  • 阅读:122
Mesh+fast roaming for mining tunnel application
wx_10366441
积分 65
帖子 13
威望 6324 个
注册 2026-4-15
发表于 2026-05-18 10:42:47  只看楼主
Stop Wasting Time on Mining Tunnel Connectivity Failures – DR5018S Delivers Reliability
Underground mining tunnels are a connectivity nightmare: signal reflections, blind spots, and moving AGVs that drop critical data.
With our DR5018S solution, you get:
🔗 Self-Healing Mesh Network
Multiple nodes connect via 5G/6G links to create a redundant network. If one node fails, traffic reroutes automatically—no manual intervention, no downtime.
⚡ Blazing-Fast Roaming for Moving AGVs
As your AGV travels through tunnels, it connects to multiple APs simultaneously, switching in milliseconds. No more lost commands, no more production delays.
🏭 Built for Mining’s Toughest Conditions
IP-rated, vibration-resistant hardware that works in dust, humidity, and extreme temperatures—designed to last in underground environments.
Don’t let poor connectivity slow your mining operations. Our DR5018S solution ensures your AGVs, cameras, and sensors stay connected, no matter how deep you go.
该图片无替代文字
    当前时区 GMT+8, 现在时间是 2026-05-20 15:43:46
    Processed in 0.252883 second(s), 12 queries , Gzip enabled
