  • 阅读:556
forloop 怎么解决
A-阳洋-18340879562
积分 60
威望 -4368 个
注册 2019-3-6
发表于 2023-05-08 12:24:18  只看楼主
forloop.docxforloop.docx<SYRIP: SURVEY;
ACT     FYCTCE1                   AD-241  TIME 230501 0447  BC2
ORDERED
ACT     FYCTCE1                   AD-241  TIME 230501 0447  BC1
ORDERED
ACT     FYCTCE1                   AD-241  TIME 230501 0447  BC0
ORDERED
SOFTWARE RECOVERY SURVEY
EVENT TYPE          EXPLANATION                         EVENTCNT  FRDEL
   44 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE                1
   43 FORLOPP       BUFFER NOT ALLOCATED                              1
   30 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE         2      1
   29 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE         3      1
   28 FORLOPP       ACCESS TO UNALLOCATED BUFFER               2      1
   27 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE         2      1
   26 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE                1
   25 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE         3      1
   23 RELOAD        PLAN
   22 APPLERR       ERROR REPORTED BY PROCEDURE FLERROR        2
   21 LARGE         PLAN
   18 APPLERR       ERROR REPORTED BY PROCEDURE FLERROR
   17 LARGE         PLAN
   16 LARGE         OTHER-SYSTEM FAILURE
   15 APPLERR       ERROR REPORTED BY PROCEDURE FLERROR        2
   12 APPLERR       ERROR REPORTED BY PROCEDURE FLERROR        2
EVENT CODE   INF1   INF2   INF3   INF4   SIDE STATE   DATE   TIME   ACT
   44 H'310C H'0000 H'0001 H'0012 H'0000 A-EX ACTIVE  230413 020459 NO
   43 H'0022 H'0F94 H'2861 H'0000 H'0000 A-EX ACTIVE  230328 104127 NO
   30 H'310C H'0000 H'0933 H'0000 H'0000 A-EX ACTIVE  230327 161249 NO
   29 H'310C H'0000 H'0144 H'0001 H'0000 A-EX ACTIVE  230327 161219 NO
   28 H'1005 H'008A H'2079 H'0001 H'0000 A-EX ACTIVE  230327 161154 NO
   27 H'310C H'0000 H'008A H'0000 H'0000 A-EX ACTIVE  230327 161154 NO
   26 H'310C H'0000 H'0E67 H'0000 H'0000 A-EX ACTIVE  230327 161123 NO
   25 H'310C H'0000 H'0C6F H'0007 H'0000 A-EX ACTIVE  230327 161010 NO
   23 H'9010 H'0009 H'0003 H'0000 H'0000 A-EX ACTIVE  230322 193041 NO
   22 H'4300 H'670E H'0768 H'0000 H'0000 A-EX ACTIVE  230322 191737 NO
   21 H'9003 H'0009 H'0000 H'0000 H'0000 A-EX ACTIVE  230322 191732 NO
   18 H'4300 H'670E H'0768 H'0000 H'0000 A-EX ACTIVE  230322 100829 NO
   17 H'9003 H'0009 H'0000 H'0000 H'0000 A-EX ACTIVE  230322 100823 NO
   16 H'9010 H'000A H'0003 H'0000 H'0000 A-EX ACTIVE  230315 054633 NO
   15 H'4300 H'670E H'0768 H'0000 H'0000 A-EX ACTIVE  230314 130750 NO
   12 H'4300 H'670E H'0768 H'0000 H'0000 A-EX ACTIVE  230312 105740 NO
END
   39 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE                1
   38 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE         2      1
   36 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE         3      1
   35 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE         6      1
   34 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE         2      1
   33 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE                1
   32 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE                1
   31 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE         3      1
   29 APPLERR       ERROR REPORTED BY PROCEDURE FLERROR
   28 CLONING       COMMAND ORDERED CLONING
   27 APPLERR       ERROR REPORTED BY PROCEDURE FLERROR
   26 CLONING       COMMAND ORDERED CLONING
   25 RELOAD        PLAN
   24 APPLERR       ERROR REPORTED BY PROCEDURE FLERROR        2
   23 CLONING       COMMAND ORDERED CLONING
   20 APPLERR       ERROR REPORTED BY PROCEDURE FLERROR
   13 APPLERR       ERROR REPORTED BY PROCEDURE FLERROR
   39 H'310C H'0000 H'008A H'0000 H'0000 A-EX ACTIVE  230413 020324 NO
   38 H'310C H'0000 H'0933 H'0000 H'0000 A-EX ACTIVE  230327 164505 NO
