  • 阅读:6183
LTE-A 协议规定终端可以在SCELL上发起随机接入吗?(已解)
铭哲
积分 455
帖子 91
威望 10063 个
注册 2011-9-14
发表于 2016-06-24 10:54:06  只看楼主
各位,最近遇到一个问题是:终端可以在SCELL上发随机接入吗?
最近在调测一个Case,发现协议规定,SS通过发送PDCCH Order要求终端在SCELL上发随机接入(St5),在PCELL上回随机接入响应(St9)。这就让我有以下几点不懂
1)以前看的资料SCELL只是提供传输资源,不能进行随机接入。但是523协议上的步骤让我不太理解,是不是Release变化,内容也跟着变了???这是我自己唯一的解释
answer:终端是不能在SECLL接入的,SCELL只能提供传输资源,这跟哪个Release无关。
2)步骤定义:SCELL上发随机接入,PCELL回随机接入响应。为何不在SCELL上回随机接入响应???
answer:这个随机接入不应该叫随机接入,应该叫上行同步。终端若检测到了跟SCELL上行失步了,要进行上行同步,PCELL回同步响应。
3)PCELL回随机接入响应后,站在终端角度来说,那PCELL和SCELL对于终端是有何变化???
answer:PCELL还是PCELL,SCELL还是SCELL。
4)这个用例这么设计,在现网中有何应用场景???
answer:终端检测与SCELL上行失步了,通过随机接入来重新获得SCELL的同步。
我记得协议上有说过,随机接入目的有二:
一.申请上行同步
二.申请上行资源
因此这个解释是合情合理的
Cell 1 (PCell) and Cell 3(SCell)
Cell 3 is an Active SCell according to [18] cl. 6.3.4
Table 7.1.2.10.1.3.2-1: Main behaviour
St
Procedure
Message Sequence
TP
Verdict
U - S
Message
The SS transmits an RRCConnectionReconfiguration message with SCell (Cell 3) addition
The UE transmits an RRCConnectionReconfigurationComplete message to confirm SCell (Cell 3) addition.
RRCConnectionReconfiguration Complete
The SS transmits an Activation MAC control element to activate SCell (Cell 3).
MAC PDU (Activation (C1=1))
The SS indicates a new transmission on PDCCH of CC1
(Cell 1) and transmits a MAC PDU (containing an RLC PDU )
MAC PDU (CC1)
The SS transmits a PDCCH order providing Random Access Preamble on SCell (Cell 3)
(PDCCH Order)
EXCEPTION: In parallel with step 6 to 8, parallel behaviour defined in table 7.1.2.10.1.3.2-2 is executed
Check: Does the UE transmit a preamble on PRACH
using the same preamble index as given in step 5 on SCell (Cell3)?
(PRACH Preamble)
P
Check: Does the UE transmit a preamble on PRACH after ra-ResponseWindowSize using the same preamble index as given in step 5 on SCell (Cell3)?
(PRACH Preamble)
P
(PRACH Preamble)
P
9
The SS transmits Random Access Response with RAPID corresponding to Preamble in step 5 on PCell (Cell 1).
10
The SS indicates a new transmission on PDCCH of CC2
(Cell 3) and transmits a MAC PDU (containing an RLC PDU )
MAC PDU (CC2)
11
The SS sends an UL grant suitable for transmitting loop back PDU on Cell 3.
(UL Grant)
12
Check: Does the UE transmit a MAC PDU containing the loop back PDU corresponding to step 10?
MAC PDU(CC2)
4, 5
P
13
The SS transmits a MAC PDU containing RLC status PDU acknowledging reception of RLC PDU in step 12
MAC PDU (CC2)
Table 7.1.2.10.1.3.2-2: Parallel behaviour
St
Procedure
Message Sequence
TP
Verdict
U - S
Message
The UE transmits a Scheduling Request on PUCCH
(SR)
P
The SS sends an UL grant suitable for transmitting loop back PDU on Cell 1.
(UL Grant)
Check: Does the UE transmit a MAC PDU containing the loop back PDU corresponding to step 4?
MAC PDU
P
The SS transmits a MAC PDU containing RLC status PDU acknowledging reception of RLC PDU in step 3
MAC PDU (CC1)
[ 本帖最后由 铭哲 于 2016-6-28 09:45 编辑 ]
    • mao_mao 威望 +10 个
      · 鼓励提问讨论! 详细.. 发表与:2016-6-24 19:20:16
    铭哲
    积分 455
    帖子 91
    威望 10063 个
    注册 2011-9-14
    发表于 2016-06-24 15:20:04  只看楼主
    偌大的论坛,没有能解决问题的人吗?都是来学习的。请帮忙顶上去
    威望 1814350 个
    发表于 2016-09-16 23:14:41
    可以,规范只是允许的;只是没有厂家的设备支持。。
    当前时区 GMT+8, 现在时间是 2026-07-24 08:35:53
    Processed in 0.680877 second(s), 17 queries , Gzip enabled
