  • 阅读:3624
诺基亚4G同异频切换的参数配置
mazhida911
积分 331
帖子 67
威望 9012 个
注册 2010-1-12
发表于 2025-04-10 14:13:03  只看楼主
A1事件
事件进入条件:Ms - Hys > Thresh
停止异频测量门限:Threshold th2a for RSRP(Threshold2a)
 A1迟滞:Related hysteresis of threshold th2a for RSRP (hys threshold2a)
服务小区的RSRP- hys threshold2a >Threshold2a,且保持时间超过a1TimeToTriggerDeactInterMeas
的设置时间,则停止异频测量。
A2事件:
启动同频测量门限threshold1
事件进入条件:Ms + Hys < Thresh
启动异频测量门限:Threshold th2 interFreq for RSRP (threshold2InterFreq)
A2迟滞:Related hysteresis of threshold th2 interfreq for RSRP(hysThreshold2InterFreq)
打开Enable interfrequency handover:异频切换开关
Time to trigger for A2 to activate inter measurement(a2TimeToTriggerActInterFreqMeas
当服务小区的RSRP+ hysThreshold2InterFreq < threshold2InterFreq,且保持时间超过的设置时间
,则开始异频测量
A3事件
事件进入条件:Mn + Ofn + Ocn - Hys > Ms + Ofs + Ocs + Off
事件离开条件:Mn + Ofn + Ocn + Hys < Ms + Ofs + Ocs + Off
NSNOfn/Ocn/Ofs/Ocs 参数
同频A3事件
同频A3迟滞:Related hysteresis of offset a3offset for RSRP intra F(hysA3Offset)
A3报告时长:A3 report interval
A3触发时延:A3 time to trigger
A3偏置:A3offset
故同频A3事件需满足:邻小区的RSRP-hysA3Offset
>服务小区的RSRP+ a3Offset,由于hysA3Offset配置为0,故A3事件的示意图如下图所示:
异频A3事件
异频A3偏置 A3 offset RSRP inter frequency
a3OffsetRsrpInterFreq
异频A3报告时长:A3 report interval RSRP inter frequency
异频A3触发时延:A3 time to trigger RSRP inter frequency
异频A3迟滞:Related hysteresis offset a3offset  RSRP inter frequency hysA3OffsetRsrpInterFreq
异频A3事件满足:邻小区的RSRPhysA3OffsetRsrpInterFreq
 >服务小区的RSRP+ a3OffsetRsrpInterFreq
A5事件:
事件进入条件:Ms + Hys < Thresh1
Mn + Ofn + Ocn- Hys >Threah2
诺西无Ofn/Ocn参数
同频A5事件:
Thresh1:Threshold th3 for RSRP(threshold3)
Thresh2 :Threshold th3a for RSRP( threshold3a )
A5报告时长A5 report interval
A5触发时延A5 time to trigger
A5迟滞Related hysteresis th3 and th3a for RSRP
同频A5事件满足:当服务小区的
RSRP+hysThreshold3<threshold3,且邻区RSRP- hysThreshold3>threshold3a
由于现网中的迟滞配置为0,故只要服务小区低于threshold3,邻区高于threshold3a,并达到触发的时间,就会发生切换,其示意图如图所示:
异频A5事件:
Thresh1:Threshold th3 for RSRP inter frequency(threshold3InterFreq )
Thresh2 :Threshold th3a for RSRP inter frequency(threshold3aInterFreq )
A5报告时长A5 report interval inter frequency
A5触发时延A5 time to trigger inter frequency
A5迟滞Related   hysteresis of thresholds th3 and th3a for RSRPhysThreshold3InterFreq
同异频切换的参数配置.docx
异频A5事件满足:
当前服务小区的RSRP+hysThreshold3interFreq< threshold3InterFreq
并满足:邻区的RSRP- hysThreshold3interFreq> threshold3aInterFreq
A4事件:
事件进入条件:Mn + Ofn + Ocn - Hys > Thresh
通过A5事件来实现,将A5事件中的Thresh1配置一个很高的值,使Ms + Hys < Thresh1 永远成立,注意这地方的Thresh1需要小于等于异频起测门限值Threshold th2 interFreq for RSRP,只要邻区满足Mn + Ofn + Ocn - Hys > Thresh2,即可实现A4
2025-4-10 14:12:55  下载次数: 8
同异频切换的参数配置.docx (2.41 MB)
    当前时区 GMT+8, 现在时间是 2025-07-21 10:25:43
    Processed in 2.769750 second(s), 15 queries , Gzip enabled