   36 H'310C H'0000 H'0144 H'0001 H'0000 A-EX ACTIVE  230327 164323 NO
   35 H'310C H'0000 H'0146 H'0001 H'0000 A-EX ACTIVE  230327 164306 NO
   34 H'310C H'0000 H'008A H'0000 H'0000 A-EX ACTIVE  230327 164249 NO
   33 H'310C H'0000 H'0E5F H'0000 H'0000 A-EX ACTIVE  230327 164233 NO
   32 H'310C H'0000 H'0F57 H'0001 H'0000 A-EX ACTIVE  230327 164215 NO
   31 H'310C H'0000 H'0C6F H'0007 H'0000 A-EX ACTIVE  230327 164107 NO
   29 H'4300 H'670E H'0768 H'0000 H'0000 A-EX ACTIVE  230323 132117 NO
   28 H'9013 H'0000 H'0000 H'0000 H'0000 A    PASSIVE 230323 132102 NO
   27 H'4300 H'670E H'0768 H'0000 H'0000 A-EX ACTIVE  230323 124256 NO
   26 H'9013 H'0000 H'0000 H'0000 H'0000 A    PASSIVE 230323 124241 NO
   25 H'9010 H'0009 H'0003 H'0000 H'0000 A-EX ACTIVE  230322 193041 NO
   24 H'4300 H'670E H'0768 H'0000 H'0000 A-EX ACTIVE  230322 192845 NO
   23 H'9013 H'0000 H'0000 H'0000 H'0000 A    PASSIVE 230322 192830 NO
   20 H'4300 H'670E H'0768 H'0000 H'0000 A-EX ACTIVE  230322 150817 NO
   18 H'4300 H'670E H'0768 H'0000 H'0000 A-EX ACTIVE  230322 100917 NO
   13 H'4300 H'670E H'04C8 H'0000 H'0000 A-EX ACTIVE  230314 130326 NO
END
   40 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE                1
   33 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE         6      1
   31 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE                1
   29 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE                1
   28 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE         2      1
   27 FORLOPP       MANUALLY INITIATED FORLOPP RELEASE         4      1
   26 LARGE         PLAN
   25 APPLERR       ERROR REPORTED BY PROCEDURE FLERROR        2
   24 CLONING       COMMAND ORDERED CLONING
   23 APPLERR       ERROR REPORTED BY PROCEDURE FLERROR
   22 RELOAD        PLAN
   19 APPLERR       ERROR REPORTED BY PROCEDURE FLERROR
   18 LARGE         PLAN
   16 APPLERR       ERROR REPORTED BY PROCEDURE FLERROR        2
   14 APPLERR       ERROR REPORTED BY PROCEDURE FLERROR        2
   40 H'310C H'0000 H'0933 H'0000 H'0000 A-EX ACTIVE  230327 163432 NO
   33 H'310C H'0000 H'0146 H'0001 H'0000 A-EX ACTIVE  230327 162920 NO
   32 H'310C H'0000 H'0E5F H'0000 H'0000 A-EX ACTIVE  230327 162839 NO
   31 H'310C H'0000 H'0E67 H'0000 H'0000 A-EX ACTIVE  230327 162720 NO
   30 H'310C H'0000 H'0A0D H'0002 H'0000 A-EX ACTIVE  230327 162609 NO
   29 H'310C H'0000 H'0F57 H'0001 H'0000 A-EX ACTIVE  230327 162552 NO
   28 H'310C H'0000 H'04DE H'0000 H'0000 A-EX ACTIVE  230327 162515 NO
   27 H'310C H'0000 H'0C6F H'0007 H'0000 A-EX ACTIVE  230327 162408 NO
   26 H'9003 H'0009 H'0000 H'0000 H'0000 A-EX ACTIVE  230323 130810 NO
   25 H'4300 H'670E H'0768 H'0000 H'0000 A-EX ACTIVE  230323 130416 NO
   24 H'9013 H'0000 H'0000 H'0000 H'0000 A    PASSIVE 230323 130401 NO
   23 H'4300 H'670E H'0768 H'0000 H'0000 A-EX ACTIVE  230322 193116 NO
   22 H'9010 H'0009 H'0003 H'0000 H'0000 A-EX ACTIVE  230322 193041 NO
   19 H'4300 H'670E H'0768 H'0000 H'0000 A-EX ACTIVE  230322 100847 NO
   18 H'9003 H'0009 H'0000 H'0000 H'0000 A-EX ACTIVE  230322 100842 NO
   16 H'4300 H'B107 H'334B H'0000 H'95CA A-EX ACTIVE  230316 145232 NO
   14 H'4300 H'670E H'0768 H'0000 H'0000 A-EX ACTIVE  230314 130750 NO
END
<pcorp:block=GCPHCP;
PROGRAM CORRECTIONS
BLOCK    SUID                               CA     CAF    ILEN
GCPHCP   8SJA/CAAW 107 0375/MCOEL R1A01     32     2      32
CI               S  TYPE  POSITION         SIZE
SWAXC3677        C  CODE  H'38B4           30
                 F                         2
END
<LASIP:BLOCK=GCPHCP;
SOFTWARE UNIT IDENTITY
BLOCK    BN     BS       FCODE  ID
GCPHCP   H'E67  ACTIVE          8SJA/CAAW 107 0375/MCOEL R1A01
END
    瀛楁暟缁熻
    当前时区 GMT+8, 现在时间是 2025-06-17 08:11:03
    Processed in 0.719170 second(s), 14 queries , Gzip enabled
