  • 阅读:1094
Solar + diesel engine hybrid power supply system
18823439285
积分 376
帖子 75
威望 60115 个
注册 2017-11-27
来自 深圳
发表于 2024-05-29 14:57:43  只看楼主
System principle
Work Mode Explanation
1.         During Sufficient Sunlight:
            The solar photovoltaic (PV) system primarily powers the load directly.
            Meanwhile, excess electricity is used to charge the battery for future use.
2.         During Insufficient Sunlight:
            The solar PV system continues to operate, but the generated electricity may not be sufficient to meet the load demand.
            At this point, the energy storage battery discharges to supplement the power requirements.
            The solar PV system and the battery simultaneously supply power to the load, ensuring stable operation.
3.         When the Battery Is Low:
            When the battery charge drops to a predefined low threshold, the system will automatically or manually start the diesel generator.
            The diesel generator supplies power to the load through a rectifier module (possibly an AC/DC converter).
            At the same time, the output of the rectifier module is connected to the battery for charging.
Implementation Strategies
1.         System Monitoring and Control:
            A central control system is required to monitor the status of the solar energy, battery, and load.
            The control system should be able to automatically switch energy sources to ensure continuous power supply to the load.
2.         Battery Management:
            Use a smart battery management system (BMS) to monitor the charging and discharging status of the battery.
            The BMS should prevent overcharging and over-discharging of the battery to extend its lifespan.
3.         Diesel Generator Maintenance:
            Regularly inspect and maintain the diesel generator to ensure it starts and runs properly when needed.
            Stock up on sufficient fuel to meet expected runtime.
4.         Rectifier Module Selection:
            Choose an efficient and reliable rectifier module to minimize energy losses during power conversion.
5.         Safety Considerations:
            Ensure that the entire system complies with relevant electrical safety standards.
            Implement appropriate protective measures, such as overcurrent, overvoltage, and short-circuit protection.
6.         Energy Efficiency Optimization:
            Use high-efficiency PV modules and batteries to reduce energy losses.
            Consider adopting energy management techniques, such as maximum power point tracking (MPPT), to improve the efficiency of photovoltaic power generation.
7.         Environmental Impact Assessment:
            Before deploying the system, assess its impact on the environment, including noise, emissions, and ecological effects.
            Take measures to reduce negative impacts, such as using low-noise generators and environmentally friendly fuels.
8.         Economic Analysis:
            Consider the long-term operating costs and maintenance costs when designing the system.
            Compare the costs and efficiency of different energy sources to select the most economical solution.
    当前时区 GMT+8, 现在时间是 2026-07-26 06:22:14
    Processed in 0.341609 second(s), 13 queries , Gzip enabled
