-116
N/A
-70
NR_FDD_FR1_F
-118.5
-115.5
N/A
-70
NR_FDD_FR1_G
-118
-115
N/A
-70
NR_FDD_FR1_H
-117.5
-114.5
N/A
-70
±8.5
±11.5
3-3
NR_FDD_FR1_A, NR_TDD_FR1_A, NR_SDL_FR1_A, NR_FDD_FR1_B,   NR_TDD_FR1_C, NR_FDD_FR1_D, NR_TDD_FR1_D, NR_FDD_FR1_E, NR_TDD_FR1_E, NR_FDD_FR1_F,   NR_FDD_FR1_G, NR_FDD_FR1_H,
N/A
N/A
-70kangguoying20210903
-50
NOTE 1:    Io   is assumed to have constant EPRE across the bandwidth.kangguoying20210903
NOTE 2:    NR   operating band groups in FR1 are as defined in clause 3.5.2.kangguoying20210903
相对精度:
       基于SSB的L1-RSRP的相对精度定义为从一个 SSB 测量的L1-RSRP与服务小区所有SSB 中L1-RSRP的最大测量值相比。表10.1.19.1.2-1中的精度要求在以下条件下有效:kangguoying20210903
        - 满足TS 38.101-1 [18] 第7.3节中定义的参考灵敏度条件。kangguoying20210903
        - L1-RSRP测量的条件根据附件B.2.4.1满足每个相关SSB的相应频段。
                              Table 10.1.19.1.2-1: SSB based L1-RSRP relative accuracy in FR1
Accuracy
Conditions
Normal condition
Extreme condition
SSB ês/Iot Note 2
NR operating band groups Note 4
Minimum Io
Maximum Io
dB
dB
dB
dBm / SCSSSB
dBm/BWChannel
dBm/BWChannel
kangguoying20210903
SCSSSB = 15 kHz
SCSSSB = 30 kHz
kangguoying20210903
NR_SDL_FR1_A
-121
-118
N/A
-50
NR_FDD_FR1_B
-120.5
-117.5
N/A
-50
NR_TDD_FR1_C
-120
-117
N/A
-50
±3
±4
3-3
-119.5
-116.5
N/A
-50
-119
-116
N/A
-50
NR_FDD_FR1_F
-118.5
-115.5
N/A
-50
NR_FDD_FR1_G
-118
-115
N/A
-50
NR_FDD_FR1_H
-117.5
-114.5
N/A
-50
NOTE 2:    The   parameter SSB ês/Iot is the minimum SSB ês/Iot of the pair of SSBs to which   the requirement applies.kangguoying20210903
NOTE 3:    Void
NOTE 4:    NR   operating band groups in FR1 are as defined in clause 3.5.2.
资料来源:TS38.133
整理:kangguoying20210903
    当前时区 GMT+8, 现在时间是 2025-12-19 23:44:45
    Processed in 0.309729 second(s), 14 queries , Gzip enabled
