技术综合交流区
基站理论与维护
» 请高手讨论一下NOKIA基站7745的处理方法
appoint123
积分 8692
帖子 61
威望 259029 个
注册 2006-7-7
发表于 2008-09-26 10:11:30
一. 7745告警定义::
CHANNEL FAILURE RATE ABOVE DEFINED THRESHOLD(占用某个信道的失败率高于设定的门限值),这个告警是用来监视话务信道&信令信道的质量状况,检测可能出现故障的信道。
二. 影响该告警的网络一些使用默认参数的值
ZEEN:TCHFR = TCH failure rate(20 %)
SCHFR = SDCCH failure rate(80 %)
PRDCFR = length of supervision period (60 min)
CS = channel seizure threshold value(10)
SMBNT = supervision start time(08-00)
EMBNT = supervision end time(18-00)
与它相关的参数有四个:一是占用话务信道的失败率门限值是20 %;二是:占用信令信道的失败率门限值是80 %;三是:监视测量信道的时间长度为60分钟;四是:信道的门限值是10 。
三. 如何看告警信息
告警信息关键词:0100 00000000000100060290D
告警信息解释
1 indicates if the alarm is on the TCH or on the SDCCH channel
01: TCH
02: SDCCH
2 indicates if the channel failure rate is above the defined
threshold in time slot 0 01表示TS0高于定义的信道失败率门限
00: belove threshold (no alarm)
01: above threshold (alarm)
3 indicates if the channel failure rate is above the defined
threshold in time slot 101表示TS1高于定义的信道失败率门限
4 indicates if the channel failure rate is above the defined
threshold in time slot 201表示TS2高于定义的信道失败率门限
5 indicates if the channel failure rate is above the defined
threshold in time slot 3 01表示TS3高于定义的信道失败率门限
6 indicates if the channel failure rate is above the defined
threshold in time slot 4 01表示TS4高于定义的信道失败率门限
7 indicates if the channel failure rate is above the defined
threshold in time slot 5 01表示TS5高于定义的信道失败率门限
8 indicates if the channel failure rate is above the defined
threshold in time slot 601表示TS6高于定义的信道失败率门限
9 indicates if the channel failure rate is above the defined
threshold in time slot 701表示TS7高于定义的信道失败率门限
10time slot with the highest failure rate 失败率最高的时隙
11subchannel identification TCH:02表示子信道为tch
00: TCH/H -subchannel 0
01: TCH/H -subchannel 1
02: TCH/F -subchannel
subchannel identification SDCCH:
00 - 07:SDCCH -subchannel 0 - 7
12proportion of TCH or SDCCH subchannel releases due to failure
in all channel releases on a given channel during the measurement
period指定信道,TCH/SD因失败释放信道占所有trx释放信道的百分比
02 - LTE-SAE Network Architecture v1.0
2013-11-20
LTE-SAE Overview v1.0
2013-11-20
Flexi Multiradio BTS-RRH应用指导
2012-08-13
厦门纵横福州维护中心2011年应预案
2012-05-13
谁有代维管理考核办法?
2011-07-28
eming0211
积分 5303
帖子 236
威望 1791696 个
专家指数 -12
注册 2006-9-1
发表于 2009-06-25 09:19:56
在线,46天前提问
在线,76天前提问
在线,241天前提问
在线,276天前提问
在线,340天前提问
在线,377天前提问
在线,426天前提问
在线,435天前提问
在线,464天前提问
在线,487天前提问
在线,495天前提问
在线,513天前提问
在线,541天前提问
在线,544天前提问
在线,554天前提问
在线,572天前提问
先顶你一下,望有人解决
ncjxghg
积分 2293
帖子 226
威望 21431 个
专家指数 153
注册 2007-7-2
发表于 2009-11-09 00:40:08
这告警很难清除,设备自身和无线环境有问题都能出现该告警。我这里的7745有一大把。
当前时区 GMT+8, 现在时间是 2026-04-20 03:59:40
Processed in 0.502262 second(s), 19 queries , Gzip enabled
