  • 阅读:6929
3GPP RELEASE 20-完成5GA演进,为6G做准备
sparkxiao
积分 1347
帖子 189
威望 145630 个
专家指数 49
注册 2008-3-17
发表于 2026-04-12 11:01:55  只看楼主
3GPP RELEASE 20
Completing the 5G Advanced evolution and preparing for the next-generation wireless
6G RAN Plenary Study
Initially approved in December 2024, revised in March and June 2025
Investigate a candidate set of minimum technical performance requirements (TPRs) based on the Recommendation
ITU-R M.2160, as well as the associated target values and key assumptions for the identified minimum TPRs
Identify typical and practical deployment scenarios defined by attributes e.g., carrier frequency, inter-site distance,
user density, maximum mobility speed, and others
Develop 3GPP requirements for 6G Radio for improvement of existing and new services
Determine the applicability of legacy services to 6G Radio, and define radio requirements
Develop 3GPP requirements for 6G Radio for these practical deployment scenarios to ensure substantial gains in all
relevant bands (e.g., overall performance, user experience, TCO reduction) for:
• Ensure appropriate set of functionalities, minimize the
adoption of multiple options for the same functionality,
avoid excessive configurations, excessive device
capabilities and device capabilities reporting
• Energy efficiency and energy saving for network and device
• Enhanced spectral efficiency
• Enhanced overall coverage, focus on
cell-edge performance and uplink coverage
• Wider channel BW (at least 200MHz) support for
6G deployments at least > 2 GHz, around 7 GHz
• Re-use of existing 5G mid-band (~3.5GHz) site grid for
6G deployments in at least around 7 GHz and targeting
comparable coverage to 5G mid-band
• Target scalable and forward compatible design
for diverse device types
• Improved spectrum utilization and operations taking
into account diverse spectrum allocations
• Aim at using common 6G Radio design, which meets
mobile broadband service requirements as high priority,
to also meet vertical needs
• Aim at a harmonized 6G Radio design for TN and NTN,
including their integration
• System simplification, including reducing configuration
complexity, enabling more efficient Cell/device management,
etc.
Define a time plan & steer work as appropriate for the RAN WGs during the 6G WG SI to deliver high-level decisions for:
Core
Network
Cloud
Radio
Access
Network
Devices
• Fundamental 6G radio design aspects:
waveform, numerology, channel coding, etc.
• Overall high-level aspects of 5G to 6G migration
• RAN architecture and interfaces,
including RAN-Core interface
• Coordination of 6G AI/ML framework
3GPP-Release-20.pdf
2026-4-12 11:01:42  下载次数: 1
3GPP-Release-20.pdf (11.11 MB)
    当前时区 GMT+8, 现在时间是 2026-06-21 07:11:18
    Processed in 0.681053 second(s), 15 queries , Gzip enabled
